Everything posted by amateur
Beautiful ships, but after more than thirty years, somewhat lacking power for the large towing jobs. It's the economy......:( Another lookalike (smit houston) also gone: demolished after a large fire in the engine room. And promise us: do not follow billings in the colour scheme. No idea why they use some nasty shade of green. The oriiginal had some darker green. Jan
I missed this one. still not used to your name-change Jan
- 83 replies
- o16
- pacific crossroads
It is positioned where the supersteucture sits loose on the hull. This whole thing is build up insitu. I guess the acetate is there to revent glue entering the gap between the hull and the superstructure, and so making the inner. Hull inacesible. Once the whole supersturcture is build up, and theglue is dry, there is no needfor a 'separator' any more. jan
You're well under way, but is it OK if I take a seat on the back row? Rotterdam was my second major build in my younger years. Still on top of the cupboard, but totally covered in dust...... billings did a major redesign, and although I see the advantage for the decks (and presumably the windows in the upper parts), it doesn't look like an improvement for the hull. palnking in narrow strips was rather easy. Actually, never had an easier planking job..... (but as it was only my second, it toom a lot of filler anyway, not in the least to get rid of the woodstructure in those upper hull part, which was certainly not made of close grained plywood ) Jan
are the treenails drawn with a sharp pencil? If so, how do you prevent from rubbin gthem off when you handle the ship? Jan
- 1,035 replies
- royal katherine
- ship of the line
Hi Doris, Great you're back. And with a formidable ship! Jan
- 1,035 replies
- royal katherine
- ship of the line
Eight months? It felt like weeks. A joy to watch your updates (also a joy to see the model completed), congrats on the results! and now, what is next? You can't leave us without something amazing to look at Jan
Where did you get that massive red-headed beam quite telling when it comes to scale.... funny isn't it: I never miss the sailors on deck in those sterile out-of-the-box models. On this kind of super detailed, convincingly wheathered models, I keep thinking: where is the crew...... I guess it is because of the quality of your work. (And please, don't take it as an suggestion ) Jan
My lion needed some severe surgery to get him im the correct position: I wanted his claws on the bow, and his head where you indicated. So I amputated his front legs, and glued them on, almost a centimeter lower on the body (filling all the gaps with some putty) I also discarded the metal sides of the galleon, replacing them with some cardboard material. That made it possible to get the scroll somewhat lower, the lion somewhat higher, so it matches (more or less). My bowsprit is on top of the scroll, should be slightly more space between them Still not finished... everything boxed up for a move..... Jan
I know how you did it: you photoshopped the original onto your desktop Unbelievable work! Jan
Another proof that there is no need to model a three-decker with run out guns to end up with an impressive model Jan
- 1,051 replies
- cheerful
- Syren Ship Model Company
Can you give us a clue with respect to the dimensions? Are we speaking centimeters, of miillimeters? Jan
A Dutch waterline
amateur replied to Jean-Pierre's topic in Painting, finishing and weathering products and techniques
Hi Jean Pierre, I did a curved (but as crisp as possible) waterline on my Prins Willem. I still like the appearances of it. (Did need some tweaking though, as the first coat was more or less on visual inspection (aided by some painters tape) with respect to the paint: I used the (cheap) acryllics from an art shop, quite heavily diluted for the first two layers, and slightly less dilluted for the final third layer. I would expect the one-layer paints far to thick and heavy to gettheresult you are after. (I guess that youreach a blurry effect by using several overlapping layers, of ineven coverage.) Jan -
How to make improvements? What are you thinking?? but OK, as you seem to ask it: I thought anchor chains where stud link chains? Jan
You could have smiled on that last pic on the beach:) But perhaps it was cold over there in Katwijk the model turned out as a piece of art. Hoping for the next one! Jan
- 434 replies
- pelikaan
- beamtrawler
Fokker Dr.I by Torbogdan - FINISHED - Model Airways
amateur replied to Torbogdan's topic in Non-ship/categorised builds
That will make a major difference to your model! Problem is: now you will be tempted to replace other white-metal parts as well.... Jan -
I did use it, but stopped using it. just plain PVA was far easier, and way cheaper..... Jan
