Posts posted by JpR62
Really well executed paint job. Well done. I like the choice of colors a lot and especially this red.
Superb work and a very great result !
- Retired guy and WalrusGuy
2
- BETAQDAVE, Duanelaker, GuntherMT and 6 others
9
Superb work, Bob. You are always an inspiration for me !
Thank You Justin, Brian, Captain_Hook and all the 'Likes'
I know that one of my swivel-gun supports is slightly off-center from the two shrouds.
But that does not prevent laying the swivel-gun. It's just that he can turn less to one side.It is probably the case of half a millimeter ... I still hesitate to move it ...
I finished laying the forestay and the jibstay. For the mouse, I used the method described in Brian's excellent build-log
Syren's Serv-o-matic is really practical and efficient. And so easy to use. Another purchase that I do not regret.
I really like this part of the construction.
This search for perfection and innovation always impresses me. It is superb ! Thank You
- Ryland Craze, Chuck and FrankWouts
3
Very nice work. Precise and clean. It will be a very beautiful little ship model !
- Dfell and Blue Ensign
2
Wonderful work as usual. Weathering techniques are really mastered !
Can't wait to see the final result !
- Duanelaker, GuntherMT, J11 and 1 other
4
As maple seems to have won unanimous support, it is therefore this species of wood that will be used.
Legos blocks and a piece of wood slipped into the gap provided to receive the keel ensure perfect symmetry of the two pieces.
A photocopy of the plan is used to aid in the placement of pieces on the base.
The extra keel copy is used to properly align the two pieces when gluing.
The base is finished. More than to apply one last layer of teak oil.
Provisional test of placement.
It's time to start working on painting friezes.
- Nunnehi (Don), BobG, gjdale and 8 others
11
- FriedClams and bruce d
2
I find the version with the single-sheet cellulose more subtle ...
Always a real pleasure to follow the progress of this log !
- mtaylor and captain_hook
2
Yes, the decision is not easy.
Finally, as there are only 6 pieces to cut, I will prepare the two sets and make my decision with the longboat in situation...
I would repost two photos once the supports are ready.
- Ryland Craze, BobG and FriedClams
3
Holly is too light. For me pear is too similar to the hull. My heart swings between the cedar and the boxwood. But perhaps, with AYC the contrast will be too pronounced ?
Boxwood seems to me to be the right choice. But that's only my opinion...
- FrankWouts and BobG
2
Thank you Bob for your opinion.
To help me in my choice, I quickly cut out an example of the future structure (some pine scrap wood) and positioned the longboat in the background.
In the first photo, a maple piece is placed between the base and the longboat while in the second photo it is a pear wood.It seems to reinforce my first idea of a better contrast if I use pear wood.
- GuntherMT, Ryland Craze, bruce d and 2 others
5
Thank you Gary for your kind words. Your work is a reference for me and motivates me enormously.
Thank you to all the 'Likes'.
I want to finalize the base for my longboat.
I will try to reproduce part of a ship's deck. It will not be a faithful reproduction but rather an inspiration.
First, I draw the laying plane in order to determine the length of the different segments. All the planks are then cut. My new Byrnes table saw really makes my job easier 😁
I simulate the caulking using the black plastic sheet found at the back of the folders to store paper documents.
It suffices to precisely cut strips of the width corresponding to the thickness of the planks and then glue them between each row.
As the gluing is done with wood glue, I spread my work over 2 weeks because you have to wait until each row is completely dry before proceeding with the installation of the next one.
The left edge will need to be sanded to equalize the length...
A first coat of teak oil is applied.
I will need your advice on the species of wood to use for the small support on which the longboat will be placed.
There are two options: use the same wood species as that of the deck, in that case: american mapple (strip of wood located below in the photo) or use swiss pear (strip of wood located above).
It seems more judicious to me to use pear wood in order to better distinguish the two different elements: the ship's deck and the longboat support.
But I still hesitate ... What do you think?
- gjdale, GuntherMT, FriedClams and 3 others
6
- J11, GuntherMT and Ryland Craze
3
I like the principle of cutting the sternrail in glued pieces of wood rather than wanting to bend a single wooden piece. Efficient and smart 🙂!
- mtaylor, FriedClams and KentM
3
HMS Winchelsea 1764 by Guillermo Madico - semi scratch build
in Member Build logs for the HMS Winchelsea
Super work. This frigate is a wonderful ship model. You really did a wonderful job with these carvings.
