Everything posted by kurtvd19
BADGER 150 DOUBLE ACTION AIRBRUSH SET SOLD The Badger 150 is an exceptionally reliable airbrush made to provide the modeler with an airbrush able to spray any type of paint or finish. It is a double action, internal mix unit. Internal mix airbrushes provide the best finish when using an airbrush. Double action airbrushes are not the best choice for beginners. This airbrush set is complete with fine, medium, and large orifice spray heads and matching needle sets, a braided air hose, two sizes of paint bottles and a 1/4 oz. color cup for small jobs. The medium needle/spray head set up is currently in place as it is the most used in painting model ships. To purchase this new today would cost at least $150. I have tested this set and can assure the purchaser it works great. It was previously owned by the late Steve Wheeler and was used to paint several models that all won gold awards in competition at the WI Maritime Museum contests. Some of the models also won best of show awards. YOUR RESULTS MIGHT VARY. The price is $50 plus normal USPS shipping (at exact cost) US and Canada only. The proceeds will go to the WI Maritime Museum in Manitowoc, WI. PayPal preferred. Please reply by PM.
2021 NRG CONFERENCE
kurtvd19 replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
Gary: The history is that we move the conferences so that as much as possible East and West coasts plus the Midwest are covered as close to equally as we can do so. This is so that all members can attend a conference without having to travel clear across the country as often as possible. Since 2013 there have been 4 Eastern events, with the 2020/2021 being in CA that will be a third Western event. The only Midwest event since 2013 was 2014 in St. Louis. So, we are overdue for a Midwest conf. The 2021 event will be in CA where the 2020 event was to be held. We plan on the 2022 event being a Midwest event possibly at a Great Lakes location. We have talked with the Mariner's Museum in VA and it is a likely location but there have been absolutely no plans made beyond 2022. A membership survey will be done before we make any plans beyond 2022. Kurt -
Converting a Backyard Shed into a Model Workshop
kurtvd19 replied to Hank's topic in Modeling tools and Workshop Equipment
An adjustable drafting chair is what I use for the couple of different height tables/benches in my shop. -
Ripping Planks - what I've learned from others
kurtvd19 replied to glbarlow's topic in Modeling tools and Workshop Equipment
A problem with cutting planks - or anything thin - between the blade and the fence is the rotation of the blade will send it back at the operator with the slightest amount of pinch or a twist of the cut piece. On big saws this has injured operators severely as well as killed some. I don't think anybody has to worry about a fatal injury from our model saws but don't think this can't injure you. Using a push stick helps cancel this out but one chews up a lot of push sticks when doing thin strips because the push stick has to be real thin when doing real thin planks. If you have ever had a push stick hit by the blade tooth you know the kind of shock that can be transmitted to your hand. It can all be avoided when using a tool to the left of the blade so there is nothing adjacent to the cut piece and it can fall away from the blade rather than come back at you and it's easier to use a push stick when one is pushing on the thicker part of the sheet. This is something that is used with full size table saws but the fixtures/tools that work on the big saws will not work on our small saws. I adapted the idea to a fixture I use on my Byrnes saws. The fixture is set to the left of the blade as shown above (Lefties you probably set your fence to the left of the blade so when I say left or right do the opposite). Measure where to place the fixture as shown below - measuring from the blade to the tip of the fixture for the thickness you want for the strips. With the sheet material moved into contact with the fixture on the left and the fence on the right. Lock the fixture down. This only locks the gauge part to the aluminum piece that fits into the groove on the saw table. I cut the aluminum to be a tight fit that still slides back and forth within the groove until I tighten it a bit more and the aluminum piece locks into the groove - notice the slit in the length of the aluminum piece - there is a counter-bore on the underside so the flat head machine screw makes the edges spread a bit wider when the screw is fully tightened. Move the fixture back towards you so there is a gap between the leading edge of the blade and the fixture as shown above and fully tighten the locking screw as described above. Turn the saw on and use a push stick to push the wide sheet material to cut the strip. When the strip is cut, it will fall to the left of the blade, move it out of the way and then pick up the sheet material and place it between the fixture and the fence - forward of the blade. Move the fence over to bump the sheet material up to the fixture and cut the next strip. On the Byrnes saw the thickness of each strip will be as close to exactly the same thickness as you can ever get. When I started cutting strips this was I measured each strip to see the variation - if any - and found that +/- 0.0005" maximum was what I was getting. Wood can change that amount or more from day to day with humidity changes in the shop. A bit of practice on how tight to make the fit between the fixture and the fence is needed but by the time one cuts a dozen strips the variation will be what I listed or less. The fixture shown below was my first generation tool that I used for several years before I made the one out of Plexiglas. The first generation fixture below -
USS Constitution Best historical wooden kit available?
kurtvd19 replied to J11's topic in Wood ship model kits
Blue Jacket's kit is endorsed by the USS Constitution Museum as "The official kit of the USS Constitution Museum". Sounds like it's accuracy is backed by the experts. -
Fiberglas used with epoxy resin will give a glass smooth surface. Hardly any odor. West System 105 epoxy resin and 206 hardener will work perfectly. Check https://www.westsystem.com/ It's very versatile and their instructions are great - the website has a lot of tips. Used for full size boats but works for models too. They have some other combinations if you need extended work times. I have used this and can recommend it. A bit expensive but their pumps for the resin and hardener do the measuring - 1 pump of each = the correct mixture - not a 1:1 mix but the pumps are calibrated to deliver the right amount to the mix. The containers are much different in size for the resin vs hardener. Good shelf life too.
