HMS Victory by gil middleton - FINISHED - Caldercraft - 1:72
Gil,
You are absolutely correct. We are our worst critics.
You have no choice but to make it right for yourself because of all people you know it is there!
I for one greatly appreciate your expertise and attention to details.
Me bored?  Not one iota!
Thank you
Alan
Alan O'Neill
Link to comment
Share on other sites
Gil - I can see that it makes a big difference. Very nice color choice!
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Gil,
Well worth the effort. You'll be able to sleep tonight. Looks great, big difference.
Happy modeling,
Len
Happy modeling,
Len
Current build: HMS Bellerophon semi-scratch from plans of Victory Models HMS Vanguard
Drydock:  MS Constitution
Completed builds: MS AVS, scratch built Syren, Victory models HMS Fly
Link to comment
Link to comment
Gil,
I can't believe you just did that!!! (says he who pulled his whole stern off ;) )
That must have been a right bi#%£ of a job, but the difference is simply WOW!
My hat is off to you Sir (again).
And no, we never get bored with your log Gil. :)
Link to comment
Gil,
I've been following, mostly silently as this ship is so above my artistic station, that being said the "fix" looks so much better. Now it won't irritate you any more. That peace of mind also has value (:-)
Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Link to comment
Thanks you all for your support, John, Michael, Alan, dragzz, Floyd Bob and Dave B (D Borgens). And not one of you said "You're crazy."
Grant, I suspect you had the same feelings when you removed the stern. A couple days into the process, "What on earth was I thinking of?"  It helped that I had sanded and stained most blocks with water based English Oak (Minwax) so that the brown oak wash didn't adversely affect the blocks.  And Len, I do sleep at night, perhaps not so much that she looks better, but that I didn't destroy it.  I'm pleased with the result and glad I went to the trouble. And I've taken Popeye's thoughts to heart, staining the lines going forward.
David (dgbot), I've used Minwax stains, but the problem is that lines or rope coils with C/A on them, will not take up stain producing a very mottled appearance.  A paint wash covers treated or untreated line.  Working in our den, I use only water based paints or stains.  I've found that staining lines with English Oak (Minwax; some prefer Fruitwood)) produces a very similar result to Brown Oak Detail Wash (equal parts Brown Oak Wash (Testors), Dust (Polyscale) and Acrylic thinner).  We simply have two options for treating lines, staining and a paint wash to get the consistent results I was looking for.
Cheers, Gil
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
Link to comment
As my Grandfather once said " There are many ways to skin a cat."   You should always choose the one that is easiest for you.
David B
Link to comment
Gil,
Have a third choice:  RIT dye
I was reading the below attached link of a thread on MSW from Bob that gives wonderful information on dyeing lines.  I have tried using only the dark brown liquid RIT (also comes in powder which needs to be mixed)  on DMC cotton line  as an experiment (2 Teaspoons to 16 oz water) with satisfied results.  RIT instructions say to add salt for cotton.  I've tried with and without which gave same results.  There's a link on that thread that shows where his original info came from (gives what to use for standing and running rigging color).  It also said to use Kodak wetting agent, but I also found isn't needed for the thread I used.  Probably needed if line is treated or made from other material (only a guess by me).  I found all six colors recommended by Bob at JoAnn Fabrics ($4 a bottle).  Amazon and other web sites sell it.  After my experiment I sent Bob a PM stating my results, he did mention he has only used the powder where I used the premixed liquid.  I just wrapped 24 ft thread around my palm and dropped in a jar of the hot water dye I prepared for about 1/2 hour.  When I need to make more just heat the jar in microwave and drop in another section of thread.  Very easy and little cleanup.
I have used minwax Jacobean and General Finishers Expresso stains before which gives the desired color, but these do harden the line where the dye keeps the line texture the same.
Hope you didn't mind me jumping in on your thread, but think you and others would appreciate this information.
http://modelshipworld.com/index.php?/topic/5396-domanoff-workshop-planetary-ropewalk/
Happy modeling,
Len
Link to comment
Very nicely done, Gil.   The difference is eye-catching to say the least.
