Posts posted by James H
She really is just beautiful. Skills I could only dream of emulating.
- hollowneck, robert952, Dave_E and 4 others
- 7
What a great final product to have for the build!
You really should consider doing an Indy in that format. Maybe at port anchor and being loaded with provisions etc? I only suggest it as I know it'd look great and I wouldn't be able to pull it off myself 🤣
- hollowneck, Paul Le Wol, mtaylor and 2 others
- 5
That build looks real sweet!
I hope you can share more with us, perhaps in a build log too?
- Keith Black, mtaylor, Dave_E and 1 other
- 4
Looking real nice.
You'll notice how things will become much more solid with the frames now.
- mtaylor, Kevin and Old Collingwood
- 3
....more. As I've done quite a lot, I've very much abridged the number of photos for each stage.
Binnacle. This is smaller than those I've built for British vessels but identical in construction. The chimney is turned brass as per Indy, Sphinx etc.
A single ladder is now built for the deck hatch opening.
Grecian will come with more armament than you'll actually need. This means that you will be able to choose the gun combination that you prefer, and we will supply options for you. These photos show the carronades and two sizes of cannon. All this before I actually plank the hull!
Until next time.
....continued.
Like Indy, the hull can now be safely turned over as all parts are locked in place with the pegs, and also with the deck, in this case. Dilute glue is now painted into all the various joints and seams.
Filler parts are added to both bow and stern so the planking as something to adhere to.
Here you see the stern superstructures now being built up. One of these will be the WC and the other is presumably sone sort of locker.
On with the coamings. These are nice and easy to build up. Once glued, the lasered edges are removed and the sides evened up. The grates are left out until the coamings are fitted to the deck. This simply aids correct positioning on the deck.
Capstan. This is identical in construction to those on just about every other VM kit. They are so easy to build up and the fittings precise.
Skylight. Although different in size to the one Iast added to Indy, the appearance is very similar, and the construction also nice and simple. PE parts are included for the hinges and window frames. The modeller can use a bit of acetate, if they wish, to glaze the panes from the underside.
- thibaultron, Prowler901, mtaylor and 16 others
- 18
- 1
Update No.2. This will be in 3 parts as it's almost 40 photos.
The hull is currently in a state of being faired, so I'll show the hull up to just before then, plus all the other things I've built up.
Pre-bevelling was done on the stern section that I built in the last update, and this was then dry slotted into the bulkhead slot on keel. This can be finalised when the hull is being faired.
Longitudinal bracing parts are now slotted across all of the bulkheads, except for #1. Again, this is dry fitted. No glue needed yet. These parts will further solidify the bulkhead positions.
The previous parts incorporated a section of the poop superstructures, and the next two parts will add further elements of this. All will become clearer.
At the bow, we have more parts that slot into bulkheads, creating the sides of the bowsprit entry point, and also to add fairing and planking.
Beams are now fitted across the open bulkheads. There are three different types of beam, relating to the position and camber.
A 0.8mm ply deck is now fitted. This is thin enough to be slightly bent and pushed into position into the slots at the bottom of each bulkhead ear. This usually gives a nice, satisfying click when finally located.
She builds up fairly quick at this stage and seems to get more imposing by the hour.
26 minutes ago, glbarlow said:
Our flag wouldn’t have the red sea down the sides, so hopefully the actual installation will provide for removing those. With each new state came a new star, so if the time period is before the 16th state in 1796 the number of stares is correct. The flag had 15 stripes only between 1794 and 1818 then went back to 13, making it unique in our history.
As the flag needs trimming from its sheet, just trim that red line off.
- mtaylor, hollowneck, Canute and 1 other
- 4
Just remember to taper those planks as you fit them. Take a few of them and soak them, then add a gentle curl into them also. That will help get those first ones installed a little easier if you're not used to working on them.
- aydingocer, BobG and mtaylor
- 3
...continued
Those doublers are now pinned into place with a series of plugs. These are glued into position.
Before the sub decks can be fitted, the need bolstering a little from below towards the stern. These two parts are now fitted which create a firm base for the sub decks. Those sub decks are now DRY FITTED into place.
Now, we have a lot of unglued joints that could come apart, so this is stopped by gluing a series of plugs through the holes in the bulkheads, holding the sub decks firmly in position, and all the other parts in a perfect position.
And the last in this update shows the final bulkhead, with the various forms glued into place prior to being shaped and secured to hull.
....until next time.
On 2/23/2023 at 7:04 PM, ccoyle said:
Don't forget to include a bottle of Grecian Formula!
You've got to have hair to worry about that!
Ok, an update. If you've followed other build logs or downloaded previous instructions, you'll see much that's familiar at this stage. There has been a developmental curve that can be traced through the various kits as they've been released, and you'll always find those advances in subsequent releases. I see a lot in this that have come from the Duchess kit, through Sphnx, Indy, and even the more humble fishers. Here, we start with the obligatory build cradle. The stern of Grecian sits far deeper in the water than the bow, so the cradle deals with that, and you'll see a little pip in one keel slot. The sits in an opening in the hull, angling the hull properly so the waterline can accurately be marked and the model displayed at the correct attitude.