Plans - Midwest Products - Fireboat #960
kurtvd19 replied to Chuck L's topic in Wood ship model kits
Is this the old wood framed kit? If so edit your question to mention it's the wood framed kit. The plastic hulled kit #993 has only one plan sheet. I just went and checked the partial #993kit I have - before paying attention to the kit # you listed. Sorry I can't help you. Kurt -
Eric: I have seen backing plates supporting ends of adjoining planks just like you mention below the floor used on small boats all over the hull - full size prototypical boats - but not being into that particular type didn't pay too much attention as to what kind they were. Somebody with more knowledge of this type of construction might be able to give you more info. Kurt
The article Chatter Grooves is 5 pages and was in Issue 19 on Pages 81-85 and was written by John Harland a recognized authority. A bit more than should be considered fair use. It is not yet available on the NRG store but I will extract it and make it available by contacting the office and telling Mary the name of the article. The cost is $2.50 payable by card or PayPal. She will have it by Monday morning. It is a PDF and will be emailed. The citation from Vol 16 - page 238 will also be included - it is a single paragraph question that appears to have been answered by Harland's article. Kurt
Byrne's saw accessories question..
kurtvd19 replied to CPDDET's topic in Modeling tools and Workshop Equipment
We did an addition several years ago and I cut all the 3/4" Oak trim for the windows, the Oak baseboards and Oak door trim with my Byrnes saw. It's a lot easier to carry from room to room than constantly walking to use a chop saw or table saw. Never even slows down going through 3/4 inch Oak. -
Any of the yellow carpenter's glues can be loosened just like Elmer's white glue is by water - just use Isopropal alcohol. The 90% works faster but he common drugstore stuff is just slower - and half the cost.
- 9 replies
- new member
- wood ship
(and 4 more)
Soup: What's your name? Noticed this is your first post. Welcome to Model Ship World. Do a search for "Aliphatic Resins" and one for "wood glue" and you will find several discussions on the subject. If you are still in a quandary after the search ask away - you will get answers. Again, welcome. Kurt
- 9 replies
- new member
- wood ship
(and 4 more)
It looks like you have to email them or call them. I thought they had a link to the books/store but either I am not remembering correctly or they changed the website since I last visited it.
A must have book for modelers of riverboats is Allan Bates' The Western Rivers Steamboat Cyclopedium and for details of boilers and engines his Western Rivers Engineroom Cyclopedium is good to have. Both are inexpensive and available used many places or new from the Howard Steamboat Museum in Jeffersonville, IN http://www.howardsteamboatmuseum.org/ Drawings 59 and 60 on pages 42 and 43 (respectively) show boilers from riverboats and the cross section - Drawing 60 shows the use of fire brick at the bottom of the boiler and the insulation on the top of the boiler. Heat transmission through the fire brick would not endanger the wood hull. Also, asbestos is noted as being used about 1900 on top of the boilers. A mixture of cow manure, fire clay, flax or chopped hay and hair (probably horse) along with road scrapings free of stones. Add water to the consistency of mortar and then applied to the top of the boilers. BTW I have permission from the author to use text and photos from his books. I hope this helps. Kurt
Micromark cutoff saw?
kurtvd19 replied to Brewerpaul's topic in Modeling tools and Workshop Equipment
I do this all the time. The cut edge needs to be cleaned up both ID and OD. A wire wheel works fine for the OD and either a file or a knife blade for the ID - keep a blade just for this type of work - you don't want to try using the blade for a fine cut after using on the tube. -
Micromark scroll saw?
kurtvd19 replied to jeffBoats's topic in Modeling tools and Workshop Equipment
Take a look at this saw from Home Depot - looks almost like a twin - and a lot less $$ One thing about Micro Mark - they have a lot of stuff but if they have it for sale it's commonly known that nobody sells the same thing for more than Micro Mark. https://www.homedepot.com/p/General-International-1-2-Amp-16-in-Variable-Speed-Scroll-Saw-with-Flex-Shaft-LED-Work-Light-BT8007/206347735?MERCH=REC-_-pipsem-_-205419917-_-206347735-_-N -
Gary: The shrouds turned out great and your solution to not using wire looks very realistic. Kurt
Latex wall paints?
kurtvd19 replied to Brewerpaul's topic in Painting, finishing and weathering products and techniques
Acrylic model paints have very finely ground pigments - some have pigment grinds as fine as 1 micron. Typical wall paint has pigment that is about 37 microns. That's how they can advertise - Guaranteed One Coat Coverage. No amount of thinning can reduce the pigment size. Use model paints on models. -
Byrnes makes a true draw-plate for making treenails. The sharp edges shave off the excess wood as one uses progressively smaller holes to get the proper size. The cheap ones advertised to do the same thing are most likely jewelers draw plates made to shape wire. If it's not shaving off wood its a jewelers draw plate or you have it going through the plate the wrong way. A good draw plate for treenails isn't going to be cheap - it has to be good hard steel and the flat surface has to be properly finished after the h oles are drilled. Jewelers draw plates shape the wire by squeezing the soft wire in the hardened steel. A jewelers draw plate does not shave off material. The wire will be longer when drawn down to the smaller size/shape as the draw plate is simply compressing the wire while it changes the size/shape and the excess metal has to go somewhere - and that results in it being somewhat longer when finished. Yes the jewelers draw plate can produce treenails but it will be a lot harder than using a proper draw plate and you will break a LOT of wood. Like everything else using the proper tool makes work easier and better.
New Website Thread?
kurtvd19 replied to Justin P.'s topic in NAUTICAL RESEARCH GUILD - News & Information
Journeyman: I have no idea about monographs there - I see a couple of articles listed. Please clarify. Thanks
