Tigersteve
Everything posted by Tigersteve
  1. Oarlocks are virtually completed. Very delicate work. I followed Chuck’s method of filing and shaping from a longer 3/32” strip. For the vertical pieces I used a 1/16” x 1/32” strip since I did not have 1/32” x 1/32” in maple. After these were glued I sanded them down to the correct scale. The below photo shows a dry fit. Undecided if these will be painted. Any thoughts? They still need to be cleaned up a bit. Steve
  2. Wow- was going to say the same thing. It does resemble boxwood! These kits are going to be flying off your shelves. Steve
  3. The maple step installed. Still plenty left to do: oarlocks, “iron” protective strap, rudder, flying transom, oars, boat hook, possible barrels, and a display stand. Steve
  4. The knees were shaped from a maple strip. Installing the step is next. Steve
  5. I look forward to how you address the specifics of rigging the 1:96 POB version as I intend on building that version some point in the future. Steve
  6. Thank you! Cutting the frieze without cutting into the design is the hardest part. It’s very narrow. Steve
  7. Hi Mike. When I first applied the Minwax Polycrylic it appears to wrinkle, but the paper pretty much dries flat. A thin coat was applied. I used an Elmer’s glue stick to glue the frieze. My method is to hold the frieze with my thumb and run the glue stick the entire strip. Make sure it’s coated and there are no lumps before applying. After it’s applied I run my finger over the entire strip. This smooths out any bumps and I can ensure proper adhesion. Steve
  8. Don, a very difficult kit indeed- not for most first timers. Also, notice James has not posted since January. Are you still at this, James? Steve
  9. Your hard work paid off! I had forgotten what that model had looked like. I think your Pinnace is jealous of this display effort. Steve
  10. How long is the bull at this point, Dave? Nice work throughout. Steve
  11. A really superior Niagara model! I think I remember you using Syren rope, but did you also use Syren blocks or the kit blocks? Also- what type of wood did you use for your project? Sorry- I’m sure it’s mentioned in your log somewhere. Look forward to the boats you craft! Steve
  12. Thanks, Mike! The maple is much harder than the basswood, but I didn’t invest much time into making a scraper so my attempts at this detail were short lived. I decided in the end to move forward. I think you were the only one to successfully reproduce Chuck’s results. Steve
  13. I’m in too. This looks like a nice project. Steve
