ccoyle
Moderators
Everything posted by ccoyle
  1. More progress. The second rail was added -- had a bear of a time installing it by myself. Ruined a t-shirt in the process when the epoxy-slathered 1x1 sprang back on me -- TWICE. Now I have a dedicated epoxy-work shirt. 🙄 The manual recommends using a Japanese pull saw to make a neat joint where the rails meet. I don't have a pull saw and am not going to buy one just for one project, so I made the joint as best I could with a regular hand saw and then filled in the gaps with thickened epoxy. It was then time to flip the project over and continue work on the outside in preparation for the exterior fiberglass. First, some sanding to take down globs of epoxy on the panels that will be fiberglassed. Next, all of the exterior seams need to be filled in. The panels were tack-welded during the initial construction phase. Here, four seams are done, along with the spots along the keel that needed to be filled in. After this bit of work, which required two batches of epoxy, I ran out of gumption and good seeing light, so that was it for today. Four more seams to go, and that will be the last of the major seam work. Cheers!
  2. One thing (well, two actually) about these kits from MarisStella is the doweling of the bulkheads, which should produce a rock-solid substructure and eliminate alignment issues (unless the laser cutting is ever off for some reason), as well as the number of bulkheads supplied. The kit appears to have about half again as many as one normally sees in a PoB kit.
  3. The doors are items that you could very easily replace with scratch-built parts made from wood or card, if you choose.
  4. I think it's a fantastic story that you've got your father's model back. It's a great connection to your past, and that will remain true no matter how much of the original is ultimately retained. I wish you every success on this journey!
  5. Indeed! I'm always aghast at the little mistakes and boo-boos on my card models until I take off my magnifiers and step back to a normal viewing distance.
  6. This was a very handsome class of ships -- looking forward to following your build. BTW, I removed "wood" from your list of tags. It's kind of the default medium for our site.
  7. Welcome aboard, Henry! Ooh, that sounds like a Halinski product -- that's a real feat. We have a small cadre of card model enthusiasts within our ranks.
  8. Yep, that was the essence of my previous post -- it might have been a little too subtle for some readers. 😉
  9. Hello, Al. I'm all for making improvements to instruction manuals, though I am not personally familiar with BlueJacket's manuals. My only comment, for whatever it's worth, is that 11 x 17 is on the large size; on my small desk that would take up about a quarter of the work space. Of course that might not be an issue with some or perhaps even most other builders.
  10. That is true, but no part of an aircraft is essential to landing it! 😝
  11. You found them (see here)! I have not built any of WAK's kits, except if you consider some of the aircraft designed by Lech Kołodziejski that were previously published by CardPlane. I have, though, completed some ships by Digital Navy, Paper Shipwright, JSC, and Modelik -- I have a bunch of Paper Shipwright and HMV kits in my stash.
  12. On we go. This first photo shows one of my fiberglassing boo-boos. I trimmed away the excess cloth and sanded the sharp edges smooth. Now, as far as a repair goes, I'm thinking that perhaps the easiest thing to do would be to sand down the spot level with the surrounding fiberglass and then simply fill the divot with some thickened epoxy. Any thoughts on this? I don't think that there will be any structural issues with the few spots I need to patch -- as you can see, there's already an epoxy fillet beneath this particular spot. Next task was to finish sealing the interior of the bow and stern compartments -- or perhaps that's bow and bow compartments since both ends are identical at this point. Eventually I'll have to pick one end or the other as the bow. I didn't photograph this step, as it's quite messy, since the work has to be done at very awkward angles inside the cramped compartments. Then came the interior rub rails. First bit is to finish widening the pre-cut slots in the bulkheads. I intended to do both rails today, since I was able to dry fit the first one with only half of the clamps I have on hand. But of course once I got the rail slathered in epoxy, the stuff acted like a lubricant, meaning I had to use all of my clamps to get it to stay in place. There is a lot of tension on this poor piece of 1x1 until the epoxy sets -- notice I have my temporary spreader in place. So, that's it for at least another 24 hours.
  13. Welcome, Dennis. The Amati Lady Nelson is a perfectly acceptable first model, as it has the "three nots" needed for beginners, i.e. not a lot of planking, not a lot of guns, and not a lot of rigging. The instructions should be pretty decent, and the designer -- Chris Watton -- is a member here. Also, there are a lot of finished cutter build logs and gallery entries for inspiration and tips. Cheers!
  14. Be sure to check this gallery folder -- might have some useful visual tips for you, Smileydent.
  15. I have been using Rapid Fuse lately and really like it.
  16. Such a photo would indicate that something really, really bad happened! 😆
  17. Welcome, and good work on your model! Flirt's designer, Chris Watton, is an active member here.
  18. Been a while since I've read the book (and BTW, back in my SoCal days, Don helped me get through my first POB project), but if I recall correctly, it's more of a survey of various techniques rather than a how-to book. If you're looking for pointers, you can start here.
  19. I got the seams cleaned up, but there were still bits of blue tape residue visible. I decided to epoxy the seams with a wood flour/epoxy mix. It hides the remaining residue and ultimately will strengthen the seam, so why not? I didn't take a picture of this step, because it's not particularly visually interesting. Once the epoxy sets, the next step will be adding the interior rub rails.
  20. There's no fiberglass or epoxy yet above the second strake. Everything gets a coat of epoxy eventually.
  21. My messy fiberglass job has created a can load of extra work for myself, but I did manage to trim some more of the ragged edges today, and I also hit upon a workable method of tidying up the sharp edges and tape residue that are left over -- my Dremel tool skills have come in handy in this regard. This photo shows the cleaned-up edge I was able to get before it got too dim in my garage to continue working.
  22. Your work thus far suggests that this project will have a fantastic end result.
