Everything posted by Jim Lad
Well, Danny, if you're not making a silk purse, you're at least making a fine linen one! John
Aha! Back in the shipyard - great news, Augie! John
- 2,191 replies
- confederacy
- Model Shipways
The country, type of ship and time period would help, mate! John
Nicely done, Ollie. A good finishing detail might be a painter spliced to that ringbolt forward and coiled down in the bottom of the boat. John
- 803 replies
- colonial cutter
- modellers shipyard
Yep, lash 'em down, Ollie. John
- 803 replies
- colonial cutter
HMS Druid by Krug - FINISHED - 1:48 - Hahn
Jim Lad replied to kruginmi's topic in - Build logs for subjects built 1751 - 1800
Very nice indeed, Mark! John -
I agree with Tom - six oars would be better - and stow them with the blades facing forward as with your test oar in the photo. John
- 803 replies
- colonial cutter
That boat's turned out well, Ollie. It was quite common for cutters to carry their boats on deck (less chance of damage that way) and as King clearly shows his boat on deck, then why not stow it here? You have a clear primary source for it being stowed on deck! John
- 803 replies
- colonial cutter
By the look of all that fiddling, it might have been just as quick to plank the entire gun deck in the first place! John
- 165 replies
- united states
- revell
Perseverance pays off! Nicely done, Bob! John
- 420 replies
YES!! Progress!! Kats, Question 1: If the boats were stowed under the davits, it was common to simply drop the coil of the fall into the boat. If the boats were stowed elsewhere, then it was usual to turn the davits fore and aft and cross the falls, hooking the lower blocks onto the opposite davit. In this case, the falls would be coiled up on the cleat where they were secured. Question 2: If the anchors were stowed for sea, the cables would be unshackled and brought inboard and the anchors stowed on the forecastle. If ready for letting go, then they were either hung off the cathead with a slip or hung off 'stock and fluke' as in the drawing below. I would think a ship such as the Cutty Sark would let go 'stock and fluke'. John
- 237 replies
- cutty sark
- revell
Every little bit you manage is a delight to see, Toni! John
- 1,449 replies
Plated Iron Hull
Jim Lad replied to Pete Jaquith's topic in Building, Framing, Planking and plating a ships hull and deck
Pete, It should work well providing it's thin enough for scale. Remember that you tug's hull plates would probably only have been 1/4 or 3/8 inch thick. John
