Triton by Pete38 - 1:48 - cross-section
yipeeeeee, i got something right
thank you
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Share on other sites
Nice build, lots of good detail. thnx for the pictures.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Link to comment
  • 6 months later...
Thank you for your continued response. I hope to post more updates soon. As so often happens Life and Work gets it the way. Mostly work   :D  I hope to post more  progress soon, so as to let the people know at MSW I have not forgotten by build log. I will continue to follow other and post my meager comments in hope that it may help someone. "even though I am very novice to this" .
PS: Thank you for the comments and like. It means very much to me.
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Link to comment
Your still way ahead of me on this one. We both need to do a little more. Me more than you of course. LOL
Enjoy Life
Later Tim
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Link to comment
Pete, I know all too well about that evil 4 letter word "Work". It gets in my way at times too, but you are doing a great job and rushing it will only lead to problems. I know all too well about that.
Kenny
Current Builds:   HMS Winchelsea   MS US Frigate Confederacy
Link to comment
  • 5 months later...
Pete,
I was just looking at the modelwork you have done so far - very nice and tight!  I'm not able to do it that clean.
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
Link to comment
  • 1 year later...
Work has finally let me get back to my build,  (hopefully it will last).  After cleaning up my workspace, you could not get in the door from the stuff piled in the way, and doing some major cleaning I was able to work on my cross section some.
I finnised the treenailing for what I had installed so far.
Making treenails seems to be a good way to get back into things after being gone so long.
After reviewing by prints I am printing out another set. These have layed around so long and been abused the scale was off and stains all over them.
Will also be starting the deck beams over again. The ones I had cut were in the way when a drink was overturned that know one had told me about.
So here is where I am now. Hope to get more done this week and to start posting progress again
SEE YA LATER
Link to comment
While doing some more clean up in my room I came across some extra deck beams that I had already steamed and bent for the camber on the deck.
They were still in good shape so this saved me some time. I had seen on other builds where the decks ere build piece by piece on the model and other where the
deck was built as a unit off the model then installed.   I will try to build mine on the modle piece by piece. My scale is big enough so it should allow me the room to work.
Installed the firts beam. glued and pined it into place. I used a hot glue gun to temporarly place some blocks on the beam so as I would have a place for my clamps to work.
I then pulled me som dowels to .040 dia to pin them in place on either side.  These went all the way through the beam and in to the side boards. Dry fitted the dowel then
applied glue, worked it in and removed the excess. This should hold them in place varly well.  (I hope)
SEE YA LATER
Link to comment
WOW.....Got to work on my build 2 days in a row.   Not alot done but making headway.
Second beam glue and installed.
Cut 2 spacers so the spacing would be the same for each end glued and clamped.
Going to try for 3 days  :)
SEE YA LATER
Link to comment
Laid out the joints on the beams by clamping the cross member in plase and scribing the edge with a razor knife instead of a pencil for more accurate marking, then used my chisels to remove the material
Even made a short beam for dry fitting the joints, easier to fit between the beams
Edited by Pete38
SEE YA LATER
Link to comment
Thank you Captainscott for those kind words.  Since this is my first build of a model ship like this it is all a big learning curve.
I have managed to get all the large crossbeams installed. Not all were as tight of a joint as I would have like but I am pleased with it
SEE YA LATER
Link to comment
I have started on the next section of these beams. I have forgotten what they are called?
Started with some rough stock and resized it down with my Byrnes saw and Drum sander
Layed out the patten with some 3M contact spray. (Sprayed only the paper patten and let dry for about 45 seconds to a minute) this way it will come off with out to much trouble with little or no residue
then sawed them out with my scroll saw and sanded to the lines.
Now dry fitting them and marking for my cut joints
SEE YA LATER
Link to comment
Finally got back to the shop for a little bit of work on the lower deck.
Decided to notch all the way through the beam for these parts instead of a half lap. To big of a chance for me to break them off
Started by using a hacksaw blade to notch them to almost full depth
Then clamped a backing board so to limit any tear out while using a small chisel to remove most of the material
Then used a file to make any final adjustment for the fit
Glued and installed clamps, waiting for to dry to start other side
Not much by slowly getting there.
SEE YA LATER
Link to comment
Thank you for all the likes....
Just a little more progress on the lower deck...
A couple of bottom shots
I said earlier that I was going to build the decks on the model, but just for some change and learning new ways to challenge myself, the next deck I will be building as a seperate unit off the model then installing it.
Just to see if i can
Edited by Pete38
SEE YA LATER
Link to comment
That deck framing looks great, Pete.   My money is on that you'll do a great job off ship and then installing it.
Link to comment
Thank you for the likes and comments
Mark, thanks for the good words, just hope it all works out
Just a little more progress, started on the lodgeing knees
Slowly but surely getting there
Just a few pics of the minor progress
SEE YA LATER
Link to comment
It's looking really nice. Well done
Regards Christian
Link to comment
Finally got a little bit done on my cross section. Not to much but slowly moving forward.  The rest of the knees done on the lower deck. Now to cut and install all the rest of the cross beams
Hopefully will get some more done here real soon.
SEE YA LATER
Link to comment
Was able to do a small amount this moring after work. Started cutting the smaller beams for the lower deck, I had already sized the stock with my thickness planer to the proper width and height. Use a quick set up to get all 10 pieces correct lenght with no tear out coming out of the saw.\
Slowly but surely getting there  :D
SEE YA LATER
Link to comment
  • 5 weeks later...
Glad that you were able to get something from my log, This is what makes this a great site, everyone sharing everything to help others. From the way you are proceeding so far in your build, the cross  beams witll be no problem. looking forward to more from your build  :)
SEE YA LATER
Link to comment
Pete, When are we going to see more? I have been rubber cementing frame patterns to wood and hope to start cutting them out tomorrow. I will update my log soon. I am really excited about this project and hope I don't neglect my schooner too much. ;)
A question though. How much meat should I leave on the frame parts for fairing? I am working at 1/48th scale. I don't want to leave too much to sand but want enough to fair them well.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Link to comment
