Everything posted by BANYAN
That's an impressive build and paint job Greg - that one can go straight to the 'pool room' (an Aussie reference for International viewers :)) cheers Pat
Great progress Danny; looking really good. Its a pity the top card layer (thwarts, bottom planks etc) was not a two-piece set to give a sense of depth inside the boats; other than that they look really good. cheers Pat
Very consistent quality work; a joy to see. cheers Pat
Hi Dave, just to clarify, the 'cleats' not the shrouds kept twisting - not sitting at 90 degrees to the shroud (i.e facing inboard); finally sorted doing it in a similar fashion to you. cheers Pat
Thanks guys, appreciate the feedback and links. Now to order and get manufacturing cheers Pat
Great progress Mark, looks like you have those dockyard workers busy again. cheers Pat
Great detail work and explanation Ed; you would think this was an actual ship being rigged. cheers Pat
- 3,618 replies
- young america
- clipper
Thanks for all the further great ideas folks; much appreciate this. My main purpose of this jig would be to hold small pieces, such as brass strip, in position while soldering. Therefore the main components will be the surrounding frame with slots and articulated fingers and arms (interchangeable) with a soldering/heat resistant base. The ideas of other materials merit further consideration. Eberhard, I am trying to picture those curtain rails as the less manufacturing I have to do the better. Can you post a picture please? The hardest part for me will be making those fingers as finding "Brass' knobs/thumbscrews" is proving much more difficult than I had thought - most eBay offering for instance are aluminium. cheers Pat
That binnacle came up a treat Dave; nice finishes. You have also done a very tidy job on those shroud cleats; they kept twisting on me. Seems you found the knack of keeping them straight very quickly cheers Pat
You have made some great (and rapid) progress with this build Denis; she is looking really good already. cheers Pat
- 378 replies
- t78 norden
- billing boats
Welcome aboard Oscar, look forward to seeing some of your builds. cheers Pat
You are making great progress with Alfred Gary; very nice work on the framing and planking. Some great adice along the way - thanks! cheers Pat
Great work Danny, you make it look easy but I know you put a lot of work into that - the result speaks for itself. cheers Pat
Brass piano hinges
BANYAN replied to Chariots of Fire's topic in Metal Work, Soldering and Metal Fittings
Also try the 'box' making forums, I think they still use these sorts of hinges and may be able to point you to a reliable source. cheers Pat -
Some very nice progress there Denis, looking good! cheers Pat
- 378 replies
- t78 norden
- billing boats
Nice progress Russ, the planking is looking good; I like the colour/tone of the wood you are using. cheers Pat
- 420 replies
- captain roy
- lugger
HMCSS Victoria 1855 by BANYAN - 1:72
BANYAN replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Hi BW and thanks for looking in. As yet I have not been able to relocate that text. I have got in a very bad habit lately of not bookmarking interesting things as I read. I think unhinging of the rudder, while not a common thing, happened more often than we might think as the article I am trying to relocate suggested as much - when hitting sand bars etc. WRT the additional chain, I think in this case these were longer versions of rudder chains so they could be used for steering also. I am forming a 'half-baked' theory at the moment that the 'preventer' element of the chain may have terminated at (shackled to) an eye, and these extra lengths would have been used as required for steering as shown by Harland (see earlier graphic). The interesting bit is this elusive reference to a "Lang's emergency tiller" - similar to a reference to a "Lang's eye in the channels" - I simply cannot find any drawings or reference other than that fleeting reference in the Mechanic's Magazine. I'll keep you posted. cheers Pat- 1,005 replies
- gun dispatch vessel
- victoria
Very nice work on the rudder and fittings Jason. It bodes well for a very nice model with the care and attention to research you are doing. For consideration only, I invested in a punch kit plastic modellers use which can punch many sizes and styles of head from a very thin foil. A bit tricky positioning but they do provide a more realistic result when painted. Not trying to get you to change your current work, just for the future if that is what you are trying to achieve. I have a set of the the Small Shop - The nutter set - for blind, bolts and rivets which I got from Historex - I have no connection with them whatsoever, simply where I got mine cheers Pat
Looking good OC; great progress despite the oops moment cheers Pat
- 455 replies
- slightly modified
- greyhound
Hi Steve, I am building an 1855 launched warship that featured clipper style rigging. I have not come across this before either, but some background reading I did during research for my build may help resolve the question. One of the issues I came across was, that to get sufficient clearance of the bulwarks brom the shrouds due to their lead angles, some channels were extra wide; whereas in some clippers/packets etc this was resolved by leading the shrouds inboard of the bulwarks. The ship I am building only had a low bulwark but some had very high ones to protect gun crews and deck personnel, which was problematical for getting a fair lead for the shrouds. The bulwarks on my build, HMCCC Victoria, were formed from 'roughtree timbers' which were not extensions of the frames etc and therefore were not as strong. Therefore the channels could not be attached to them. Putting this together, perhaps, in the two channel ships, a POSSIBLE reason is that the lower one provided the strength for anchoring the shroud as it was attached to the hull proper, while the upper may simply have been a spacer to clear the rails etc. Ed and co will be better placed to answer this. cheers Pat
Great results from some meticulous planning and execution Dan. As always, your explanations make easy reading and are very informative. cheers Pat
- 287 replies
- michelangelo
- ocean liner
