Papa
Everything posted by Papa
  1. The bow and stern blocks are in and mostly shaped. They still need a bit more shaping, but i will wait until I confirm how the planks will lay down before I take any more wood off.
  2. I have shaped the counter block and started the transom framing. I made a quick jig, not in picture, to hold the frame piece at the correct angle until the glue dried. I will trim the frame pieces to length when they are all in place. I found the counter block was very difficult to get right. There are a lot of angles and bevels. In fact, I messed one up and had to start again.
  3. The side pieces are an excellent idea. i will have to add those to mine. Ron Gove
  4. Finished the bulkheads and, following the building instructions, attached temporary battens along the bulkheads verifying that the spacing was identical port and starboard. I did this by cutting spacers that would just fit between bulkheads at the center keel and then used them to properly space the outside. Only tiny adjustments were necessary because I had been very careful to square up the bulkheads as I glued them in place.
  5. Work on the Morgan has been slow. I am taking my time making sure that each bulkhead aligns to the reference marks and is square to the keel. I am letting the glue set at least overnight before moving on. I have found that shaping the bevels is so much easier with solid wood bulkheads. Beveling plywood is a pain.
  6. On my Granado I thought the supplied chocks were too small and I made new ones using scrap wood from one of the parts sheets.
  7. Your workmanship always amazed me. Your eyes must be like magnifying glasses.
  8. At long last I have started my CWM. This kit has been in my stash for quite some time. I saw no point in photographing the kit contents as there are quite a few Morgan build logs showing the parts. I will note that, contrary to the instructions, the center keel was a single laser cut piece, not 2 pieces. I do not know if this is still the case, but it makes for an easier start to the build. The photo shows my building slip set up to start test-fitting the bulkheads.
  9. Great looking model. You just need a pile of scale "road apples" in the horse pens to finish it.
  10. Your work is an inspiration Dan. Just slow, steady, precise, with attention to detail. I may give card another try. Your build log is a practicum on card models. Ron
  11. Fantastic work Dan. I am giving up on Helgoland. It is not worth the effort it takes. I will stick with wood where I mostly know what I am doing.
  12. Very nice looking model. I did the Monitor about 25 years ago. I used the copper strips i had left over from coppering the Essex to simulate the plating. I embossed rivets (man was that boring) around all the edges. Once painted it look great.
  13. Perhaps the clamps have been improved. I purchased mine quite a few years ago.
  14. I had some of those c!amps. I think I got them from Model Expo. They are not high quality; the metal is soft and after a few uses the screw part snapped off of the handle. Also, they split the bulkheads.
  15. I like the methodical work preparing the keel and bulkheads. Nice job. I hope I can do as well on my next build.
  16. I believe I purchased my hobbyzone ship building jig from hobbyworldusa. Good price and it was shipped promptly.
