Hey!! Moving up in the world- got a workshop! Although this is one of those clean, fine builds that probably should be left on the kitchen table! Always good to see your awesome build Ron, one of my favorites and a MSW classic!
Thanks Bossman, Martin, John, and Lou, and everyone who hit the "like" button.  I'm glad you guys are still around and watching!
Work continues on the tie-downs for the boat.  I cut a couple of pieces--not sure what you would call these--but they will notch into the wales of the boat and guide the ropes that will tie it down.  After rounding the ends, a shallow groove is filed into each end--
And on the underside, two notches are filed--
They fit across the boat like this==
You can also see the ringbolts placed in the deck that the ends of the ropes will be hooked into--
That's all for now!
Ron
Great to see your progress on this build - always one of my MSW favourites!
hamilton
Is it still called a batten? I thought that was the definition for any kind of wood strips that secure things?  That boat is amazingly detailed....I can’t imagine how small those rudder hinges are, you must still have a steady hand!
Hi Hamilton!  Thanks for checking in.
Lou, batten, yes, that sounds good to me.
So, a small update.  I am not able to spend a lot of time on the model--maybe an hour or so every couple days.
Work continues on the battens and tie-downs.   I cut a couple lengths of rope and gave them a dipping to darken the thread a little--
Then draw across some beeswax--
After making a simulated spliced loop in one end, I test fit the rope on the batten to get an approximate length for the loop at the other end of the rope--
Once I had the two loops, I connected them with a bit of wire to test the length.   I'll finish the one on the right before going any farther with the second one.  Need to make sure this will work!
Testing the fit again on the model.  I put a small dab of glue just on the rope where it turns down off the batten.  Hopefully it will hold it's shape after I take it back off the model to work on lashing the two loops together.   I'm not sure yet whether I'll finish that lashing completely off the model, or try to tighten it on the model--
Ron
Edited by rlb
How much can I bore you with incremental progress!?
Here is the tie-down, ready for further work--
One end is "seized" (I don't know the proper term)--
And back in place, rope is (at the other end) thread through the eye splices--
And the wire cut--
Just to end with something interesting, while glue on the knots dries, a shot looking down the deck--
Ron
Nothing boring here, Ron.  It's always good to see the progress of a craftsman.
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks, Martin.  Here's some more progress!
I got lucky somehow with the first tie-down.  The second one took a few tries.  The first test fitting showed it was too short.  I considered lashing it anyway, but my conscience wouldn't let me--
So I cut another piece, a little longer, and threaded the hooks onto it--
I seized the port side hook--
And test fit it.  Too long now--
I trimmed a few millimeters off each end, and reformed the eye splices.  You can see the dab of glue that forms the splice--
That one was also just a smidge too long--
I trimmed again, formed another eye splice, and finally it was just right, so I seized near the hook, and lashed the eye splices together--
By the way I found my missing oar!!  Here are the five lashed together--
But to my dismay, I could not slide them under the battens!!  The battens and tie downs can't be removed now without messing with the hooks (or cutting the lashings and seizing's), and I don't want to do that--
So close--
I discovered that one side of the seat was not glued tight, and it lifted to let me push the oars under--
And I was able to push the front batten forward (I had put just a touch of glue to secure it, but was able to gently break it free) just enough to slide the delicate oar handles under it--
The work on the tie downs was tedious, and I took shortcuts with the splices and lashings.  I need to improve my rope skills, but for a start, there's the boat, fastened nice and snug!!   --
Ron
Edited by rlb
Man, that is some beautiful, precise and clean work! A joy to behold!
hamilton
Thanks much hamilton!
Now that the boat is done (as much as I am going to do), I'm going to work on the masts.
