Everything posted by Gregory
A new angle in precision sanding
Gregory replied to Arcticbeaver's topic in Modeling tools and Workshop Equipment
Just speculation based on a one time post and no further contribution to the discussion. I could be wrong.. Happens all the time.. I'm the suspicious type. -
I think we got spammed.. -
This one looks to have about the smallest footprint I have seen. It appears to be well made. Allwin Benchtop Mini Disk/Belt Sander -
I think I would spend $87 on one of these: Harbor Freight Before I would spend $225 on the " Ultimation " sander.. -
Is this the kit from Occre? From what I can see in the images available the anchor cable is not visible after it enters the hawse hole, so I think you will be good with just leaving it hidden.
The operator has a lot to do with that.. -
The pictures are kind of vague.. Where's the motor? P.S. O.K. I googled it and see there is a hand crank.. Interesting. That would really limit it's usefulness in my opinion. That would be some good information to provide on the web site. -
Do you have any sources for the model? The cover of Marquardt's Anatomy of the Ship book shows a relatively sharp bow, as does this contemporary painting at the National Maritime Museum..
FWIW The long guns on HMS Victory and USS Constitution use the double + single block arrangement as seen in your plans..
- 61 replies
- fair american
- model shipways
Just a thought Chris, you might consider a built up stem of 2 or more pieces where you can get the grain to follow the long axis as much as possible. You are way ahead of me in doing this sort of thing, but I am just learning with a laser cutter, and experimenting with fabricating some embellishments to one or more of the kits I am working on. One of them is the Corel Resolution kit, that comes with the typical veneer stem, keel and stern.. I orient my pieces to align with the grain of the stock I'm using. Still in the early prototype stage for me, but I hope to improve as I go along..
Just noticed a new post to this topic.. Just curious.. I'm wondering how a selection of only 20 kits is a problem for a first time builder?
You will also find that the hoops that hold the sail to the mast will add traction down the length of the mast and also provide points to add a touch of white glue..
I believe the weight of the boom pretty much keeps the sail taught at that point. Someone with more knowledge than me might be able to add to this or correct me..
Here is an online copy of The Elements and Practice of Rigging And Seamanship, 1794.. I didn't see anything about oars.. I'm still looking.. This appears to be what we are looking for. The Elements and Practice of Rigging, Seamanship, and Naval Tactics It is a four volume set, but further googling provided information about oars in volume one. There are excerpts here: GoogleBooks But no complete free version that I can find.
Looking for tips before beginning Charles W Morgan
Gregory replied to spars's topic in Wood ship model kits
You might consider looking at this topic and tidying up build log title.. Before you post your build log please read this - Starting and naming your build log -
Walnut Wood
Gregory replied to scottpollack's topic in Building, Framing, Planking and plating a ships hull and deck
While my link took you to the ModelExpo sheet wood, there walnut strips should be good also. They have always been good about taking stuff back if you are not happy with it.. -
The model kits can also be found on eBay. They show some closeups of finished model details, and they don't look very good IMO.. CSS Virginia for example.. P.S. Just saw Kurt's post; perhaps some kits are better than others...
Walnut Wood
I know there has been some questionable 'boxwood' strips from Modelexpo, but I have recieved some excellent walnut, cherry and mahogany sheets from them. Spend $100 and get free shipping ( while promo lasts ).. WOOD SHEETS At ModelExpo -
In a fabric store or Amazon, you are looking for " tulle " or millinery netting. It would probably require an inspection to check the size of the weave.. Too bad it is sold by the yard, when the need is only a few square inches.. A place like JoAnn's might give you a small free sample, which might be all you need..
Plank Bender....
Gregory replied to dvlp47's topic in Building, Framing, Planking and plating a ships hull and deck
My $.02.. This is my down and dirty basic bender.. -
I understand why a painting would not be a primary source.. However, I have often seen them referenced here for other details, including colors, for other parts of a ship. Why not sails? P.S. I notice in James' review of the cutter Alert kit:
I would also think that contemporary paintings would be a good indication of color..
