Everything posted by cog
Nenad, That's not an office desk ... That's a disaster area, or a war zone!!! I would give that to hothead, something to keep his mind busy
- 4,152 replies
- cutty sark
- tehnodidakta
Mick, That will be not much fairing, what I see from this side. Maybe a bit of "touching up" in your case touching down
- 504 replies
- washington
- galley
Well done .. it really looks very good, very crisp, and sharp
- 75 replies
- scharnhorst
- dragon
More then interesting build Keith, when I look at the height, she seems to be a bit narrow in the beam, or is that an optical illusion ...? I like your framing a lot, and, as Patrick wrote, it would be a shame to hide it all. The windows would be a solution, will you be installing lights ...? Cheers
- 34 replies
- steamer
- sternwheeler
That was truly a missing item. Your captain wouldn't have liked the absence of it!!! (Witchetty Grub ..) at least you've got your snacks nearby cheers
- 1,083 replies
Those boats are looking good, Bob, and must be fun to make too. cheers
- 348 replies
- pequot
- cable ship
The hobby is strong in you Kees. I don't know about the incorrigable, you must have been driven (or bored). Modelling is a good way to keep the mind bussy. The doctors probably thought you strong enough. Good to have you back at the table!!! Cheers
- 434 replies
- pelikaan
- beamtrawler
Piet, A humongous feet (could put that one in my mouth!!) feat, in such a microscopic diorama ... It's ... breath taking ... and nearly impossible to believe. You did it!!! Congratulations, it looks a zillion ... Cheers
Impressive rigging Gregg. Love the way she is coming together ... Murphy can be a pain in the hiney, always turns up when you don't want it Cheers
- 342 replies
- dreadnought
- zvezda
Mike, Whatever you do, you can't let us down. Build to the best of your ability, and improve. Have fun in your build, and tackle the challenges ... enjoy it !!! Cheers
- 225 replies
- chaperon
- model shipways
Good on you Mike. The first step is always the most difficult one. Beech wood ... Personally I like the colour, and structure, you can bend it easily when steamed, I don't know about the dry heating method. It is often used in kitchens, as it doesn't splinter (cutting boards a.o.) I don't know how thin you can get it or mill it, that's another question left unanswered, but it can be finished very smooth.
- 225 replies
- chaperon
- model shipways
A hughe change compared to your previous view. You like it or you don't, no middle road in this. I am looking forward to see the remainder of this metamorphosis!!
- 4,152 replies
- cutty sark
- tehnodidakta
Ah, to be on the safe side, Mike. Make a xerox copy when finished and use that one to transfer the markings. You could use carbon paper to transfer the markings ... if that is still available
- 225 replies
- chaperon
- model shipways
What will be visible of that ugly join, both a midships as length wise, once the walls and deck frniture is fitted ... If that is acceptable to you ... the decision is yours, as it is your build, Mike. If, however, you decide to plank the deck, make a template from your current one for the round and square openings. Put a piece of paper on top and with a soft pencil, 2B or higher, softly scratch over the openings. You'll see a distinct darker circumference of the opening. If you fixate it on one side you can lift the paper and look where the next opening is to be marked. You can then use the template to transfer the marked openings to the new deck.
- 225 replies
- chaperon
- model shipways
Mike, The thickness you can overcome (if to thin) by glueing it on top of veneer/ very thin plywood. To thick, that can be sanded down. The wood. It's merely a matter of preference, you can get most kinds milled to request. Mick (Yamsterman) has an address in the UK where he get's his wood. It depends also on the amount you care to, or can spend on it. If the decks get stained ... it's merely the quality of the "look" of the wood after staining ... Cheers
- 225 replies
- chaperon
- model shipways
Glenn, Magnificent ... Looking at her two question come to mind: 1. What's the "indent" from fore to aft on the topoutside 2. Looking at the mounted wheel, I get the feeling it is rather small compared to the housing you build around it, why such a height Cheers
I'll PM you for it, we'll grab the bull by the horns ... give me a minute to write it down
- 225 replies
- chaperon
- model shipways
Piet, It looks like you can push the finished hull straight into the water for her maiden voyage, and finish planking the other one ... it's astonishing the detail you got on that little piece of wood, the size of a lamp bulb ...
Mike, Quite a destruction you had to lay the deck. I might have planked the entiry thing not conforming to kit, but that would be me. Still you've made a nice job out of it ... A scale cow ... I would say black and white or tan and white ... probably off white like my Tryumph Dolomite was ... Cheers
- 225 replies
- chaperon
- model shipways