Here are my calculations of the dimensions for the two masts, using Lee's book for guidance--
I had started the masts a while ago (years now!), and was unsuccessful.  The top piece was my attempt at the main mast which was too short, too thin, and I didn't like the way the hounds turned out.  The third one down was going to be my foremast, but it is too short.  That roughly cut piece in the middle of the group of three will be my new foremast.  The lowest piece is the second try at the main mast, which is (so far) on track to turn out okay.  You can see on the printed drawing where I have adjusted the heel length to account for the shallower draft of my lake vs. ocean brig--
The piece that is to become the fore mast was cut very ragged, from thick stock.  It needs a ton of sanding to get it smooth, square and down to size--
752813436_Oneida01-28-2020CSandingMastMotion.JPG.0532e2bf8c5498c8637d12eb92835db8.JPG
It's getting there, the marks indicate that I don't initially sand that side--
While I work on the masts, I am also going to work on the head rails, and in preparation I'm bending some stock.  Sometimes you just have to look around the house for the right radius--
746959231_Oneida01-28-2020EBendingHeadRailStock.JPG.27f86ac60d59426af2107cef228fe81b.JPG
Ron
Edited by rlb
Ron, beautiful Brig and workmanship. I’ll follow along if you don’t mind 😀
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Welcome, Dowmer; and thanks NateB!
The masts have been roughed out and marked for the next steps--
The first pieces for the bow work are ready to be subjected to trial and error.  The pear piece is for the hawse hole bolsters, and the Castello Boxwood is for part of the headrails--
437195805_Oneida01-29-2020BHeadRailBeginning.JPG.67704d25d817d15f19e14c65179cd2e2.JPG
The hawse hole bolsters will need to be ebonized.  It's one of my favorite processes on the model--it reminds me of developing prints in the darkroom in the old days--magical.  But my magic solution has dried out and needs to be rejuvenated.  Pouring vinegar into a small jar of rusted nails--
211618405_Oneida01-29-2020CBlackeningRejuvination.JPG.f177e14aa64ee60db860ac9d66367f7b.JPG
These were steeped in vinegar last year (hence the black crustiness), but they've dried out over the past year and need to be re-steeped--
What fun.
Ron
Thanks for all the likes!
Here are the masts with centerlines marked.  Hopefully that will help with the tapering.  There also are my curved bolster and headrail pieces--
I cut the bolster piece down to two pieces of approximate length, and while holding one up to the bow, put a pencil lead through the holes from the inboard side to mark their locations on the bolster--
Then pilot holes were drilled.  They need to be at a downward and forward angle relative to the bolster piece.  The holes will be filed out larger, while checking that they match up with what's on the model--
The aft end needs to be shaped--108909748_Oneida02-01-2020DEndCarved1.JPG.be369c18d62ca45f86a8e4df4892f5f2.JPG
And given a stepped end.  I'm not sure if the actual one was made up of two separate layers of wood, or simply carved as I am doing--
Seeing how it looks in place--
Either I didn't capture the right profile, or it just doesn't look good to me.  I changed it to a simple curve, and you can see I've enlarged the hawse holes a bit--
The wales needed to be roughened up to make sure glue will bond--
And they are now glued in place.  (Optical illusion-the stepped ends disappeared!  They are there, but the at this angle they don't show.  I actually ran back to the model to make sure after I looked at this photo!)  Final shaping of the holes will happen after these have set--
Meanwhile the headrail piece has been cut in half, and those pieces are sawed lengthwise--
488890011_Oneida02-01-2020JSplittingHeadrailPieces.JPG.522109043855300b321f77d807752392.JPG
I have thinner flat stock I could have used, but it hadn't sunk in how thin these pieces really needed to be, I just grabbed a piece from my odds and ends bin that looked about right.  Actually though, it was easier to bend the square shape than it would have a flatter one on it's thin edge anyway.  They are a little rough--
862418706_Oneida02-01-2020KRoughSplitHeadrailPieces.JPG.6ffdb5bc684298ec83e5787dc86676ae.JPG
But after sanding a little, I think they will work--
1513275278_Oneida02-01-2020LSandedSplitHeadrailPieces.JPG.570bfd892d25abb255deba5b617dab64.JPG
Ron
Edited by rlb
Ron -- I really like the fact that you're relying on hand tools so much.  The quietness of working wood by hand has always been one of the key attractions for me.  And I can only admire your keen eye in spotting the table edge as the right curve -- marvelous!
