Russian Su-33 Flanker D by CDW - FINISHED - Trumpeter - 1:72 Scale
2 minutes ago, king derelict said:
I dunno Craig. It seems that most times I read your updates I find myself going off to buy something.
You have some great tips. Thanks
The Flanker is looking really nice
Alan
Alan
I actually bought the Infini template/s after watching another modeler paint the deck of a 1:700 warship using the smallest strips of masking tape to paint the individual planks in various wood colors. It came out so nice, I had to have one myself.
Amen. I've been looking at these things and I could see one or two of them finding their way to Casa Canute.
Ken
Started: MS Bounty Longboat,
Thanks to the wonders of Amazon the Type A turned up this morning. I had to play with it straight away and it works very well with Tamiya and blue tape. Definitely needs a new knife blade to get the best out of it. think its going to be great for masking decks and I have a Centurian tank that I want to do in the Berlin paint scheme and i think that will solve a lot of problems.
Of course now I'm thinking I need some of the others.
Alan
Alan
I use a number 11 surgical scalpel blade and that works perfect for me. Definitely a new blade. I have the small radius template as well. I think it’s the B template. I don’t see as much need for the other two. My next 1:700 scale warship decks will be painted as mentioned earlier, using the tape to simulate different color boards.
Craig if I am reading you right are you talking about the three color scheme derived from one color for decks?I have done two back in day like that that is some work it works but alot of taping and patience.I  in fact started the Eugen like that and bought the wood deck to go over it it's a long process.;)
Yes, that's the process. Tedious work but in the end looks fantastic.
Such nice work  - really looking the part.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Brother, that is one of the best jobs of tonal masking I've ever seen, and the first using metallic's....
Very, Very well done...
And thanks for showing the proper technique... Not too many know how to do it correctly...
Very nice...
Very nice...
Thanks EG. I learned that technique from a fellow modeler a few years ago. I should have mentioned the metallic colors used were lacquers. Alclad II and Mr Color. The Mr Color copper color was highly reduced to keep it somewhat translucent. Of course the Alclad colors are translucent straight from the bottle. One day I am going to try this technique using acrylics but on something scrap, first. Not sure about getting a translucent finish using acrylics.
I put on all the decals I intend to use on the airframe then applied some Solvaset. Will let them thoroughly dry before proceeding with panel lines detail. There remain a LOT of weapons needing detail painting and decals as well as the landing gear and doors. Fun 🤩
This is looking Superb  - you have brought all the detail out of what looks like an excellent kit.
OC.
Current builds
Completed works.
OC.
Thanks OC
The ingredients for an oil panel line wash
Lightly dampen a rag with white spirits and give it all a good wipe down (in the direction of airflow)
There are various products one could use to reduce artist oils for the panel wash, but here I chose lighter fluid. Besides being an excellent product to reduce the oil, it contains naptha which dries more quickly than other products such as white spirits. It's a builder's choice, whatever works well for you, use it.
Edited by CDW
43 minutes ago, Canute said:
Paint job and weathering were quite nicely done. Now, I want to see your loadout.:D
Thanks Ken. This being a naval fighter, it’s going to carry an interesting mix of air-to-surface missiles along with air-to-air and a data link pod. The Russians have the KH-59 cruise missiles, a slow, low flying missile, and the KH-31 hypersonic missiles designed to take out ships as well as ground targets. For air defense, R-77’s, R-27”s, and R-73”s.
