Everything posted by ccoyle
Okay, I think I need to clear up some things. The epoxy in this case is not the finish; at this point in the construction it is essentially a sealer. The unthickened epoxy is still pretty darn thick -- it's like trying to paint with honey. Perhaps the cold temps these days have something to do with that. In spite of how thick it is, I was still disappointed to find later that there were quite a few runs, even though I had endeavored to spread it as thin as possible. As for finishes, the instructions recommend marine varnish for anything left bright, and marine primer & paint for anything else. I may end up painting the interior if I'm not entirely happy with the epoxy results -- I'll wait to make that decision. Thanks, all!
Another CA characteristic that some are unfamiliar with is that the bonds it forms have a low shear strength, which means that they don't resist impact well. When CA is used to bond materials that aren't particularly porous, such as styrene or metal, a jolt to the joined pieces will often knock them loose.
Looks fabulous, Nic! Have you got a next project in mind?
- 356 replies
- red jacket
- finished
"Painting" with unthickened epoxy is time-consuming and not particularly fun, but it has to be done. Here, the entire inside has received its first coat, and that includes the two end compartments. Don't ask me how many batches this task required -- I lost count! In fact, I strongly suspect I will run out of epoxy and will need to resupply. In the back you can see one of the two decks; these also got epoxied on their interior sides. Now, I have a question for you experienced builders out there, like @Bedford. The instructions don't say anything about sanding in-between epoxy coats. Is it a good idea? Optional? Or wait until the second coat is done and sand before varnishing?
In Mariposa we referred to this as "cosmetic snow." Not a lot, to be sure, but I like winter, and I don't feel like we've had a proper one unless I get at least one decent snowfall. Like some fruit trees, I need a certain amount of cold set to feel well-adjusted and productive for the coming spring and summer.
Almost -- I moved it for you. 😉 With regards to America, you have several options: BlueJacket makes two kits, one in 1/4" scale and the other in 1/8". Dusek now own the Mamoli line of kits and still offer the 1/66 scale America. Daniel Dusek has been updating the kits as he re-releases them, so the Dusek version might be worth a second look. Billing Boats offer one in 1/72 scale. Model Shipways made one at some point, but I believe it is out of production. Examples might turn up on auction sites. No matter which you choose, this project should be well within your abilities.
Permission to come aboard . . . . again
ccoyle replied to Peanut6's topic in New member Introductions
Welcome back! What style you choose for your reconstructed log is up to you. Have fun! -
Well, the weekend came back around, which means it was time for the final bit of fiberglass work. I think I finally got the handle on how to work with the stuff, so this step only took me about 90 minutes to complete. As our friends from across the pond say, I'm quite chuffed about how this turned out. Last night I trimmed the fiberglass cloth and cleaned up my work area. The instructions said nothing about slitting the cloth at the ends, but of course the draped cloth naturally wants to create folds there. I made just enough of a cut to allow the cloth to hug the sides neatly, then tacked the ends with tape. Applying the resin went lickety-split this time around. I worked with small batches, and it took six batches to do the entire job. The flatter portions I worked with a spreader, and the ends were finished off with a disposable chip brush. An extra piece of 4" wide cloth covers each end. I cut darts into each strip about half-way into the curved portion to eliminate some of the pucker. Once this is cured and trimmed, it will be time to seal the entire canoe with two coats of unthickened epoxy.
Long answer: Models are kind of a gray area in copyright law, but the governing principle in IP protection is the question of whether there is potential, intentional or not, to defraud the original IP owner. Since you are building a one-off model from scratch, as opposed to designing a kit with the intent to market it, you are neither defrauding the author's estate nor any of the production companies involved in making the film (and there were so many of the latter that I'd wager it'd be difficult to find out who actually owns the IP rights to the film version). In any case, all of the representations of the fictional Unicorn, book and film, look like late-17th century two-decked men-of-war, so you could hardly be faulted for building a generic ship of that type and calling it "Unicorn." This is quite different from the examples of Black Pearl and Flying Dutchman from the POTC universe; in their cases, the unusual appearance of each ship is a highly creative work protected by IP law. Even then, though, you'd likely be safe if you were building only a one-off model for yourself. Short answer: Yes, you can post pictures.
That's a very handsome model -- congratulations!
- 146 replies
- artesania latina
- bluenose ii
Correct, but bear in mind that the amount that you need to remove from each bulkhead may change slightly from top-to-bottom. Use a planking strip to check your progress. Ideally, at each bulkhead the plank should lie flat across the edge with no sharp bend in the plank and no gaps between it and the bulkhead. It's one of the skills that comes with the territory -- you'll get the hang of it.
No worries! In fact, you still have a lot of sanding left to do! The blocks you have glued in at the bow and stern -- the filler blocks -- need to be sanded to match the contours of the false decks above them and the bulkheads adjacent to them. The bulkheads also need to be bevelled so that your planks will not form a sharp kink at each bulkhead. You'll want your planks to form smooth curves from stem to stern. Midship bulkheads require little bevelling, if any, but those at the bow and stern may need quite a bit, especially on bluff-bowed subjects like Halifax. Good luck!
"Told by whom?" is the question. $800? Sheesh! 🙄
- 749 replies
- albertic
- ocean liner
Dia dhuit! Search through the build log index. There are several builds of this kit in progress.
Merging of topics needs to be done by a moderator. Adding to an existing log is done simply by using the reply window after the most recent post, just as you replied in this topic.
- 30 replies
Fixed! Michael, I really do hope your fine restoration effort finds a worthy new home.
- 749 replies
- albertic
- ocean liner
Papegojan 1627 by mati - FINISHED - 1/48
ccoyle replied to mati's topic in - Build logs for subjects built 1501 - 1750
Fantastic work -- worth the wait!