I believe I spotted the handle of a chisel in one photo, and a Lee Valley chisel in another, so I wonder why you're not using those to make the initial rounding and tapering shapes for your masts -- shavings are a lot easier to clean up than sawdust.
I can't even begin to list the difficulties my own hawse holes gave me!!!
Cheers,
Martin
Thanks Ed.  I've been meaning for so long to get back to Oneida.  I hope I can sustain the motivation this time.  My course would be called "How to Build a Model Ship-A Lesson in Perseverance, Patience, and Eyesight Magnification."
Martin-I think, if you are not in a hurry, hand tools are all you need.  I jones for a Byrnes saw, a lathe, or even a motorized sander, but my hands have gotten me this far, I will probably continue that way, at least for this model.  (My Proxxon rotary tool has been extremely useful for many things--so I could never say this model was completely hand done.)  If there are others models in the future maybe I will invest in more advanced power techniques.  As far as sanding the masts, I have gotten very comfortable with sanding, especially using sandpaper taped flat on the table .  Every piece of wood on the model has been sanded in some fashion.  A miniature plane would probably work very well for tapering the masts (in fact I have one--though it is not of high quality), but I trust myself most with the sandpaper.
Ron
Edited by rlb
A backward step to report:
I discovered that my slot in the stem for the gammoning is too high.  The upper cheek (I had been calling them headrails in error, but the cheek pieces are the ones shown in the last couple posts that I was bending, cutting, etc.) will at least partially block the gammoning slot.  I might have tried cutting a new slot, and covering or filling the bad one, but I opted remove the stem piece and make a new one.  I was never happy with my gammoning slot anyway--it was a little too elliptical, and not tilted quite right.  This will be the second time I've had to remove this piece in situ.
After a few days of repeatedly scoring the joint with a knife, and soaking with isopropyl alcohol--
The piece finally broke free--
Ron
Edited by rlb
Work continues on the replacement head piece, and the cheeks.
On the left is the original lazer cut piece.  In the middle is the one I just removed, due to the bad gammoning slot position.  On the right is the new one, basically shaped.  I refined the cutout for the decorative piece that takes the place of a figurehead.  It better matches the original shape, and the shape shown on my plans.  I will wait before drilling the bowsprit stay holes and gammoning slot--
I tacked it on with just the barest bit of glue.  But it will stay in place while I work the cheeks and headrails out, then I'll cut the gammoning slot, glue it on to the stem, and do some final shaping after it is permanently attached.  Below are three of the cheek blanks.  They won't do.  They need to extend farther up the stem before joining the piece that makes the final decorative curve.  The joint will be hidden under the gammoning, not where I was thinking it could be, at the join of the stem and hull--
I drew a card paper template to get the rough shape--
And cut four blanks out.  They will need a lot of shaping--
All to be done with sandpaper and files--
One of many test fittings--
Here one just about finished.  It's hard to tell, but the short leg has a slight up curve, that's why the blanks need to be cut from thicker stock and sanded down.  And the long leg needs to be more of a slight trapezoid in section rather than square.  Like many others on the ship, it's quite a complex piece (assuming I have made it somewhat close to how it should be!)--
A molding profile is scraped into the piece with a razor blade.  The very left end, on the corner of the blade, is the profile I used, running it on one side of the piece, then the other--
519599183_Oneida02-08-2020HRazorBladeMolding.JPG.bc19297ea55821f927581d40d913c79a.JPG
Test fitting.  It is done enough to move on to the others.  Some adjustments may still need to be made, but I hope I'm on the right track this time--
180435864_Oneida02-08-2020IOneCheekDoneforNow.JPG.fe21544607ec4c6935fdd5fe3db8e98d.JPG
Ron
Edited by rlb
Thanks Mike!