Link to comment
I was going to go along the same line....with the Rit dyes,  but I was told that over time,  it would deteriorate the thread,  and cause premature breakage.   that's when I put it back on the shelf and went with the India Ink......I was doing standing rigging thread at the time.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Len, Many thanks for adding the link to Bob Wescott's notes on RIT dyes.  A great addition to methods to achieve a realistic appearance of ship's lines.  I've added it to my "favorites" for future use.  Stains do change the feel of the line, although, once the line is set, there is probably little difference.  As far along as I am, I'll likely continue with the simplest course.  Popeye's comments raises visions of peoples' clothing falling off as threads deteriorate, although Judy assures me that RIT dyes have been used for decades.  Forgive me Popeye but I couldn't resist.
Thanks Mark.  The white rigging had been bothering me for a long time.
Cheers, Gil
Link to comment
That was worth it :-)
Cheers, Daniel
Finest etch parts for HMS Victory 1:100 (Heller Kit) and other useful bits.
Link to comment
Gil,
Just an FYI...  Hahn also used RIT to dye wood. He wanted a "worn" blue so dyed the wood and then lightly sanded it.
Link to comment
With so little rigging to go (Braces and ropework at the bitts, kevels and pin rails), I elected to use what is perhaps the simplest method of staining the rigging.  Roughly measuring the thread for a particular line (in this case the driver boom lift tackle) and using a reverse hook, the line was pulled through the stain (Water based English Oak), allowed a minute or two to penetrate, then gently wiped with paper towel and hung to dry.
post-68-0-17599900-1393024074_thumb.jpgpost-68-0-96560200-1393024113_thumb.jpgpost-68-0-19899300-1393024148_thumb.jpgpost-68-0-17163800-1393024178_thumb.jpg
Throat halyard for the driver gaff ready to rig.
Link to comment
DRIVER BOOM
Driver boom and gaff after sanding to shape.
Boom tapered, saddle fitted and sanded.
"Iron bands" applied. (Styrene strips)
Parral around mizzen mast.
Sheet tackle rigged.
Foot ropes, lifts and guys (vangs) attached at end of boom.
Link to comment
Gil,
Great idea in staining your rigging thread! An sollution for many of us with less than perfect rigging thread.
I also like your fine detailing on the spars. Insprational!
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Link to comment
Continuing  with the Driver boom.
Lift blocks
Lift tackle
Driver boom lift
Rigging the base for the lift tackle with a tail attached to the **** end of the block.
post-68-0-03331400-1393025409_thumb.jpgpost-68-0-34569500-1393025430_thumb.jpgpost-68-0-15101800-1393025463_thumb.jpg
Attached to the channel
Link to comment
And finishing the driver boom.
Rigging the guy blocks
Parral.  Gloss removed with clear flat acrylc.
Fully rigged driver boom.  The ship has gained about 6 1/2" to reach 55" or about 140 cm.  The admiral asks "Where do you plan to dock this ship?"  In the living room????
Next, The driver gaff.
Edited by gil middleton
Link to comment
outstanding work Gil   museums and art galleries are hungry for work like this!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I have room Gil  :)
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Link to comment
LOL im taking notes to avoid the staining issues, thankyou yet again for all the hard work you are putting into this build and sharing it with us
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Peter,
We are looking forward to a five month cruise to Alaska.  Early May in Victoria, mid May in Bella Bella / Shearwater.  When do you find out your schedule?  I've not been to the Old Bella Bella Coast Guard Station.
Popeye, Our home is a museum featuring 3 old ships and one old modeler.
Thanks Edwin and Kevin, but Augie and David, be careful what you wish for.  You'd get to pay the thousands in shipping costs.
Cheers, Gil
Link to comment
On with the Driver Gaff.  Preparing to rig the gaff.
post-68-0-18251900-1393112089_thumb.jpgpost-68-0-93464000-1393112121_thumb.jpgpost-68-0-99941000-1393112309_thumb.jpg
Driver boom and gaff rigged.
Topgallant and topmast yard braces to blocks on driver gaff. Driver gaff vangs (or guys) with tackle leading to the taffrail.
post-68-0-84558200-1393112610_thumb.jpgpost-68-0-49262800-1393112636_thumb.jpgpost-68-0-88580200-1393112663_thumb.jpg
Cont......in next post.
Link to comment
Peak halyard to poop deck, port.  Throat halyard similar to starboard.
Looking aft from starboard.
End of driver gaff
Now on with the fun stuff.  Gil
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
