Everything posted by dvm27
Personally. I think those cap squares look terrific, Chuck. Most appear oversize. Yours look perfectly to scale.
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Nice job Siggi. I find those drift rails incredibly hard to fit at the hances. Are they steamed or cut to shape?
Yes, by all means remake these hideous trial versions Michael. They'll look exactly the same to the rest of us but you'll feel better!
- 2,214 replies
ancre La Belle 1684 by Oliver1973 - 1/36
dvm27 replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Curse you Oliver! I'm already spending too much time on YouTube and now I've had to add you to the list. My favorite La Belle model used to be Glen Grieco's version done at Texas A&M but your model is giving it a run for its money. -
HMS ROYAL KATHERINE 1664 by Doris - 1/55 - CARD
dvm27 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
These are magnificent examples of mixed media use in ship model building, Doris. Do they not have dust in your country? I wonder how you keep these masterpieces in pristine condition without being encased. Whatever will you do next? I hope you will share it here. We talked once of your publishing a book based on your techniques. Did that ever come to fruition?- 1,035 replies
- royal katherine
- ship of the line
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
dvm27 replied to Bitao's topic in - Build logs for subjects built 1851 - 1900
Very sorry for your loss. I always found my workshop a place of solace during times of grief. Hopefully it will for you as well.- 257 replies
- young america
- Finished
I can see your work improving as you progress, Kevin. Great job on the bowsprit step. I too still use my Preac saw and it's great for small jobs. Don't know if you ever purchased the motor upgrade but it's fantastic and makes the saw even better. Check out http://shipahoymodels.com/equipmentforsale.htm
- 1,126 replies
Swan-Class Sloop by Stuglo - FINISHED - 1:48
dvm27 replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
The framing plan is a rough indication of where things are located but use the sheer plan lofted by David Antscherl for actual locations and heights. All gun and sweep ports, as created by installing the sills, should run in a fair line from fore to aft. Maybe use a thin batten to insure they are all in a fair line.- 475 replies
As Druxey said buy an architects scale on eBay. Using full sized measurements, even if not ones you are familiar with, will eliminate a layer of potential error. After awhile you'll pick up this arcane system of measurement pretty quickly. Plus, when working with full sized numbers an alarm bell will go off in your head when your piece is way too small or large based on an errant calculation you made.
Non-pet owners sometimes have a hard time understanding how deeply we mourn when we lose a pet. Twenty years is a long life for a cat but that does not diminish the loss. Tyra was lucky to have such caring and compassionate owners and I know she lived a wonderful life.
- 2,214 replies
I have the pleasure of owning a copy of Prisoner of War Ship Models by Manfred Stein, While some of them are a bit crude in their appearance others are exquisite works of art. Like Navy Dockyard models many of them were built by committee and by some of the finest craftsmen of their day.
- 95 replies
- POW
- Bone model
Add me to the group Chuck. Greg
Your setup in the second photo was very informative. Your use of a plywood scrap with a hole drilled acts as a steady rest for the mill and I shall use that in the future for sure!
- 589 replies
- le gros ventre
- cargo
Cap Rails
dvm27 replied to SeaDoc's topic in Building, Framing, Planking and plating a ships hull and deck
You can turn your hull upside down and place it over a sheet of cardstock or thick paper. Trace the outside profile of the hull onto the paper with a pencil. Cut out the profile, place on the model to insure it matches then draw an offset line to the inside of the cap rail to the required thickness. Works well for me. -
Making and using a draw plate
dvm27 replied to Don Case's topic in Modeling tools and Workshop Equipment
Just curious, Don, what scale model are you making? With the Byrnes drawplate I can draw bamboo down to a no. 79 drill bit hole but there is a lot of wastage and a lot depends on the quality of the bamboo. If you're working in 1/4"-1ft scale I should think nos. 70-76 should cover most of your trunnel needs. -
Apron frame rebates
dvm27 replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
The Fully Framed Model by David Antscherl (SeaWatch Books). I can't imagine building a Swan class without having the book as a reference or the Swan 3D virtual build (www.admiraltymodels.com). -
Apron frame rebates
You are indeed correct that the apron is extremely difficult to make, Don! Took me several tries to get it right. As the width of the lower apron tapers from 18" to 10" over it's length your strategy might be difficult to employ but perhaps is doable. You would first need to make the lower apron to the correct dimension (12" tapering to 10" aft - chapter 1.19 in TFFM). Then you would need to add the 3" stepped line to either side and taper it to fay into the apron at the bottom. No matter how you do it check and double check that the steps line up on either side of the lower apron both horizontally and vertically. I found it much easier to do this with my Sherline mill but others have successfully done this with just a sharp chisel. Care, deliberation and patience is required here! Oh, and the stern deadwood stepping lines is no cakewalk either but should be easier after after completing the apron. Have you started a build log? -
Great video, Kevin. Wish I could attribute my building issues to termites but there's snow outside! Couple of comments: 1. Using those pencil marks to fair the inside of the frames works as well as on the outside. Those concave surfaces are hard to fair, especially in the bow and stern. 2. Great fix on the transom knee error. Is the wing transom upper edge at the right height at the outer counter timber or did you need to raise that as well? It seemed to be flush with the lower transom knee in the video before repair. 3. The deck beams can be recessed in two ways. You could cut 1" mortises into the deck clamp to receive the beams or notch the ends of the beams 1" to fit over the clamps. I found the latter infinitely easier to do although you need to be carful that they are installed in the proper location after cutting the recess.
- 1,126 replies
We've missed your updates, Michael. I'd almost forgotten how beautiful this model is. That wood grain would look gorgeous in a full sized yacht!
- 2,214 replies
