Hi Jason, I have looked at the framing on Pegasus, the ports sit between frames but there are filler frames below and above the ports some of which are extended to a timberhead, one being directly above the Bridle port, but there are also a couple further aft. The knightheads were intended to give lateral support to the bowsprit, and certainly on Pegasus sit close either side; the arrangement you show wouldn't fulfil this purpose so I think there may be some doubt as to the accuracy of their position. B.E.
- 800 replies
- snake
- caldercraft
Just love it Daniel,absolutely brilliant. ps. Grant, what do you think this is table service, nominate a messmate to collect the rations from the Galley, or else you'll all go hungry B.E.
Hi Bob, those plans look very similar in layout to those of my Pegasus. The upper mast part, that area above the stop of the hounds,ie where the top of the cheeks and bibs are fitted is the masthead and should be square, or slightly broader athwartships than in the fore/aft direction (Steel) In the case of Pegasus the transition is from 8mm dia at the hounds, with the sides flatted off to take the cheeks, and with the head squared to 6mm to form the masthead. The square section is indicated on the plan. Is there perhaps a note in the kit narrative indicating the use of strip to build up the masthead to the full square section? B.E.
I look forward to seeing the fruits of your labours Hamilton, whichever design you settle on. Re the tiles: my approach would be to cut them from paper or perhaps adhesive backed foils. The lead may well have been coloured with ochre to give the appearance of gilt, but on the Victory the lead sheeting has been left natural. When I built my Victory model I used exhaust repair tape coloured grey to represent the lead. B.E.
Hi Hamilton nice work on the decks. Re the Quarter gallery. Drawing D4/2 is quite difficult to picture in 3d, I would imagine it is not quite as angular as it looks, but rather had a slight round to it. The little roof which would be slightly concave would possibly have been tiled in decorative shingles, using overlapping semi circular discs of lead. I’m a little puzzled by the broad timber running from the cill to the rail as the dotted line looks to be the transom line, and I’m struggling to see the relationship between that timber and the gallery. I think you initially need to make up the basic shape and see how it looks on the model, and think about the mouldings and decoration later. Had you considered using sculpey to form the lower finishing, I would imagine it would lend itself to forming those fancy shapes as shown in the drawings. One other thought drawing D4/1 shows a Quarter badge similar to Pegasus, it can be made either flat or canted as Andy (realworking sailor) has done on his build, and there you have how he went about the job. At least with that type you would have a reduced number of glazing bars for the lights. Certainly the flat version can be cut from thin sheet and the window frames made up on the base. Styrene strip could even be used to form the curves and glazing bars if they are to be painted. Cheers. B.E.
I think I have used the four jaw chuck more than the three jaw simply because my topmasts have been made from square stock, and for round stock the collets take care of dowel up to 10mm dia. The four jaw is certainly more fiddly but I have found that by closing the jaws evenly and then opening by degrees to allow insertion of the workpiece off the lathe, I have better control. Final tightening is then done with the chuck screwed on. B.E.
Those bijou carronades are an exercise in pure frustration, but that's the worst over now, you can relax and enjoy the rest of the build. You're right about the plating, Amati have the edge over Caldercraft by a long way on appearance, and if I were doing Pickle again, or any other Caldercraft kit for that matter, I would ditch their plates in favour of Amati. B.E.
- 31 replies
- pickle
- caldercraft
Sorry to see the Mizen has failed Peter, good luck with the replacement. Cheers, B.E.
- 431 replies
- pegasus
- victory models
Nice work Tony, and a great instruction on how to achieve it; I would be really pleased to have produced that little gem. B.E.
- 269 replies
- Caldercraft
- First build
(and 3 more)
They look fine to me Jason, I also had to jigger with the chain lengths on Pegasus to get them to look right. Cheers, B.E.
- 800 replies
- snake
- caldercraft
Neat work on the Mizen stay Andy. Lees (Masting & Rigging) indicates the use of deadeyes up to 1805, but Marquardt ( 18th century rigs and Rigging) qualifies this as relating to large ships. Antscherl has gone with 5" hearts (2mm at scale). I suspect Lees who was Senior Curator at the NMM based much of his work on the close inspection of contemporary models, but hearts or deadeyes are a minor point in the ovearall scheme of things. B.E.
- 1,148 replies
Only been away a few days but you have made great progress Timmo, love the last batch of shots, show off the cleaness of your work a treat. Cheers, B.E.
- 366 replies
- granado
- caldercraft
A very nice job on those carronades Len, they are excellent B.E.
- 122 replies
- bellerophon
- victory models
Rigging sizes in relation to scale of model
Blue Ensign replied to HKC's topic in Masting, rigging and sails
That is more difficult because wire rigging sizes tended to be somewhat smaller than the equivalent rope sizes. Can the operators of the Danmark provide any information? or failing that The Cutty Sark also had wire rigging and that rigging information is available, and may not be too far out. B.E.
