Tigersteve
Everything posted by Tigersteve
  1. How long is the bull at this point, Dave? Nice work throughout. Steve
  2. A really superior Niagara model! I think I remember you using Syren rope, but did you also use Syren blocks or the kit blocks? Also- what type of wood did you use for your project? Sorry- I’m sure it’s mentioned in your log somewhere. Look forward to the boats you craft! Steve
  3. Thanks, Mike! The maple is much harder than the basswood, but I didn’t invest much time into making a scraper so my attempts at this detail were short lived. I decided in the end to move forward. I think you were the only one to successfully reproduce Chuck’s results. Steve
  4. I’m in too. This looks like a nice project. Steve
  5. The friezes were treated with Minwax Polycrylic before using a glue stick to apply. The difficult part was cutting the friezes off the sheet. The mouldings were edge-bent with dry heat to conform to the shape of the hull. Gluing these was a challenge. After the glue dried, the mouldings and hull were sanded. Wipe-On-Poly was applied to the entire outer hull including the friezes. Steve
  6. Thank you. I appreciate that guys! I installed the friezes last night. It really makes the boat “pop”. After I install the mouldings I will post photos. Steve
  7. Thanks everyone for the positive feedback. The last and most difficult of the paneling is complete. Strips were edge-bent after soaking in hot water to create the curvature. One continuous panel was created to take the place of the knee at the bow. Not as crisp as the other panels, but this issue should fade as the knees are added. Steve
  8. What was the experimental wood? Any clue why Wood Project Source’s store is “closed for maintenance”? Steve
  9. The rear panels were fitted and installed one piece at a time onboard. The bottom strip of each panel was slightly edge-bent to follow the curve above the cockpit seats. I skipped making the template and jumped right into this. I think the single panels change it up a bit. The panels really should be somewhere in between 1/16” and 1/32” wide in my opinion. Unfortunately, mine are not. ;-) Steve
  10. I’m sure there are many solutions to completing these tasks. Your metal work is mind-blowing though. An art in itself. Steve
  11. The eight midship panels are completed. To accomplish this I created a template to capture the correctly sized rectangle. 1/16” wide maple strips were sanded and coated with Wipe-On-Poly prior to cutting the mitors. A jig was created to size, assemble, and glue the panels. After they were assembled, another sanding and coat of WOP was applied. The “fancy” profile was omitted. Many logs I viewed showed folks adding this detail, but at 1/32” thick almost none could produce a profile as clean as in Chuck’s prototype. Mike Y had the cleanest profile, btw. I created a scraper and tried it out, but even with hard maple it was difficult. I decided to save the hours on this detail and move forward. (It’s extremely tiny with the naked eye, but looks huge in photos.) Next task is to figure out the configuration of the rear panels. I will try a modification: one longer panel instead of two shorter panels. Another template will be made to see how it looks. Steve
  12. Finally catching one of your builds from the start, Dan. Nice work so far! Steve
  13. Gary, that sounds like solid advice. Ship looks great. Steve
  14. Echo the above comments. Insanely complex! Steve
  15. Really fantastic model. I really enjoyed following along. Steve
  16. Thank you all for the positive comments and likes! I’ve certainly been taking my time with this project. I just realized I started this log in April! The panels should be fun. Who knows how long that will take... 😜 Steve