Here is the keel, designed to accommodate SEVENTEEN bulkheads! This will be a sturdy model. The first slot is ID'd with '1' to correspond with the first numbered bulkhead. From there, just work backwards. At this stage, NO glue is to be used.
Bulkhead #9 is made from two identical parts, glued back to back. When made, the bulkhead is fitted to the keel, again with no glue.
The last bulkheads are fitted, except for the rearmost one. No glue!
All those bulkheads, for the moment, can move about a little. A lot of that is now removed by sliding full length doublers down each side of the keel, directly up against it. These are in two parts per side.
- Prowler901, Oldsalt1950, KentM and 15 others
- 18
17 minutes ago, ccoyle said:
No rest for the weary, eh?
I've had 10 days on Hogwarts Legacy though 🤣
- Prowler901, thibaultron, mtaylor and 4 others
- 4
- 3
Ok folks,
This kit will be hitting the doormat tomorrow so I'll be starting work tomorrow afternoon. Again, this is a prototype for the kit, and I'll be doing the kit manual pics and text as I go.
Some history, abridged from Wiki
Grecian was an American schooner launched in 1812. During the War of 1812 she received a letter of marque. The Royal Navy captured her on 5 February 1814 and took her into service as HMS Grecian. She was sold in 1822. In 1823 she became a merchantman. In 1824 the Chilean Navy captured her, but she escaped, and thereafter may have served for a time as a Spanish privateer. After the end of the Peruvian War of Independence she apparently returned to more conventional pursuits and was probably lost in 1829 though she was still listed in 1830 as sailing between London and Lima.She had a long, curving stem, and a shallow, less convex bow. Grecian's first captain was James Phillips, and under him she had made one voyage to France. She received letter of marque No. 944 in December 1813, under Captain Knapp. She had not captured anything before the boats of HMS Jaseur cut her out under the guns of a battery field pieces on East River, in Chesapeake Bay on 2 May 1814. The British cutting out party under Lieutenant West, first lieutenant of Jaseur, rowed up silently in the night, drove Knapp and the seven members of the crew on watch below deck, fastened the hatches, cut her cables, and sailed off. The British commissioned her as HMS Grecian under the command of Lieutenant Henry Jewry. After the end of the Napoleonic Wars, Grecian was deployed on anti-smuggling duties in the Channel, and captured a good number of vessels, including Betsey, Nancy, and Market Maid. On 18 August 1818 Lieutenant Nathaniel Martin was appointed captain of Grecian. Between 30 August 1819 and 20 January 1820, Grecian made several small captures. Grecian made further sundry small captures on 16 May 1820, 27 March 1821, 20 April, 6 May, and 2 August.
She was paid off in 1821. The Admiralty put Grecian up for sale in April 1822 at Portsmouth. She was sold to Joshua Crystall for £510 on 18 April 1822.
Initial prototype photos
These are the builds Chris did to test the initial fit of parts prior. Here is where initial changes take place before sending out the materials to me. There may still be changes made as I build, and I will then pass those onto Chris, but the hull of this is quite different to other gunned vessels, so the usual trials and tribulations will be much less.More stuff when the parts land here...
- hollowneck, Kenneth Powell, ccoyle and 24 others
- 24
- 3
A little history (edited from wiki!)
HMS Indefatigable was one of the Ardent-class 64-gun third-rate ships-of-the-line designed by Sir Thomas Slade in 1761 for the Royal Navy. She was built as a ship-of-the-line, but most of her active service took place after her conversion to a 44-gun razee frigate. She had a long career under several distinguished commanders, serving throughout the French Revolutionary Wars and the Napoleonic Wars. She took some 27 prizes, alone or in company, and the Admiralty authorised the issue of four clasps to the Naval General Service Medal in 1847 to any surviving members of her crews from the respective actions.
Indefatigable was ordered on 3 August 1780 (long after Slade's death), and her keel was laid down in May 1781 at the Bucklers Hard shipyard in Hampshire owned by Henry Adams. She was launched in early July 178, and completed from 11 July to 13 September of that year at Portsmouth Dockyard as a 64-gun two-decked third rate for the Royal Navy. She had cost £25,210 4s 5d to build; her total initial cost including fitting out and coppering was £36,154 18s 7d (around £6.6m in today's money). By that time, she was already outmoded for the role of a ship of the line as the French only built the more powerful 74-gun ships, and she was never commissioned in that role.
She was broken up in 1816.
