On 3/4/2023 at 6:58 PM, Valeriy V said:
I am glad to welcome all members of the forum again! :)
My new topic will be dedicated to the Cyclone-class destroyer. It was built by the Nevsky Zavod in St. Petersburg in 1902.
Displacement: 152.4 tons
 Length: 45 m
 Width: 4.9 m
Draft aft: 2.5 m
Armament:
2 - 47 mm (1.9 in) guns
1× 2 torpedo tubes 356 mm
Greetings Valeriy for the next construction. I will be very happy to watch.:imNotWorthy:🔥 Ondras
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
2 hours ago, Valeriy V said:
On the drawing it looks like this:
Valeriy, I had noticed that and assumed it was used for low speed manoeuvring. given the exposed position it would seem untenable  to use it during action or in a seaway.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I think the original idea was to reduce the turning circle following an attack. Torpedoboats and destroyers would approach their target at high speed, fire their torpedos and then turn away quickly to get out of the range of the artillery of their targets. The long narrow hulls would make torpedoboat very slow turners.
It seems to me that your assumption is true for the first destroyers who had torpedo tubes built into the hull and fixed.
The destroyers of the Cyclone type already had full-fledged rotary torpedo tubes and they could fire from any heading angles without fear of losing time to turn around.
Therefore, Keith's assumption is probably closer to reality. These destroyers were created for coastal action where there are many narrow bays, skerries and fjords. In these difficult conditions, it was necessary to maneuver constantly.
Valeriy, happy to see you are back in the forum. Looking forward to this build.
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
On 3/28/2023 at 6:19 PM, Valeriy V said:
I am making the propeller group of the destroyer.
Very nice, How did you make the propellors and "A" frames? Are the blades brazed on to the hubs and how did you achieve the twist? Ditto the bearing bosses on the "A" frames. Hope you are keeping safe.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
21 hours ago, Tony Hunt said:
We need an update, Valeriy! 😀
Tony!
       Now I'm working on the hull of the destroyer. It's dusty and dirty work, and I try to do it outside. However, bad street weather now does not help speed up the process.
    And I'll have to wait a bit and work on different blueprints...
Thanks Keith, I'm fine!  :)
All parts are made separately and soldered together with silver solder. After soldering with silver, the brazed seam is very strong. This allows me to bend the propeller blade to the desired angle using ordinary pliers. In this case, between the propeller blade and the metal of the tool, I insert a small wooden spacer. It protects the item from deep scratches.
Thank you Valeriy - very useful. I'll copy your technique for Cangarda. Copying is the sincerest form of flattery.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Wishing you well.🙂
Ras
Current builds:
Previous builds:
44 minutes ago, Dr PR said:
Valeriy,
How do you get the holes for the prop shaft in the propeller struts to align with the openings in the hull?
Phil, this is very easy to do.
  First you need to fix the propeller shaft using a template, and then solder the necessary parts on the fixed propeller shaft.
  I show this method in the photographs of Varyag.
Really clever. This log keeps getting more and more amazing!
Excellent work as usual Valerie. The stern is quite an unusual shape - neither round or flat. The props seem large in comparison to the hull but I guess she had a lot of power for her size.
Is the plating simulated using card or something more elaborate?
I hope you are keeping safe.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Valeriy
I tried looking the cyclone class up but couldn't find much detail. Were they early samples of turbine powered craft or did they have reciprocating machinery? Do you know what the horse power was? Were they coal or oil fired?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
