GrandpaPhil
Posts posted by GrandpaPhil
- Snug Harbor Johnny, Baker, mtaylor and 7 others
- 10
Here is the original rigging plan (Courtesy of the French Ministry Of Defense Historical Office) as approved in 1864 for the refit from a barquentine rig to a barque rig:
You can’t really tell if there is any mast rake from the pictures that came with the kit.
However, from the original sail plan, you can tell that rake, for our purposes, at 1/200 scale, is negligible.
Now, for the Magenta, which will be 1/72 scale, that may change.
- mtaylor, Edwardkenway, Keith Black and 3 others
- 6
Note: the mizzen mast is painted and awaiting sealant after the paint dries.
It is quite cold here which is negatively effecting drying times.
The rigging plan for this model is very simplified due to the scale, so I am only going to running about a third of the lines as in a normal barque rig, even with sails.
By comparison, my Mamoli Endeavour (the Captain Cook one, not the yacht), which also had a barque rig, took three months to rig.
I took holiday (vacation) next week to try and finish this model.
And, due to the rigging simplification, it might actually happen.
- Canute, mtaylor, Keith Black and 2 others
- 5
The foremast is made and temp installed:
It still needs paintwork and sealed.
I just made my own mast, but I used the kit’s mast tops and fife rail.
The mast is made from a dowel rod, a bamboo kitchen skewer and a toothpick.
I shaved them down with a scalpel and sanded smooth with 220 grit sandpaper.
Mast hoops are made of paper.
- mtaylor, Keith Black, Gahm and 8 others
- 11
Glen,
Incredible work!
- Keith Black, Glen McGuire and mtaylor
- 2
- 1
Thank you very much!
Solferino is ready for masts!
I started on the hammocks, but discovered that they would interfere with the lanyards on the deadeyes.
So, I rolled them and put them in the plastic container that I stored the ship’s boats in.
I have no idea how many I made, I didn’t keep count.
I started on Solferino’s masts:
I found out in a test fit of the lower foremast that the kit version of the masts only go to the deck.
I had to use the first foremast I made as a depth gauge to figure out what I needed to add to each of the masts.
I then annotated said addition by the pieces from the kit.
Needless to say, I have to make another foremast.
Oh well, live and learn.
I’m making each full mast, one at a time to prevent confusion as to what goes where.
I will make yards and gaffs after I finish and install the masts.
- ccoyle, Edwardkenway, hof00 and 8 others
- 11
I’m working hull rigging and getting railing stanchions made from wire for the forward railings.
I already touched up all paint and sealed my work in.
I will paint the railing pieces after installation.
I’m trying to finalize the hull so I can go ahead and make/install the masts.
At some point in the nearish future, I need to put a highlight coat on the hull.
That is when you VERY lightly drybrush white on the upper surfaces and edges of a model to give the impression of lighting and shadows.
It should be done prior to installing the masts.
- Edwardkenway, Baker, Keith Black and 2 others
- 5
I am adding ship’s boats to davits:A couple of the straps are too wide and I shouldn’t have made them from the thicker card.
Oh, well, live and learn.
In other news I touched up the black.
The tan needs touched up and then the whole model needs sealed.
Speaking of sealant, I just bought a couple cans of that Krylon Matte Spray sealant that @ccoyle recommended. Thank you very much for pointing me in the right direction.
I am acquiring a pretty significant card model collection.
I keep buying Shipyard kits.
I can’t help it. They are so cheap to buy, but are such high quality.
And with the 30th Anniversary combo packs, how can you pass them up?
Even if they are 1/96 scale, card kits are so easy to resize at will and build them however you want to.
Orel has a bunch of kits that I want as well.The same scaling issue applies there as well.
Welcome!
- Keith Black and mtaylor
- 2
Britannic is looking really good! Amazing work!
- AJohnson, king derelict, Kevin and 3 others
- 6
Welcome!
- mtaylor, Keith Black and Dave_E
- 3
The Vanguard Sphinx looks incredible!
- Canute, HardeeHarHar and mtaylor
- 3
The drawing on the right is the side-on drawing of the first cant frames.
They appear to take the shape of the curvature of the keel when set at an angle.
- Keith Black, VTHokiEE, catopower and 1 other
- 4
French Ironclad Solferino 1861 by GrandpaPhil - FINISHED - Orel - 1/200 - CARD
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by GrandpaPhil
Foremast lower shrouds and the foremast backstays are in place:
They are going very slowly.
I have been having problems getting behind the davits and the vertical supports for a railing type piece of rigging that will go all the way around the ship.
The small size of the deadeyes has been giving me some problems, too.
Many of the shrouds and a couple of the backstays so far have been replaced a couple of times, too.
However, as much of a difficulty as these are, real ratlines look infinitely better than ratlines made on a loom with fake deadeyes.
This part of the model has been a lesson in Adapt and Overcome.
