Hi marsalv,
     It's always good when you make a post.  I look forward to seeing your cannons.  Even though you're new to turning I have faith your guns will be as nice as everything else you've done.  I can't envision you doing anything second rate...... that is unless you build one.  ;-)
Tom
Hello Marsalv,
stunning work! Really nice, it will be one of best Pandora models I have seen.
Alex
Edited by Alex M
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Marsala
I hope you don't mind a bunch of questions so here goes.   Did you etch away material around the monogram so the monogram itself is raised?  Any details you can share on how you made these would be very much appreciated.  Were there any problems with the CA holding tight during or since the blackening process?  What blackening solution do you use?  Sorry for all the questions, but your cannons are extremely fine and I for one would love to know more.
Thanks
Allan
Guest Tim I.
Marsalv,
Your build is a joy to follow. The cannons turned out great!
- Tim
To Allan - the monogram is not my production, these are made by "etching" company (http://www.etchworks.cz/). Normally are parts etched simultaneously from both side, here is etching made only from one side. Before gluing is necessary to roughen both surfaces (eg. tweezers) then glue adheres well (I had to repair two pieces from 20). The solution for blackening - heated solution water and patina for Tiffany technique (ratio 50 : 1) (http://www.vensy.cz/vensy/eshop/12-1-Tiffany-technika-cinovani/31-2-Chemie-pro-cinovani/5/345-Patina-cerna-tiffany-technika)
Carriages assembly.
G'day Marsalv
Your canons are splendid. Was each one done separately or you used a master to copy them. The reason why I asked is that they all seems so uniformed.
Henry Ford will be so proud of your product line! Amazing workmanship mate.
havagooday my friend
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
G'day Marsalv
I know that the canons carriage should be red, but it's a real shame that you have to cover the wonderful raw wood with paint.
Greg
Edited by Greg the peg leg sailor
That gun carriage looks great, and so do your cannons.  You continue to work to a high standard.  It's fun to follow your progress. Thank you Marsalv.
Greetings!  I am new to this forum and have thoroughly enjoyed reading through this thread!  I have the old HMS Pandora kit by Constructo, and immediately found problems with the kit.  Your building log has given me a few ideas for making corrections, particularly in the shape of the bow.  Thank you!
Your model looks outstanding!
wyzwyk, where in CT do you live?  I live just a few miles north of New London.
Bill
Marsalv, how do you get that nice brown color on your cannon hardware? Mike Also I see you have what looks like nuts and bolts being used. Did you make them or is their somewhere I could look for them?
Edited by RedDawg
