Everything posted by amateur
Hi Sandor, The pic you show is not 'just an other modl'. It is the model (or a very good copy of it) that is owned by the naval Museum in Den Helder (Netherlands). It is a model build by the original builder of these ships, and shows the ship 'as build'. In your case i would believe the planking pattern of this model. Jan
- 15 replies
- cannoniera olandese
- mantua
Ah, that's why your hair looks so gorgeous @Chuck. I bend the planking using a iron, using the model itself as a guideline. I find it alomost impossible to get the correct bend in one go. So I make a bend, try it on the ship, and repeat, until the desired curve is there (or, in my case almost equally likely, I have to start over again, as the wood splitted) Jan
Hi Kees, I wouldn't label that as schematic.... Quite nicely detailed on this scale. Jan
- 434 replies
- pelikaan
- beamtrawler
But as long as those still look way better than my own best efforst, I wouldn't mind looking at your glitches (Not interested in buying, though ) Jan
- 191 replies
- young america
- clipper
And dont forget that most mast are sllightly thicker above deck than at decklevel. Also, the taper isn't straight, but 'circular' Jan
She's looking gorgeous! I like her profile in the last pic. You're not going to complete this one, then? Jan
- 191 replies
- young america
- clipper
I have read very mixed reports on those pins. I used very simple push-pins for the job (the ones with a plastic head). Did quite well.... Jan
- 652 replies
- royal william
- euromodel
Sovereign of the Seas kit (was there ever more than one)
amateur replied to mtdoramike's topic in Wood ship model kits
Sorry, not old enough to answer your question..... Jan -
Hi Mark, Thanks for the link. missed that one. Jan
- 434 replies
- pelikaan
- beamtrawler
Hello Kees, Can you give some details on that tool you have attached to your table. It looks like a very usefull one for making windows. Did you buy t, or is it completely selfmaed? Jan
- 434 replies
- pelikaan
- beamtrawler
You're ageing very fast Crackers! (two days ago you looked quite young, although a bit tired) Perhaps you should see your GP.... Jan
- 434 replies
- pelikaan
- beamtrawler
Continental Frigate Hancock by wyz
amateur replied to wyz's topic in - Build logs for subjects built 1751 - 1800
Interesting restart! (I have a couple of unfinished ones as well, but I don't think they can be brought back into life.....) Jan -
Hi Gunter, I discovered in my own build (corel, prins willem scale 1:100) that dor the topgallants some cheating was necessary: the yards are not heavy enough to keep thme in their places without some help. For the main yards, everything just hangs fine by its own weight. @jparsley: next time you should consider making your mastwoolings from rope, or a strip of paper when the original had iron woolings. These brass rings donotlook completely right.. Jan
In stead of making theframes higer, you could also consider making the recesses inwhich thegratings rest slightly deeper. I think that willlookbetter. Jan
- 208 replies
Copied this one somewhere from the net (without the expalantion to the numbers...) The jeers are the two ropes from the blocks nextto the parrels to the underside of the top. Jan
I remarked in a parallel thread on these gratings that heynare the wrong side up: the flat side is the inderside, the upper side is not flat. If I remember correctly, Chris used these gratings as he was trying to get something in scale thickness. The lower decks are completely fitted out, and the deckopenings are the only real see- through option. Therefore in his own pics, the gratings are next to the openings. However, scale thickness required something slightly under a milimeter. Too thin to have them in wood. (Atleast, mass produced in a kit) Jan
- 208 replies
