Landrotten Highlander
Members-
Everything posted by Landrotten Highlander
Amati 1:64 HMS Victory - LATEST NEWS
Landrotten Highlander replied to vossy's topic in Wood ship model kits
I started with kits but went over to the dark side (scratch building), but for this one - the HMS Victory at 1:64 - I will reconsider, even though it is the 'wrong' scale, as my builds are 1:48 or 1:32 -
thanks for the clarification ... twice 😁
- 345 replies
- graf zeppelin
- trumpeter
Given the fact that the Germans were working on a concept of a jet fighter, I think it is entirely possible that some foreward thinking engineer thought that perhaps these things will one day be used on ships?
- 345 replies
- graf zeppelin
- trumpeter
Good point @Ondras71 is making. When I build a kit like that, I make sure the top of the front strengthening piece is situated just underneath the level of the false deck - that usually gives me the correct beard line.
- 26 replies
- mantua
- royal caroline
Another option is to have te rope pulled through a lengthy basin of dye. Your set-up would look something like this: a shallow long basin (such as for instance one of thos long plastic trays for window ledge planting) partially filled with your dye. The spool on one end, a rope goes underneath a metallic/plastic/wooden 'finger' that pushes it below the dye level, runs just above the bottom of the tray, passes a second 'finger' before it is pulled out. Perhaps using some tehnoLego manufacture a large-ish spool to automate the pulling of your rope (needs to run at slow speed, so the rope takes approx 3 minutes to run from one end of the tray to the other end). The spool would function the same manner as those mecahnised anchor things (my brain is not working properly this morning, cannot recall the name of the thing) that is used to lift the anchor, i.e. the anchor chain runs 3 times around the thing before it is taken off again, thus the chain is not wound up on it) That way all you have to do (once it is running) is to take the rope as it leaves your spool and hang it up on the hooks in the ceiling.
Pulling up a chair, as this model is on my wishlist as well - and in the scale I want.
- 87 replies
- royal caroline
- yacht
Sorry to hear about your fateful companion Capt' Buddy. A Dutch friend once sent me a poem about the rainbow bridge, where all pets are made whole and healthy and await their human friends when their time has arrived. Halped me through a rough patch when my first cat passed away because of cancer on his spleen. Wishing you all the strength you need. L.H.
I think Druxey and MTaylor are on to it. From my days learning to work the lathe (admittently, many decades ago, and in steel rather than wood) we always aligne our boring too in the horizontal plane (so not vertical as you are doing) and had to have the tailstock running in the opposite direction than for outside turning. The benefit in this setup is also that it is much easier to include a counter pressure to your cutting edge (in other words, if you have tube sticking out a long way, the moment your tool touches the inside of the tube it will always attempt to push the tube out of alignment, leading to an oval shape, rather than a perfect round one - having something gently pushing against the outside will counteract this).
Hi All, an article in the Guardian regarding the find of an Egyptian Vessel as described by the Greek historian Herodotus. https://www.theguardian.com/science/2019/mar/17/nile-shipwreck-herodotus-archaeologists-thonis-heraclion There is also a book available regarding the same ubject: https://www.oxbowbooks.com/oxbow/ship-17-a-late-period-egyptian-ship-from-thonis-heracleion.html
No problem. It is true I have plenty of industry experience but in no way do I consider myself an expert. As a matter of fact, to increase my knowledge I am currently enrolled in an MSc Advanced Manufacturing: Technology and Systems. It is amazing the quantum leaps that have happened since I left college, including cold forging turbine shafts from a small billet - the machine treats the steel *** if it were plasticine (and I hope I do not need to expand on the theoretical knowledge behind this technology, it is worthy of an undergraduate course on its own)
I think somewhere in two opposing corners should be sufficient. Any difference in stretching of the rubber will be due to differences in tightening the two halves. No need to go too close to your cavity, as then any stretching of rubber will lead to deformation of the cavity itself (so you could have a banana-shaped gun, instead of one where the two halves are slightly misaligned). The purpose of these pins is to align the moud halves at the same spot every time, then try to keep the same format of tightening for all subsequent pours. Personally, if your test is successful and you wish to use this technique on your good one I would take the brass template gun and place it in the mould cavities. Then tighten the two halves using a spare bit of wood so you can drill the necessary holes through this wood (I think two is a minimum, but no more than one hole in each corner). Then for pouring your material, only use pins that are slightly shorte than the overall thickness of your mould so you do not risk misaligning the rubber by forcing the wood over the pins. Again, I have no personal experience with this technique, but what I describe above is consistent with my observations and training in Industry relating to injection moulding and hot forming - the guiding pins are at the edge of the mould, and only so close as so not to cause undue deformation of the mould block - which requires both complex calculations and extensive experience when designing dies for hot forging (even though the deformation is within tight tolerances, it does happen).
I got this book in the original German language, and am enjoying learning about all the facts that have been uncovered. Highly recommended. p.s. if you have issues purchasing this book ,send an email via the website or a PM to Schiffebastler to sort this out. Probably a simple fix that has to be solved at the website template (may not have been tested properly when set up - happens more often than not these days)
I have no experience with rubber moulds, but have worked in the manufacturing industry for over 2 decades. Is it possible to drill a minimum of 2 holes in the corners to which you would then insert a dowel? Have it fixed in the bottom half of your mould, then the top half will slide over the pin. This should increase repeatability of alignment (this method is used fron injection moulding to hot forging).
Lime of Sulpher - a product used to blacken copper. Best done outdoors, asit stinks to high heaven.
- 889 replies
Hi chuck, will you let me know when you have stocked up on the kit, and when you are able to ship across the pond again? I am now entering a very busy period with the Uni and might not have time to follow up on a day-to-day business - and I HATE to miss out on the kit for a 3rd time
- 421 replies
- medway longboat
- Syren Ship Model Company
