Everything posted by Gregory
That looks like it is what you want! For application, depending on the surface, I keep it in a plastic squeeze bottle and put a little directly on the surface and spread it around with a soft cloth, eventually wiping off all the excess. For smaller parts, and stuff like masts and spars, I will brush it on and let it sit a few minutes before wiping off.
Dutch yacht by henry x - RESTORATION
Gregory replied to henry x's topic in - Build logs for subjects built 1501 - 1750
Some models are good examples of how people can turn lousy kits into beautiful objects.. ( Eye of the beholder, and all that...) You could spend all day for the next ten years pointing out the shortcomings in thousands of build logs. I don't think that is what we are here for. It's not very becoming to come into someone's log and lecture them about the futility of their efforts based on your superior knowledge. I'm looking forward to the piece of art that Henry makes out of this salvaged model.. It has been really interesting so far. Perhaps a moderator can tidy up the log and get it back to the excellent subject it is.. -
Why? Forgive if I sound contentious, just continuing the discussion; but the worse that can happen is you have to re-glue, and it may have been a weak joint in need of strengthening.. -
I wouldn't worry about getting a perfect match beyond having the two pieces in a straight line. I assume there are going to be some trestle trees or other fittings covering up or hiding most of the joint. If you can, use a small wood dowel instead of the brass rod.. This will give you some play while setting up and a better joint when the glue dries. The seam does not have to be perfect or invisible. Once you build up the rest of the mast and add rigging it will not show. You can also do some fine tuning of the appearance after the glue dries. I often use this method to build up a mast from smaller pieces. Here is a mast I am working on but haven't glued yet.. The joint will not be visible when I am done. I hope this is what you are referring to.. If not will try to clarify.. Gregory
When I suggested stripper, it would be for small painted areas, with a lot of testing; say on an out of sight area, and definitely avoid glue joints. Paint thinner and even water, if left to soak, might compromise glue joints. -
Clean up is looking good. Take your time. You might consider using some paint stripper. Just make sure there is wood under the paint. Use sparingly and maybe several light applications instead of a heavy one that sits for while.. -
You may have to hand-make the shackles with wire and such, but Syren may have some blocks that would work.. There are several sizes of these types of blocks.. Internally Strapped There are several build logs where members are making detailed metal work.. Here is a good place to start.. Build logs for subjects built 1901 - Present Day Meanwhile I will be looking for some links for you.. Cornwall Model Boats has a lot of these types of fittings, but searching for them may take some maneuvering. Here is my search for shackles But other words might produce results for other fittings..
You might browse some of the other restorations to get ideas about cleaning techniques. Remove as many loose parts as you can and clean them individually. A mild soap solution is always a good start. Alcohol and q-tips are another option. For loosening old glue, you might try a hair dryer after you are sure there are no loose parts to go flying away. -
I would remove it just to see if there is some hidden treasure inside..🙂 I would enjoy seeing updates as you restore this.. It looks like a nice decorator model with an antique look .. -
HM Cutter Alert 1777 by muratx - scale 1:48
Gregory replied to muratx's topic in - Build logs for subjects built 1751 - 1800
Chris, Did you overlook this? -
Le Coureur by PC52 - Mamoli - 1:54
Gregory replied to PC52's topic in - Kit build logs for subjects built from 1751 - 1800
Here is an image where walrusguy ( skip down past the ship's boat ) used tissue paper to make hammocks.. Just roll up tissue paper. Wetting it may help to get a wrinkle effect.. You might use some light coloring if you don't wan't it to look too bright white.. -
There has been some talk about this.. Model Shipways USS Constitution Cross section
I really like the way you have several pin vise' for different bits.. I thought I was the only one who did that..
- 778 replies
- cheerful
- Syren Ship Model Company
I really like this little Kit Soldering Iron Kit I t comes with a lot of stuff I am not likely to use, but the price is good. What is great is that it has a variable temp control .. I use the little pointed tip to melt down polyester thread nibs when tying knots.. You can make them invisible..
Hang in over there.. The 1949 caught my attention.. I was born Jan 15 1949 in Hearne, Tx near Bryan/College station. I see by the Farmers Almanac, the temp on that day was 75.. Then on Jan 31 it was -2.9... Brrr. We lived out in the country, so I don't think we had electricity, and pretty sure we didn't have internet..😁
- 778 replies
- cheerful
I have learned a lot over the years. The biggest thing to wrap your head around, is that you can't cover a curved surface, with flat, straight planks. Few kit instructions bother to point that out. To make it worse, they are often curved in more than one dimension. You are doing a great job so far. Most importantly, you are asking questions and not getting discouraged.
One more thing I don't see mentioned, is that in general, the more expensive kits took more to develop, Thousands of man-hours for something like the Caldercraft Victory. The higher retail price helps recover that cost, hopefully make a profit and keep them in business. This is a prime concern when it comes to knock off kits - the producer did not incur those development costs, and their sales price is virtually all profit after a few kits are sold..
It looks like you are not taking into account the amount of tapering needed at the bow. You need to measure the number of planks needed at midship, then divide the area at the bow by the same number. Here is a little section from Chuck's Winchelsea. He is single planking, but you can use the same method on POB. You can practice on first layer and refine the process on 2nd layer.. Don't undo what you have done so far, because it will clean up just fine as a basis or 2nd planking. You may end up with some sharp pointed blanks, but don't worry about that now. Here is a little detail to show the marks ( red dots are mine ) made when lining off the hull and determining plank width.. Looking ahead you will find the area at the stern post may be wider than mid-ship and you will have to introduce a stealer or two, because you don't have wider planks to make up the difference. I'll try to help you later with stealer info, if you need it. I am certainly no expert, but I have had to dig deep on this forum for the help I need.. You will probably see I talk about Chuck a lot, but I have found he is good at explaining things in a way the beginners can understand.
