KeithAug
Posts posted by KeithAug
  1. So I had better make a start but firstly a big thank you to all of you who have engaged with this project thus far. I will try to be as enthusiastic as you all seem to be.
    I have been collecting photographs and looking for plans of Cangarda on the net for about 8 months. It is fairly normal to find web photographs of restored classic yachts. Typically they are photographed in anchorages and photographs are also taken when they are sold or chartered. Unfortunately these photos are generally less than ideal for the typical modeller. For a start, much of the charter photography focuses on broad external overviews complemented by extensive detailed shots of the internal accommodation. The camera rarely points down at all those interesting deck fittings or up to the heavens where all that fascinating rigging resides.  Shots taken at anchorage (or in transit) are also generally less than ideal. They tend to be taken from too far away to get the detail and of course deck detail is generally obscured by the viewing angle. Sometimes as in Cangarda's case photographs of the restoration are available and these can be a useful resource.
    So far as plans are concerned, in Cangarda's case I was somewhat fortunate.  A paper to The Classic Yacht Symposium 2006 covering the early restoration of Cangarda contained 4 useful plans as follows:-Screenshot2023-01-08at12_38_47.thumb.png.d776069f4d62636c0bf6eb89d64f01c1.pngScreenshot2023-01-08at12_39_19.thumb.png.6ab6b35ec0bc3d486dd0a678bdc12b50.pngScreenshot2023-01-08at12_39_47.thumb.png.113ca9c0195ad94ef502f6878b566956.pngScreenshot2023-01-08at12_37_26.thumb.png.4e605e11a74d376a2a3651f5f807d1bb.png
    These plans while containing a lot of detail were contained within a PDF document and I struggled to find a way of extracting them while keeping the detail. The images posted above are screen shots and of course when these are blown up they pixelate and produce saw tooth line edges which aren't very useful.
    Notably the plan information did not contain hull lines and at this stage this was the most significant obstacle to attempting a successful model build. What did give me some optimism was that I had found a lot of on line photographs of the hull fabrication. With these I had started to get a bit optimistic that I could use the available plans (above) with the general frame shapes to make a reasonable representation of the hull form. Screenshot2023-01-26at20_49_41.thumb.png.8152b183439f10ff779fc801c6b7dc14.pngScreenshot2023-01-26at20_52_02.thumb.png.1eb7bd89d05cd8c71d3806e639228f6f.pngScreenshot2023-01-26at20_57_22.png.14e666a0aaa2af026175ed5c8f2a3d44.pngScreenshot2023-01-26at21_09_43.thumb.png.3398f7665344c9f463c4aea6ff9bdb40.pngScreenshot2023-01-26at21_35_02.png.a21b7f4f4ffc09b51dc2c0357b6d3323.pngScreenshot2023-01-26at20_51_01.thumb.png.8b6b8f7aa67c60f86f70a3ab3cbf57f9.pngScreenshot2023-01-26at10_17_10.thumb.png.e2475ca7ab92088326b8c5a667642ee8.png
    Interpreting the frames from the camera angle distorted images to generate the frame sections wasn't going to be easy but hey i was willing to give it a go.
    I am always a bit reluctant to put upon people and this was probably the reason that I only recently contacted Jeff Rutherford whose boatyard undertook the restoration of Cangarda. I couldn't have been more delighted with his response. Jeff confirmed that
    there were no lines originally and that the designer drew the profile of the bow and stern and the yard filled in the rest. The hull was then digitally scanned and the lines were retrospectively generated. Jeff put me in touch touch with Andy Davis of Tri Coastal Marine who supplied the "precious" hull lines drawing in PDF format together with a bonus reproduction of two of the plans from the 2006 paper. Screenshot2023-04-22at11_26_32.thumb.png.147f4ad941bdd9aa17ccc85d5fbc1edd.png
    The lines at this stage are not sufficiently detailed for modelling having only 11 abeam sections (5.5" spacing at 1:24 scale).
