Posts posted by RGL
I am a fan of alternative history, but I generally see a really good PE upgrade set that inspires me. This is the third German ship so it was a good option as Bismarck and Tirpitz are done to death and no one can tell me I’m wrong as it was never operational (except @cog) so I can beat it up a lot. Thus post #1 which shows it’s only viable use in any timeline.
Strangely enough a novel came out after I started my build that included her.
H&S Infinity with a .15 needle and a .5 needle for big works. It’s an amazing tool.
- Canute, CDW, Landlubber Mike and 1 other
4
There is always so much work with nothing to show! But, I find when all these pre prepared pieces suddenly come togeather and you find yourself mikes ahead of where you thought you were.
Question; are you going to rig your ship?
- Canute, J11, Old Collingwood and 4 others
7
Are you going to use chipping fluids? If so might I suggest a good coat of German black/red then a coat of satin varnish and start with the chipping fluids and then shading?
Regardless its looking great and I’m looking forward to see its hull painted.
One bite of the elephant ata time
- popeye the sailor, cog, Piet and 4 others
7
- Ryland Craze, yvesvidal, Tigerdvr and 12 others
15
Yes, the bleed through! I’m going to use the airbrush for the rest of the deck painting so hopefully it won’t be wet enough to soak.
- CDW, Canute, Old Collingwood and 1 other
4
Finally, I hand painted all the features that are supposed to be metal. There was a tiny bit of over run but after weathering and parking airplanes on top it want stick out.
Next is to paint a big yellow line down the centre and the flags. The wind barriers don’t need to go on yet permanently. Coming along OK.
It’s dried rust, as it’s a dark colour it comes up very bright. I might work some scratches into it with a lighter primer colour on panel lines yet. There is a really big flagpole and a quad cannon in the stern that does distract a bit.
Once I get the deck on I need to paint on nazi flags, landing lines and the weather it. Yes, there will be nazi flags as it’s still historically accurate regardless of it being repugnant.
There will then be every bit as much as detail as Yamato or Ise.
- BANYAN, Ryland Craze, Canute and 15 others
18
The lid is on, hardest part of the build now needs a full day of touch ups and the rear support struts under the flight deck. I’ll have to pull off half of the support gussets and glue them flush to the hull.
Everything above the flight deck line can be done after everything below it is finished. Armaments will be done second last to the aircraft.
The massive holes cut cut in the front of the flight deck will house the catapults.
- GrandpaPhil, cog, BANYAN and 15 others
18
- GrandpaPhil, paulsutcliffe, Canute and 9 others
12
DKM Graf Zeppelin by RGL - FINISHED - Trumpeter - 1/350 - PLASTIC
Masts, 2 days work.
