Posts posted by MEDDO
For the flat sections of the deck probably not necessary but you definitely need to fair the bow and stern frame so you can get a nice positive gluing surface. Most of that char will have to be removed to get those forward and aft frame ready to plank but otherwise as long as there is not any stress the char will probably glue just fine.
Page 9 of this article will show what I mean.
Thanks Darrell! It was good to see everyone even if just for a short time. So do you know what you want to start on next?
Thanks JD
Was able to start shaping the thwarts and they seem to line up fairly well. I really appreciate that they were oversized and could be fit to match. Next up working on the upper inner planking
- Moab, druxey, Ryland Craze and 3 others
- 6
I know Model expo sells cross sections of both the Mamoli 1/93 scale as well as the Model Shipways 1/76 scale USS Constitution
The MS one is the same scale as their full kit. The MS cross section is designed by Ken Foran who is a member here. My own opinion is the MS instructions pretty good and the service can't be beat
Recent update. It seems to be paint, paint, paint and more paint. Have the seats and back in as well as the front platform. The risers and stretchers were a bit more difficult to place but seemed to go ok. Next up is the thwarts and then more painting
- Ryland Craze, Chuck, JpR62 and 8 others
- 11
Great start. I love the POBII. Basswood is sometimes a bit difficult to deal with but you are correct it is going to be covered up and if you have enough for the rabbit it should be ok
Awesome Ryland Thanks
- Ryland Craze, davec and thibaultron
- 3
1 hour ago, hollowneck said:
Sorting-out making the jig will take some time and effort but it will be worth it.
The jig can be relatively simple. Here is an example from a demo I saw at the most recent NRG conference. Extra piece of wood to hook onto the edge of table so it doesn't slide forward. The V grove can easily be made by just cutting off a corner from a square at a 45% angle then gluing 2 pieces together to get a nice 90 degree V slot. I am pretty sure he was using at least a 3/4 inch chisel maybe even 1 inch wide. Worked great
- chris watton, kurtvd19, mugje and 3 others
- 6
10 hours ago, Zarkon said:
I think Chuck made a guide on how to make planks but I can't seem to find it.
I think this may help.
- FrankWouts and Zarkon
- 2
Looks great I like the flags.
I think you can go to to the first post of the log and edit it and there is a wya to change the title.
- Canute, JesseLee, popeye the sailor and 1 other
- 4
1 hour ago, BobG said:
he had learned to paint a straight line without using any masking tape
Sorcery! Magic! Witchcraft! -
Pride of Baltimore II by Tony Dee - Model Shipways - 1:64
Personally some may be able to control a power tool for this but it always seems to get away from from me so I always prefer to just use sandpaper and/or sanding sticks