A small update:
For some relief during during fashioning the new stem piece and cheeks I worked on tapering the masts and bowsprit (and vice versa from the tedium of sanding the masts).  They now have their basic taper done.  There is about an extra 100th of an inch everywhere to allow for final sanding.  Next will be chamfering the corners to make the octagonal sections, and begin the rounded ones.  Note the bowsprit taper is not symmetrical.  The top edge (you can just make out my penciled note "top") is straight, and the bottom and sides are tapered--
1585187241_Oneida02-08-2020A1InitialMastTapering.jpg.5f0cc9cba623a81cf02a2b3a43be7ffa.jpg
Ron
Work continues on the masts and bowsprit
Here is the Main Mast sanded, with the heel tenon cut in.  I also have the second of the cheek pieces mostly sanded down--
Here is the Fore Mast partly done.  The tape marks the areas that are not to be rounded, and there is a little more work done on the remaining cheek pieces.  A center line is drawn on the tapered bowsprit before sanding it to an octagon--
245969131_Oneida02-15-2020BForeMastRoundedBowspritcenterlinemarked.JPG.65646a92a3beb4083a5c8aa5c536fc74.JPG
The tenon being cut in on the Fore Mast--
1786099799_Oneida02-15-2020CCuttingForemastTenon.JPG.d40c3adaaba8098d0c709f49e25fc91a.JPG
While sanding the bowsprit from it's basic tapered square form, I made the mistake of giving it an octagonal section for its whole length.  Unfortunately this meant cutting another blank and starting over.  Here I am starting to sand the octagonal section into the new one, with tape at the fore and aft ends marking the areas to leave square--
1428111987_Oneida02-15-2020DSandingOctagonalBowspritSection.JPG.7a51edc2628dd1cede626befcc685b40.JPG
Then, only the center portion of the bowsprit (where I am holding it) needs to be rounded.  More tape to mark the rounding limitations.  Note that at the fore end (to the left), the rounding is not symmetrical, and the top stops before the bottom--
 1619544049_Oneida02-15-2020EMarkingBowsprintRoundSection.JPG.e7a1ce3edfdfa638dc10df3b0a597158.JPG
Here is the bowsprit roughed out, the top is facing the window--
The new one next to the aborted one--
Here are the two masts, the good and bad bowsprits, present state of the cheeks, and the new stem piece (which fell off as I was working)--
1638994988_Oneida02-15-2020HMastsandBowsprits.JPG.0446bd0bf29dba5d33e06758ce57fff5.JPG
The stem piece fell off (you remember I barely tacked it on) as I was filing out the bowsprit opening and test fitting the bowsprit many times--
603104461_Oneida02-15-2020H1FilingBowspritOpening.JPG.01b9cfe66dcecdcee94e82bdbd2688ae.JPG
After much filing, the bowsprit finally fit through, and I marked it for a very shallow tenon to be cut--
536534606_Oneida02-15-2020IMarkingBowspritTenon.JPG.d87bfa135688c41872b6362a2b5fa794.JPG
With my big hand out of the way here it is test fit in place (tenon not cut yet, nor bowsprit seat finished)--
Ron
Edited by rlb
Ron, is it your intention to fully rig it, I know way back when you indicated that lack of space might prevent you from rigging it but maybe with the new home you have more room would really like to see her fully rigged perhaps a new course "The fully rigged model ship"
Best,
Ed
Ed,
I'm not positive yet, but I do think I will fully rig the ship (without sails).   As you remembered, my old house would not have had room, but I have one or two places in my new home where I think a fully rigged Oneida would fit.  Oh, others have taught that course far better than I ever could, but I'll give you a front seat to my attempt.
