Thanks for the compliments Elmer , and Crackers.
I have been thinking about my build entries and like the style that Ed Tosti uses for his entries so I am going to see how it works from here on the numbers are starting at number nine because I have made 8 posts recently regarding the cabin structure. I will follow a similar pattern for different areas in the future.
Cabin Structure. part 9
After gluing up the sides and beams I noticed that I had not done as good a job making the beams line up on the top profile and this caused a problem with the gluing of the planks. My solution was to sand down the sides and ends to match the middle beams rather than removing the beams. this then ensured that all the curved surfaces were identical.
I made a long sander with some 220 grit and carpet tape strip of oak.
I used the narrow side first then the wide side to finish, i did not see the need to go any finer than the 220 grit because all the surfaces will be covered with glue and other wood.
This allowed me to set some new pine strips that were all the same thickness as the fir planks. These strips were glued to the perimeter and across the separation beam.
The fir planks will be pre drilled for the "screw plugs" (small dowels) before being glued to the top then the dowels and caulking before fitting the companion way slide logs and hatch.
Michael
Michael -
Teriffic woodworking on the cabin.  The huge 'sanding stick' is an elegant solution to the problem.  The joinery is superb.  You should consider submitting some photos to Fine Woodworking for their Reader's Gallery.when you are done.
Thanks for sharing, as always.
Be well
Dan
At first I was like "that caulking looks terrible, look at all the bubbles that pop up" but then on the next picture where it's scraped, I was like O.O it looks AMAZING. I am definitely going that route in my next build
Dan Thanks for the compliment and thought.
Hello Spencer welcome I think you must be referring to one of the earlier posts where i began using the coloured glue as a caulking.
In the deck planking I used a beveled edge and on the cabin top I am going to use a fine rabbet ti give a more consistent result.
Michael
John, I suppose it depends on your point of view.
Michael
Cabin Structure part 10
This series of pictures shows the laying of the long planks and the inserts of the "Screw Plugs"
The first picture shows the planks glued to the beams after they have been drilled with an .048" drill which is close to a 3/8th scale screw plug. a 3/64th would have been more accurate which is .046875" I can live with it.
Close up of the caulking rabbet
The first plugs glued in.
After the glue had set the dowels were cut off with an exacto saw blade proud of the plank surface.
The plug was then pared down with a very sharp chisel.
The rest of the plugs setting up.
The next part will cover the companionway and slide logs.
Michael
Deck Fittings part 1
While waiting for caulking glue to dry, I unraveled some copper ground wire pulled it through the draw plate for the correct diameter to thread 0x80?
I spent some time bending up some deck eye bolts. These are going to receive rings as well. There will be a few sizes from 1 inch to 2 inch OD in scale
When they are all made they will be silver soldered.
Michael
Michael,
I envy you the scale of your boat.  I’ve always wanted to put fasteners on eyebolts under the deck but after the deck is on and the hull is planked there’s no way to get to them.  Yours are looking good.
Bob
Current build:  SS_ Mariefred
Bob, John, Thanks. The thread in masting and rigging about fly tying has really got me thinking.
Michael
Michael, those eye.bolts look great! I hear ya about the fly tying rig--I've been following that thread also, and it's got me thinking as well... Last blocks I did were with a 3rd hand; it worked but definitely would like to find a better way.
Jay
Current Build:  Ariel
You've spoiled us, Michael.   Thread and nuts on the eyebolts, yet.  Looks great!!!!
Jay Mark, Mark, Ron, Crackers, Thanks for your encouraging comments.
Michael
Cabin Structure part 11
Most of the caulking is now completed and scraped. The first picture shows the dark carpenters glue filling the seams befor scraping. A few spots needed to be topped up with more caulking.
The second shows the scraping of the planks and caulking.
Test fitting the slide logs, these are both different heights because of the slope of the larger area I used a couple of sticks to ensure they remained parallel and level to each other
The rear section glued and ready to be scraped, the slide logs are located to measure the forward end panel of the companionway, this will be mahogany.  The aft end will also get mahogany side slots for the drop in boards up to the hatch. after the pine section of the curved plank stop is removed.
Michael
very nice work Michael.........did you consider using rope calking?   the slide rails look awesome.....are you to add stops on them as well?  gonna look sweet when done  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Excellent joinery, as always, Michael.  Impressive work with the eyebolts too, as everyone has said.
What finish are you thinking about for the cabin?
Dan
 Thanks Denis, Greg, John, Dan, and Dan for all the kind remarks.
Dennis No I did not consider rope caulking. I'm not quite sure what you mean by stops on the rails.
Is the glue just tinted carpenter's glue and have you done this before? Just wondering if the glue might shrink a bit over time.
Greg, Yes the caulking is coloured Carpenters clue, placed with a syringe, it is the same glue as the deck caulking and that is now over a year old.
Dan I am thinking that the cabin will get the same teak oil finish, it will allow the wood to breath.
Michael
Cabin Structure part 12
The planking and scraping are finished on the top and now the bottom locating cleats are being glued to the bottom this cabin needs to be removable so that the weights and servo etc can be accessed.
The second picture shows the cleats being glued and also shows the small clamp draw from the card catalog file cabinet that shows up in some of the pictures.
Next is the hatch cover boards and the splines ready to be glued to the cross beams of the hatch.
The last picture shows a small work station that I can move quickly off the wood workbench, it has a cork surface and the pliers are held by some small 1/4 inch ceramic magnets glued into the pine backboard.
Michael
I wished I worked like that.........my table always looks like ground zero! :D :D :D     what I meant Michael,  is are there to be stops for the hatch cover rails......to keep it from sliding too far backwards and forwards.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Fine work, as always.
Bob
