beautiful work Valeriy,
I like the reinforcement brackets at the mid-island front area...
Nils
Current builds
-Lightship Elbe 1
Completed
Valeriy, Is the originals hull plated and riveted?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I am well aware of this method, but was always worried, that the edges of the putty may crumble. Automotive (spray) putty is quite strong on the surface, but it is actually a bit crumbly, so as to permit easy sanding.
I gather, once painted the edges of the strakes become much stronger?
Very good looking result Valeriy,
The hull structured with these "belts" give the model a realistic look
Nils
Current builds
-Lightship Elbe 1
Completed
5 hours ago, Valeriy V said:
Yes, undoubtedly, paint helps strengthen the edge.
WOW. Incredible results that you obtained Valeriy.
However, I am not sure I would trust the automotive putty (even painted) in such small thickness.
Most definitely, the hull will require a lot of care when manipulated.
Yves
Yves
Yves, no need to worry! :)
  This method has been tested in practice by more than a dozen ship modellers on floating ship models. ;)
Here in the US we call this stuff Bondo.  I have found it to be very durable.  I have a Navy Steam Cutter model that is 35 years old.  I made the cylindrical boiler by casting a blob using a pipe for a mold and then turning the casting on a lathe.  It is still as good as new.
The only problem that I have encountered recently is that it sets up so quickly that it would be impossible to spread it carefully.
Roger
I’m not very familiar with ship construction of this period but your work reminds me of all those beautiful builders models in the finest museums. It is a pleasure to watch your build!
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks Greg!
  It is these models made at the beginning of the last century that inspire me. :)
3M developed a UV activated Bondo and it sounded like the cat's meow so I purchased a can and proceeded to use it on filling the body panel on a car I was restoring (I can't remember which one). Once I had the panel filled I sat it out in the sun for the recommended amount of time and it was still soft. I allowed another couple of hours, still soft. I let that stupid panel sit for two days in the sun and it never hardened.  I finally had to dig and scrape every bit of that worthless product off the panel. UV activated Bondo sounds great and might work......if you live on Venus.
 Roger, if you requiring more working time use less hardener. Work with small batches versus one large batch, slow and steady wins the race.
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
49 minutes ago, GrandpaPhil said:
Incredible work!
Did you just layer up the masking tape to make thickness, and then apply the putty?
Yes, GrandpaPhill, that’s right.
  Strips of adhesive tape in 2-3 layers, depending on the required thickness of the putty strip. It must be taken into account that liquid putty has its own amount of shrinkage when drying.
Valeriy,
thanks for sharing your technique in applying the "putty-belts".  I was`nt familiar with that methode before you showed it. You did a super job and its very inspiring and I asume it mut be a nice job for modelers who have experience and a steady hand with "Gips-Stuckarbeiten" structures. I am wondering if it may be possible to combine the way you do it and the way I usually do my hull metal-plating riveting
Nils
Current builds
-Lightship Elbe 1
Completed
11 minutes ago, Mirabell61 said:
Valeriy,
Nils
Nils, I think that it is impossible to show the riveting of sheets using this method. Because after the putty has dried, it must be treated with sandpaper. During this operation, all riveting will be destroyed.