    The hull of Cangarda is constructed on 86 frames all equally spaced at 18" full size or 3/4" at 1:24 scale.
    Only one of the cross sectional hull lines aligns with a frame (frame 75 at the ruder post) with all the others being set off from the frames by varying distances. I want the frames on the model to align with actual frames (I learned this lesson on Germania see note1 below) and so I need to do a lot of draughting to generate the frame drawings.
    I have decided that I can get away with 43 frames for modelling purposes giving a frame spacing of 1.5".
    I guess it is now time to get down to a few weeks of tedious draughting to generate the 43 frame drawings.
    Note 1 - On Germania I didnt align the frames with the actual frame positions which became a problem when cutting the port holes (which invariably sit between frames) - some of which sat half on and half off the plywood frames - making for some very tricky drilling.
  2. 10 minutes ago, Bob Cleek said:
    In your Germania build I remember your decision not to paint the Germania's hull. What are your thoughts regarding the Cangarda's hull?
    Bob, I’m modelling her as she is now with her all welded “smooth” hull. As originally built she was constructed from riveted plates as can be seen in some of her early photos. My first thoughts on painting are. Plank her hull in mahogany and overpaint above the waterline in green to match her current finish. Below the waterline leave the hull as polished mahogany. But who knows what I will be thinking in a years time☹️.
  3. 1 hour ago, Bob Cleek said:
    Then, later, here she is flying the British "Blue Duster" in Canadian waters.  https://en.wikipedia.org/wiki/Blue_Ensign
    Bob, hmmm! I suppose she may have a Royal Naval Officer or reservist on board or be a member of a Royal Yacht Club, who knows?
    Or it may just be that the red duster is a bit lowbrow!
  4. 1 hour ago, Bob Cleek said:
    . It could be that she was pending transfer of ownership and the new owners intended to register her with a new hailing port.
    Bob - I thought that but then had a look at the photos I had of her since launch. Only one or two show the stern with any clarity but I can't see a hailing port on any of them.
    The second image is August 2021.
  5. 2 hours ago, Bob Cleek said:
    BTW, does anyone know why she doesn't have a hailing port on her transom?
    Bob, I don’t know but like you would be interested to find out.
    This is what I believe the rules are:
    The name and the hailing port must be displayed externally on the vessel, either on both sides of the hull or on the transom. The hailing port must include the place and a state, territory, or possession of the United States.
  6. 2 hours ago, FriedClams said:
    It's going to be quite large isn't it - a little over 5' (1.6m) - am I figuring that right?
    That’s what the admiral said ………………….. rather disapprovingly as I was pasting the plans together on the dining table earlier today. She relented when I showed her the photographs of how pretty Cangarda is.
    5’9” overall length.
  7. 20 hours ago, Roger Pellett said:
    If our free trade negotiators have failed to exempt legitimate exchange of intellectual materials between out countries then that is a shame.
    Roger - i wasn't aware of this and as you say it would seem to be easily circumvented by ebooks. Maybe the law makers have been reading too much Fahrenheit 451.
  8. On 3/28/2023 at 6:19 PM, Valeriy V said:
    I am making the propeller group of the destroyer.
    Very nice, How did you make the propellors and "A" frames? Are the blades brazed on to the hubs and how did you achieve the twist? Ditto the bearing bosses on the "A" frames. Hope you are keeping safe.
    • NRG Member
    • NRG-ColorLogowithTrademark2.png.f602d97b
    • Location Belfast, Maine
    Keith,
    I got some more photos of Cangarda today.  Slight rain and overcast.
    I put in a request to get aboard to take more photos, hope to hear back sometime today or tomorrow.
