Elijah
Everything posted by Elijah
  1. I'm not sure on the transoceanic, having never built one myself, but I'm sure somebody else can answer that question. Good luck, I will follow!
  2. Yes, the lighting will add a great effect! You'll also be able to see the interior (right?) !
  3. Hi Mark! That's a nice stern you've got there! I look forward to seeing more!
  4. Your planking looks great! I look forward to seeing more!
  5. It looks great! I think you have made me add a new ship to the list !
  6. Phill, you are correct, the wood is very soft and crumbly! I am starting to think of purchasing some styrene and using that for templates. It would make cutting easier, and it wouldn't crumble! Maybe I can make a trip this weekend…
  7. Hello, could you show some pictures?
  8. It looks good, however, you don't normally pin the second planking. Good luck!
  9. Last night I finished the stern holder. I still need to do some minor sanding. First, I cut out a paper template and nailed it to a wooden board. Next, I cut it out. This wood is crumbly, and a small piece came off. The spot is circled in red. I used ca for the first time to reattach the piece. I test fitted the sternpost simulator with it. I will do some sanding to make it fit better with the stern holder. After I'm done sanding, I will work on other components of the building board. Until next time!
  10. Excellent work Sal! I have noticed, only the portrait orientated photos turn sideways. The landscape ones are fine.
  11. Water would probably help. It makes wood flexible.
