JpR62
Posts posted by JpR62
  1. I had put my project on the longboat on hold because I have a pretty good idea of its future presentation which will be inspired by Steve's wonderful work.
    I was looking for gratings that could match the 1:24 scale.  Finally, I found what I was looking for at CAF who provides gratings at different scales.
    The largest one allows for a 3 mm spacing.
    So I cut 3 mm wide strips with my Byrnes table saw.
    The assembly is then a breeze.
    The three elements are then cut to size and sanded.
    At this scale, we can afford quite precise details. Having the beautiful 3D photos of Swan class virtual 3D purchased from Admiralty Models, I was able to have a precise documentation. These virtual views are absolutely beautiful and the price is really modest considering the quality and quantity of details on this class of ship.
    I allowed myself to photograph one of my gratings next to one of the detail photos of the Swan Class virtual 3D. You can only admire the quality of these photos... And there are hundreds of them detailing all the elements of the ship!
    The nailing session will still be long...
  2. Thank you Chuck for your kind words. But when you have a model of this quality, so well designed, it is easier to get a good result. A lot of the credit goes to the designer...
    And thank you to all the 'Likes'.
    Setting up the fashion pieces.
    I decided to choose Alaskan Yellow Cedar as my wood for the fashion pieces. This wood has many advantages: it is easy to cut (I was able to use my cutter to cut the 1/16" thick pieces), it is easy to shape, and you get clean angles. Really a great wood!
    First, I cut my pieces into perfect replicas of the plan. But then I realized that it was difficult to position them correctly... So I got inspired by the method used by Stuntflyer (Mike). I traced on the model the front location of the parts with a pencil. I cut my pieces with the back part slightly wider. Once glued precisely to the line, I simply sanded the back part. Be careful not to forget to leave a space of 1/32" along the transom while in the part that runs along the counter you have to sand level.
    I glued the pieces with Titebond wood glue, which means that the preformed pieces must be held in place while drying.
    The pieces are then sanded on the back side and reduced to a thickness of 3/64".
    To finish, I simulated the reinforcement dowels by drilling 4 holes with reference to the plan. A sharpened pencil tip is inserted in the holes to round them perfectly and toothpick tips are glued. The whole is then finely sanded. I know that you won't see much once the fashion pieces are painted black but I hope that you will be able to see them under the layer of paint.
    I will now proceed as many modelers have done to lay the first two strakes of planks directly under the wales before adding the second layer of the wales.
    I have several questions that come to mind:
    - Is it time to paint the outside of the counter red?
    - I purposely left my fashion pieces slightly longer (they extend slightly past the bottom of the wales). Should I wait until I have installed my first 2 rows of planks before sanding them to the right length?
    - If the manual contains precise indications on how to tapered the first 2 strakes of planks at the bow, nothing is indicated on the width of the planks at the stern. Should I keep them at their 3/16" width or should they also be tapered?
    Thank you in advance for your help!
  3. Thank you Christian and Glenn for your kind words and thank you to all the 'Likes'.
    In the end, I decided to opt for a cleaner finish on the inside because I felt that the joints between the planks were too visible. So I fill in all the joints and sand the whole thing to prepare the surface for the painting phase.
    You will notice that in the meantime the transom has been completed.
    I realized after the first layer of the bottom molding was installed that the rabbet at the bottom of the port opening was twice as wide. So I decided not to leave a rabbet on the upper part to respect the height of the port opening. As we will install the port lids later, we should not notice this small mistake...
    I then traced the upper curve of the stern with reference to a copy of the plan and gently sanded the top plank. In the picture above, the starboard curve is finished.
    And finally an exterior and interior view once the sanding is completed.
    Since I have a week's vacation for Easter, I'm taking advantage of it to make progress on this superb model.
    I now have to move on to a more delicate phase with the fashion pieces... I will first consult a lot of existing logs
    and reread carefully the manual.
  4. Thank you Ryland for your kind words and thank you to all the 'Likes'.
    I started working on the stern.
    I started by planking the counter. I first determined with the help of the plan the curvature to give to my planks.
    Then I have to admit that with the travel iron it's really easy to shape the planks. You just have to moisten the wood with your finger and bend it while passing the hot iron. And the plank keeps its curvature.
    For gluing, although no pressure is really needed, I still hold the planks in place with clamps while the glue dries. I can't master gluing with CA, it sticks my fingers more often than the planks... So I use good Titebond wood glue which requires 30 minutes of holding time for the glue to set.
    Once the whole counter is covered, as this part will be painted red, I allow myself to fill all the micro-cracks between the boards. Often, they are not even visible to the naked eye but with a magnifying glass or by observing against the light you can see them.  I use acrylic wood filler (Jubin Akrilin) that I tint with a drop of acrylic paint and add a little white glue.
    I mark the areas to be filled with protective tape and use a toothpick to push the filler in.
    The over-lengths are first shortened with my proxxon and then refined with sandpaper.
    The whole thing is then carefully sanded.
    The interior has been lightly cleaned of a few small traces of glue. I don't know yet if I'll fill the inside joints between the planks perfectly or if I'll leave them like that. I don't mind that you can guess the joints between the planks...
    It's time to move on to the upper part of the stern.
  5. Thank you to all the 'Likes'.
    The strakes above the molding have been glued, so take your time and measure the length of each segment precisely.
    I marked one edge of each plank with an HB pencil to simulate the tarred seems between each strake. I also glued the edges with a dark wood glue.
    You will notice that the two outer frames of the stern have been reduced to a thickness of 1/16". Most of the work was done with a sanding drum mounted on my proxxon flexishaft and then the last few millimeters were carefully removed with various sanding sticks.
    At the stern, the last row is slightly below the top of the outer frame, but this has been noted in several build logs and I don't think it should be a problem.
    Next step: planking the stern and always so much fun !
  6. Thanks to all the 'Likes'.
    This week, I put the planking between the wales and the first layer of the molding.
    For this I used the method described by Chuck and proceeded to shape the planks using a small travel iron and a hair dryer.
    I have to say that this method works pretty well and makes it easier to get the planks in place.
    I found that the second strake, the one that fills the space, was still difficult because the width of the planks must be really precise.
    The next strake should be easier as it will consist of a constant 5/32" width, although here it will be the length that needs to be precise to leave a 1/64" gap around each gun port.
  7. Thank you Glenn and Mike for your kind words and thanks to all the 'Likes'.
    Glenn, cherry is really a beautiful wood and the quality provided by Wood Project Source is really excellent. Too bad they are out of business.
    Mike, this project is really interesting and indeed a lot of fun.
    Just a little progress this week with the installation of the first layer of the molding just under the gunports.
    They had to be positioned just 1/64" below the edge of the gunports. It's really a small rabbet... I again used a temporary batten strip to try to be as precise as possible.
    I started dividing the open space between the wales and the molding in half so I could prepare the planking.