    Note that the discharge pipes are not symmetrical port to starboard.EA7B5561-BBF0-4D63-9FCD-858556405AB7.thumb.jpeg.74704d190814cd06558e79fd74e9f2c7.jpeg0A30D4F0-16AC-48D1-8ACD-144127A4E068.thumb.jpeg.9b600c6074b424a0f12cf33bc5476f9e.jpegECD672F6-9DA1-4E4B-959D-F735B00E4A4A.thumb.jpeg.fc14928e16141801243b65ede47510bd.jpegA198B65B-A889-44DC-8CB5-EAC41A371B07.thumb.jpeg.55acca6f7c44d5bc632db2c3d3d0dbcb.jpeg049B4DFF-712A-4304-A144-4D08529576ED.thumb.jpeg.e5e0e9480e650142f10588f19b483140.jpeg14598615-2FE1-4F42-80C5-24856193A976.thumb.jpeg.39e720f37d8fcc234cf4b91aeea2d18a.jpeg6505001A-8A30-45BD-B13E-E60CDC9D541E.thumb.jpeg.394c922441065286fe7322c72f4050f4.jpeg3A41164F-7F09-4AC9-8C74-FE5326F1286C.thumb.jpeg.1a3b1eee74ae900316a3bd378817f346.jpegE2700069-C87B-4305-BB65-289BA652404D.thumb.jpeg.49d35e8ecd3f191073f79829391da385.jpeg223701AC-F8DB-4BB2-A763-4539ACA1149E.thumb.jpeg.bbcda6a1e6da563eccf1d6acb1fc3efe.jpeg08D10606-B330-47F5-BFAF-F53B0BF2CDAC.thumb.jpeg.bfdc4d468806ea4674b3c6dfaaaac1a0.jpegED7671AA-5DC9-4F63-BA8C-8C59FA37D911.thumb.jpeg.b2c509fadff8b1aaab203a3bdd38a63d.jpegBB5DE5D6-84C0-4497-B8F9-48D5FE6406F6.thumb.jpeg.d648a20636fb52e293c7c2c419d82e1f.jpegF5D28702-6DC0-426E-8B83-35B520CA4F64.thumb.jpeg.53b863706634e6a3214d4f226dbc3f59.jpeg41FAA86E-28F3-4537-9631-3ED7E536EE3C.thumb.jpeg.a85850873290f8e11f7cdd86953a9f91.jpegFAEA693C-56A0-4275-888B-8C18AC95A99B.thumb.jpeg.4ed9067d47a419fe6e746d2a5fb09f79.jpeg89B35480-FDC8-47D1-B79E-5386A3A93E37.thumb.jpeg.714ed3e404e791f45da82242edc435ab.jpeg02E7295C-337A-4491-8E0B-F9EC0411A83F.thumb.jpeg.7d1385f548ce65bcb790fcbed28125ba.jpeg5AE100A5-3220-49C2-9AD1-772112FBAABE.thumb.jpeg.897d2f45d50d6da078a37164e662507f.jpeg652B63C6-EF85-4750-889C-5050F468D563.thumb.jpeg.b13e1d31bb5c642279c0c830aab7c4d5.jpeg29C4F7E0-B3F5-44AD-93D1-30FE4148BC0F.thumb.jpeg.b438b97d7b0ea1018c46c11e288ae5a7.jpeg0780C19B-1470-492A-A935-EC30BD6AD04D.thumb.jpeg.6d6238ed383121000a74dac23558abef.jpegFCE7AD13-352F-4AEB-A53A-8F29F58DDFB1.thumb.jpeg.bd2422c7177026c1994fae5b600277f2.jpeg23454714-0206-43FF-94B6-79BD194A1F8D.thumb.jpeg.c26e6a14a4b7893a98d67d6c18e6de20.jpegAE1D8379-626D-4B23-9F04-1DF7D5B26E8D.thumb.jpeg.bf5c2feaae669f763573a4eb0d7ca69a.jpeg891E6258-311E-4C94-AB17-0EE43EAEC043.thumb.jpeg.8651270f4cd1729c1192d96ba8be6f19.jpegDF2FA293-4217-4105-BDC2-0BC8B8440D69.thumb.jpeg.6f2341a5f49b12b1e94e0e9ebd48661b.jpeg