The kit
This is quite literally hot off the press with regards to what you see here. Indefatigable is being represented in this new kit as the razée, and quite rightly so. I do have a lot of affection for the stuff built at Bucklers Hard, having visited there a couple of times myself. It's a beautifully tranquil place in England's New Forest, which really does betray the hive of activity it used to be. It even has the original shipwrights houses and the pub there, as part of the tour. Just to think, Indefatigable was definitely built in one of these two slips, as was Agamemnon etc. I took these photos a couple of years ago.This is very stuff for Indefatigable, as all I currently have are the cannon, carronades, and also the cutter. It will also become very obvious that when building these models, I never do anything in chronological order as seen in the manual. I work on whatever Chris has completed and sends over to me, with other work infilling between main tasks. I try to waste as little time as possible in order to keep to fairly tight release schedules. For the first time you'll see me work on stuff like this before the big hitters are sent to me. Even then, I will feed back with my findings and things will possibly be changed to reflect my own build.
Not too much to see at the moment, and work won't start proper for a week or so, so keep checking in to see if things have progressed. Here's the two sheets of 2mm pear which contain the gun carts...
I also have three bags of guns. These are:
- 12-pound long
- 24-pound long
- 42-pound carronades
I do need to wash these guns in some isopropyl, especially the carronades as the initial washing left then with tissue debris on them. Also, the carronade carriages will also have 3d-printed wheels!
Indefatigable will have many of the design traits of Sphinx, but this time incorporate more traditional planking around the upper bulwarks and gun ports etc. Indy will also feature a traditionally planked deck too.
Here are the parts for the cutter:
Chris might want to chime in here with other notes on the design too.
3 hours ago, Mike_H said:
Just catching up after a month of riding my bike in antipodean sunshine. She looks magnificent! Really striking how the final addition of deck furniture gives a sense of scale - she’s a big girl. And also how it shouts out about the quality of the model (and the build skills used).
Every times I see the yellow ochre shown in this log I think - wow, that’s bright. Probably my only real point of comparison is Victory, and I know that historical views on her colour at Trafalgar have changed over time. Given how much research Chris has done, I wonder if there is a precedent for such a bright yellow?
On documentation of masting and rigging, I think Chris’s twin points - decent drawings and the level of skill expected for this model - are compelling arguments. That said, and having just hauled myself up from novice-level in this respect, there is room for an intermediate model, where the manual suggests the order of build and gives a brief description of the purpose of each category of rigging.
The yellow used on this model was Humbrol 74 Linen. My photoshop editing may have called for saturation to be turned down a little. Don't rely too much on any intensity that there seems to be. She's no different than any other scheme like this that I've seen modelled over the years.
4 hours ago, Seb Martingale said:
Hi Chris,
A fabulous model and a great build by James.
I see a couple of items are covered by the use of waterslide decals. These do have a definite shelf life - I know because of my journeys into plastic modelling.
Would you care to make an estimate of the shelf life of the ones included in the kit?
Regards, Seb.
Decals last many, many years. Even the older ones I've seen used have lasted over 20yrs and still been ok. Some old decals used to yellow on the carrier film, but you've no need to worry with modern stuff.
- KentM, Mr Whippy, Thukydides and 5 others
- 8
My main airbrushes are an Iwata HP-CH and an Iwata HP-C+.
I run these on an Iwata Studio Series compressor. These are what I have tended to use for both my magazine work and also my Vanguard Models prototypes.
However, with Indefatigable and her size, these airbrushes weren't as friendly, so I splashed out a 'small' fortune on a new airbrush. The larger needle allows me to give a good wetting to the hull with polyurethane varnish.
Ta da!!
As long as it does the job, all is good.
1 minute ago, Oldsalt1950 said:
Time for you two to take a few days...
I fully intend to!
There's never been a project on my bench, from recollection, as long as this. I was always a swift builder before VM stuff, but not one that ever rushed. Now I need to be in the zone between rushing and simply being swift. It takes a silly amount of forward planning, as a builder, in maximising my bench time in building as much of the small stuff as I can while doing the initial frame work...so deadlines can be met. I learned a lot of that from my magazine work, but this takes it to a whole new level.
- BobG, druxey, hollowneck and 11 others
- 14
20 minutes ago, Oldsalt1950 said:
I must have missed something somwhere...
Nope! 😆
Masting and rigging is well covered in the plans and making masts is mostly all about dimensions from dowel stock, I can't confer that any easier than a plan can. We also have to assume that at this skill level that the builder will have the prerequisite skillset to complete.
My room got gradually messier over the last 3 year with only interim cleans.
For the first time since last April, there's no building activity.
This time it's a deep clean to remove all vestiges of dust and detritus. Indy is now encapsulated so it won't get dusty during the next project. About halfway to making this workable again.
Blocked by the website firewall
in How to use the MSW forum - **NO MODELING CONTENT**
That about nails it.
In this instance though, we use Sucuri as a proxy, so all connections to MSW are going through that proxy, and it was Sucuri, not our own software, which flagged up the threat. Thankfully, these are very, very few, so it's never a problem for us to whitelist each IP.