Ron
Beautiful work. I built this without masts and rigging an look forward to seeing your continuing build
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
Slow progress on a number of things:
I marked the stem piece for the gammoning slot, drilled two holes, and then threaded it onto the jeweler's saw to cut the slot--
After cutting the slot, I gradually cut it out with micro chisels and files, then glued it onto the stem.   I'll drill the bowsprit stay holes in place, I'm not sure exactly how they are going to line up yet--
I cut a rough blank for the billet figurehead piece.  This will be a new experience, carving it--
256723132_Oneida02-17-2020CBilletFigureheadBlank.JPG.9b7dc2a9f598d9007b58d49eb2d5e8f9.JPG
And I'm roughing out one of the headrails.  Once I have the shape fine tuned a little, I'll cut the other one--
Here's the bowsprit fit in place, with some starting work on the bowsprit cap--
The cheeks are getting there.  The two starboard side pieces are done, and the port side pieces still need some thinning down.
Ron
Edited by rlb
The hawse hole piece is now blackened, using the 'ebonizing' technique.
First mask off around the piece--
Then paint it with the Quebracho Bark Extract--
Followed (while it's still wet) by the Iron/Vinegar liquid--
In a few seconds it's quite black--
Masking removed--
1115068753_Oneida02-19-2020EHawseMaskingRemoved.JPG.4b9ca00a52c3616575ed73a2e654a9ab.JPG
It will get some Tung Oil finish which will warm it up a little, and it'll match the wale and bulkhead cap, which were blackened the same way.
This is my model for the billet figurehead, from the USS Constitution--
570156313_Oneida02-19-2020GConstitutionBillethead.JPG.3b177d3113a3f433765ae8671272b66e.JPG
I'll simplify it quite a bit.  Here's my rough sketch.  I'm not quite happy with it, so I'll sand this off and try again--
1898328294_Oneida02-19-2020FRoughBilletheadDrawn.JPG.86cbdd8a926570f4e3f4bc421ff1dbe1.JPG
Ron
Edited by rlb
Looking good Ron, I’m always glad to see your updates, I know I’m going to be impressed or inspired or in awe.... I think your log is just so indicative of perseverance and commitment, I’ve seen your tenacity and the results speak for themselves.   Nice work on that gammoning slot, see now I would convince myself I need a mill to do that well.... those head rails are a 3D challenge too, and have the potential for multiple iterations....
Thanks Lou, and all who have liked.   Yes this area of the ship is a real challenge to me and one I can't really totally visualize yet, but it's only wood and I can cut a new piece as many times as I need to!
I have been working on the billethead.  I redrew it with a smaller star and some other refinements (not sure how refined they are, but they're the best I can manage!), and carved it out--
I was happy with the star, but the lower center part just kind of got mangled.  It's also overall too big.   I need to trim the whole piece down, which means sanding this carving off and trying again.  Fortunately the piece is also too thick at this point, so I have a couple tries at it before I need to start with a new piece.
Here it is closer to the right size, with the design drawn on, with an ever smaller star.  There are still some gouges from the previous attempt, but I don't think they will be a problem.  It's still a tad too big, but I don't think I can do smaller!--
And carved out.  I was able work in a couple of the little "barbs" as the scroll winds around the star, though the star itself is not quite as nice as the bigger one from the previous attempt--
The small "tang" at the bottom helped me hold the piece as I was carving--
But that comes off now--
Here is the piece next to the plans.  You can see mine is bigger, and a different design.  Maybe I should have tried to match it closer, but I'm not really sure what I would carve for those squiggles trailing off the scroll!  It also seems a little blank on the forward area.  (Sorry Mr. Chapelle!)  My top cheek molding will transition into the scroll that wraps around the star, instead of stopping separately behind, as shown on the plans.  I think this will resolve my oversize issue, as my height is close, but not the width--
Here is the piece dry fit on the stem--
There is still some carving work to do, and there is a notch in the back (you can just see it the previous photo where I am holding it next to the plan) that needs to be deeper so the piece slides farther back on the stem.  The curl at the bottom needs to line up with the front of the stem.
Ron
Edited by rlb
Ron, well done. I think you did an admirable job, considering the size of the work.
