Posts posted by KeithAug
2 hours ago, wefalck said:
I didn’t want to go insane over making such microscopic studded chains)
Eberhard, When i looked at the picture i wondered if you had made the chain - i thought you had perhaps gone mad and was somewhat relived to hear you had bought it. Thanks for the suppliers details - added to my tools and materials list.
- Keith Black, FriedClams, druxey and 2 others
5
12 hours ago, FriedClams said:
I'm inept at using the scroll saw
I know how you feel. At the end of cutting the frames for a particular build I’m getting quite good. I then put the saw away and don’t use it for 3 years until I start the next build. I’m then back to square 1.
Taking shape very quickly Nils and looking good.
Thank you Keith, Gary, Pat, Steve, Veszett, Maker, Andy and Michael and than you everyone for the visits and likes.
I haven't made a lot of progress in the last week, house guests took their toll and I spent some time fitting a DRO to the mill.
I did a bit of turning to make the stern light.
I then made the flagstaff from a bit of mahogany dowel with brass fittings.
I have decided however that it looks a bit heavy so I will thin it down a bit.
The stern rails have 2 life rings attached. These are of the larger type - 30" external diameter (.83" at scale size).
I glued 2 pieces of .040" plasticard together, drilled the central hole and then turned and shaped the outside diameter.
I needed to shape the inside diameter so I machined out a bore in a piece of wood and pressed the rings into it. I then shaped the bore.
With the rings still in the wooden jig it was mounted in the mill and the notches were cut out and drilled to take the grab rope.
Not much progress but the guests have now gone so things should improve.
- ccoyle, Retired guy, FlyingFish and 17 others
19
1
impressive planking to both the deck and hull. Well done.
8 hours ago, AKRYPTO said:
Giving the middle finger to Parkinson's disease one scuttle at a time
Thats the way, kick the backside out of it.
- thibaultron, AKRYPTO, mtaylor and 1 other
4
On 2/25/2022 at 6:01 PM, JKC27 said:
how I am going to create all the appropriate radars, masts, antennae that are both on top of the wheelhouse and also at the front mast.
A lot of members have faced these challenges. Post a few pictures and I'm sure you will get a lot of useful advice. Build looking good.
Very complicated paint job. I think you should have said "I made the deck from teak" no one would have been any the wiser.
- FriedClams, Keith Black, amateur and 2 others
5
On 2/22/2022 at 10:53 AM, Valeriy V said:
On my model, the rods for vyblenka are screwed with brass wire with a diameter of 0.08 mm.
Magic.
Looks very interesting, hopefully after 28 years progress will now be a little more rapid.
- thibaultron, mtaylor and Ian_Grant
1
2
Thank you Eberhard, Druxey and Richard for commenting - also thanks to everyone for the likes.
Most of the last week I have been working on the fore to aft rigging but I did start by fixing the radar (thank you Eberhard) - before and after shots below:-
I also needed a number of medium sized bocks for the running back stays (2 pairs), so I spent a day making a few.
I also made a few strops which I then realised were not needed - but never mind they will be needed later.
It find it is almost impossible to take good photos of overall rigging so I just took photos of specific areas.
Getting the tension correct in all stays is a bit of a trial but in the end I managed it - the next photo shows the flying jib stay tensioner.
The jib and flying jib stays were also mounted at this stage.
The top of the jib and fore stays are shown in the next photographs.
I then moved to the stern and installed the pair of running back stays for the lower main mast. The photo shows the top attachment.
Followed by the bottom - both are tight at this stage but the leeward side will be slackened off later.
Then the main topmast running back stays were rigged.
I then rigged the brace for the main mast. (It braces the top to the bottom via the dome (satellite coms?) bracket.
The stays joining the fore and main masts were then rigged.
I have a few more deck fittings to make, life rings, stern light, and flag staff. I will have a go at these next.
- Roger Pellett, GrandpaPhil, Valeriy V and 23 others
19
1
6
1 hour ago, Valeriy V said:
Metal ratlines are therefore easier to work with
Ah! that makes a lot of sense - good idea. What are the vertical lines (shrouds) made from - they look like a braided wire?
20 hours ago, Roger Pellett said:
screws would have allowed smaller diameter props; an important consideration in a craft to be beached.
Thanks Roger - I had wondered whether limiting draught was part of the thinking.
- Roger Pellett, mtaylor and Canute
3
Valeriy. Very impressive - as usual. The ratlines are particularly neat.
- mtaylor, FriedClams, Keith Black and 4 others
7
Beautifully crisp work Rob, wonderful.
43 minutes ago, rwiederrich said:
Finished up the mizzenmast shrouds.
Beautifully done.
I am surprised that such a small ship had 3 screws. Interesting - do you know why?
- mtaylor, Andrew Egan, lmagna and 1 other
4
I think you undersell your CAD skills. Impressive.
- Wintergreen, mtaylor and druxey
3
7 hours ago, AKRYPTO said:
The Ship will be in 1:72 scale and will be a functional RC model.
Have you made the hull from scratch? - looks very professional.
- mtaylor, thibaultron and lmagna
3
On 2/15/2022 at 9:07 PM, Jond said:
I am off sailing in Florida
Sounds great, I’m jealous.
USS Tennessee 1869 by Keith Black - scale 1:120 - Wood Hull Screw Frigate - ex Madawaska 1865
Posted · Edited by KeithAug
Very neat work Keith.
