paulsutcliffe
Members-
Everything posted by paulsutcliffe
The temperature warmed up slightly Friday is managed to get some ship time in, head main rails are now attached and some more work done on the gallery top now working on the head timber carlings etc which curve upwards bevel towards the front and the sides, I had never noticed previously that they curve similar to the main rail as well Regards Paul
Mad magazine, now there's something I haven't thought of in a long time
- 82 replies
- skipjack
- wye river models
Hi Peter The quarter galleries did indeed have a kind of pool on the top, actually the cistern for the officers and captains heads/toilet inside the gallery which flushed down and out through the bottom of the gallery These were usually lead lined with a drain hole at the fore end Hope this helps Regards Paul
- 366 replies
- bellerophon
- victory models
Very similar hull shape as a packet ship as Chris says above, although I'm not sure of the gangplanks in the waist, definitely not a clipper or the cutty sark as they generally had their chains inboard and a roundedstern, could be a whaler or something along those lines Regards Paul
Hi thunder Check out the lines and stringing section, I have bought a lot of the strips in different thicknesses mostly boxwood and all have been top quality Regards Paul
Welcome Bruce http://www.exotichardwoodsukltd.com/ and http://www.originalmarquetry.co.uk/ are also two great suppliers of box, pear and ebony in the UK, have purchased all my wood from these two with no problems Regards Paul
Union Jack on a French ship ? Not sure how that would go down 😀
- 961 replies
Nice choice Keith, go for it Looking forward to the results if altair was anything to go by Regards Paul
Hi Michael, no problem thanks for looking in, I had major problems on the starboard with the windows and fitting the gallery, After some help from Druxey, Ed and others at the time I managed to fix it, I had made the top and bottom shelves the same size but not taken into account the taffrell I have had to trim down the top piece to match the bottom to ensure the windows are the same size and slope. Regards Paul
Wow, beautiful work, I didn't realise how big it was until I saw the funnels in your hand
The edges of the planks need to be bevelled to fit perfectly against the previous plank, you also need to shape the plank slightly in places to get a good fit ie thinner in the centre getting wider slightly towards the stern, have you read the planking tutorial by David Antscherl ,(look under tutorials in building, framing and planking) or chucks tutorial on planking in his cheerful log, this will help you enormously I getting your planks tight Hope this helps Regards Paul
- 43 replies
- 18th Century Armed Longboat
- Model Shipways
Druxey took the words out of my mouth, I was just about to say I doubt there was much fading under all those costs of paint.
Hi all Happy and prosperous new year to everyone Continuing with the head timbers I have made the lower rail, cathead supporter and eking piece, druxey states in his comet fireship book that the supporter is one of the hardest parts to shape and cut, he tells fibs ha!!! The head timbers are a real pain to shape and cut inbetween the rails and I have made umpteen templates and wrongly shaped pieces to get to these shapes, which don't really look much at the end. Regards Paul
Hi Mark Very nicely done, I'm glad you have finally decided on pewter casting, please make sure you show us how you do it as I would like to also learn more about doing this. One comment, I always thought the trunnion was off centre ie below the centre line, and is shown like this in the aots Diana not central as you have drilled, worth checking before you do all your masters, of course I could be wrong Regards Paul
