cog
Everything posted by cog
  1. Druxey, She looks wonderful, I hadn't expected it (thought it bit "cheap"), but she seems to float with those clear pedestals ... Is the greenish roof meant to be oxidised copper like ...? Cheers
  2. It's a marvell ... Even without the final finish they look absolutely smashing ... Cheers
  3. How many re-do's ... ah, it doesn't matter, as long as it looks good!!! That's major fiddly work, Nednad. I like it!!! Cheers
  4. Fam ... I just dislocated my jaw ... that is some major impressive work you've done!!! Very crisp and sharp details ...beautiful ... Cheers
  5. And anther step closer to perfection ... It's fun watching you and learning ... Cheers
  6. JesseLee, Looks good to me, and what's more important, it does the job!!! That's what counts ... Sorry to hear you're still not at full throttle ... I'd hoped you would be movin' an groovin' by now ... Keep your spirits up, for it sounds like your carronades will come out good! Cheers mate
  7. Those are some serious masts Kees. Very nice detail ... curious as to how the lights will turn out Cheers
  8. from 3 to 2/2.5 mm !!! The spice must be flowing ... On the image it seems so much bigger ... very well done ... you've more than earned tha glass of wine Cheers
  9. What size were you looking for, Nenad ... does it keep enough water ... I just don't fancy red for buckets a lot ... do those come in balck or green??? Well done. Nice and tiny!!! Cheers
  10. tat's a kind captain ... he takes the well being into account, even if it is only to keep his crew into shape ...
  11. One may wonder how amazing your builds would be at a larger scale, Igor. So much detail ... so clear and distinct Truly wondeful work Cheers
  12. Tought you had someting to finish here at MSW. Good to see you back at the 'bench', Russ Cheers
  13. Sorry to hear about the slip ... hope that will work out well ... she's looking mighty fine though Cheers
  14. Still going strong despite the absence of Gwen ... thst's good to hear ... She'll be thrilled to be back ... to see you with a platter of Indonesian food in your hands !!! and the big smile on your face, a tidy house and yard and all the other things done she normally does... Keep it up, time for modelling is near ... Cheers
  15. Off to a good start on the rudder again, Mark. Your four footed friend will be very happy and keep his teeth far from it I reccon ... Cheers
  16. Sam, You may question, as long as I am certain about, it it doesn't matter. Since you have found the path less travelled by - as usual - I am hard put to advise ... I would advise you -still - to follow the normal rigging steps, and not look for short cuts, which will eventually be a detour ... Looking rather nice that bowsprit!!! Cheers mate
  17. Clever tool extension, Ed. The strength in repetitive actions is seen in the final result. Making deadeyes or doing e.g. Iaido kata, in the end it is all focused on reaching perfection, and so far you have been on top of it. Cheers
  18. Waiting on a ship ... swell serving job Sam. I'll be trying Alex's machine one of these days, and will compare it to your result, although, you have the edge as a better builder!!!
  19. Hello Clare, The hairspray is used to avoid smudging a drawing, it's not expected to give it a life long protection ... Fixatives in paint are often used to make paint stick tbetter to the object it's used on ... I would choose the matt spray if I'm honest durable and rigid compared to hairspray... or use the fixative with a matt varnish, though I would also advise you to try it out on something a like ... Sometimes the time spent at the art academy isn't to bad ... ;-) Cheers, Carl
  20. The gold looks like a metallic lacquer to me, but that will certainly be the photograph. The other colour ... I would expect some white-ish streaks in it ... with reference to the name
  21. Clare, We used hairspray to fixate charcoal, and pastel crayon drawings from smudging, so I would presume (dangerous word) it would stay a lot longer than a short period. The flat lacker could do the same, since it is 3D, I would hold a sheet of paper behind it to avoid spaying to much ... Cheers Carl
