Everything posted by dvm27
Very nice job, Kevin. I like the way you've integrated the 3D images into the construction. It might be a perspective thing but the lower deck aft hatch seems skewed to port in your photo post 241.
- 1,132 replies
Swan-Class Sloop by Stuglo - FINISHED - 1:48
dvm27 replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Nice job on those fore cants so far. They are a bear to fair, especially the inner surfaces. I find that drawing lots of pencil lines along the shear helps with the fairing process. Keep remarking the lines during progressive fairings until they all disappear. This will insure you have hit all the low spots and have a fair hull. Work from the fore cants aft and I would recommend you install the first full frames (14) before completing the cant fairing. 80 grit garnet paper and a series of shaped flexible battens with sandpaper glued on really help in this area. Also, those spacers between the cants will likely pop out during the fairing process but take the time to re-glue them in place. Once you get to 5 or 6 inches molded dimension the cant tops are very fragile and you don't want to tear one out. One final thing to consider regarding the extensions of the cant frames for the timberheads. If you are a talented carver and plan to shape them in place ignore the following. I amputated the timberhead extensions so I could perfectly shape the shear line where the forecastle plankshear will eventually seat. It is very difficult to carve the timberheads in place and equally difficult to achieve a fair line for the plankshear as well with them sticking up. With the timberheads not present it is very easy to get a smooth run by using a sanding stick athwartships. The timberheads are later shaped (I used the Byrnes saw) and applied after the plankshear is in place. This project is like a chess game - you need to think several moves ahead!- 475 replies
The rafts look terrific Keith! The amount of bright work on this vessel is unbelievable. Keeping it looking good must have occupy a huge part of the crews time.
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
dvm27 replied to Bitao's topic in - Build logs for subjects built 1851 - 1900
Have you left us HYW? Your initial posts leave us longing for more...- 257 replies
- young america
- Finished
Bob is not mailing these from his basement. Once he receives the order he contacts the distribution center and they in turn fill the order. I suspect distribution and the USPS may be part of the delay during Covid. Before Covid I always received my orders in 2-3 weeks. Order acknowledgements have never been done as far as I can remember.
Here is a link to an article Roger wrote. There are hi-resolution photos and I'm betting you're not going to like what you see. But it's a beautiful model. https://www.craftsmanshipmuseum.com/BuildingAlert.pdf He also published articles in the NRJ regarding planking and coppering: “Clenched-lap Planking Over a Framed Hull,” Nautical Research Journal, Vol. 44, No. 4; and “Coppering a Clenched-lap Hull”, Nautical Research Journal, Vol. 45, No. 1.
Very nice Toni! I admire your desire to make everything yourself. I might have purchased the copper rivets and roves from Scale Hardware https://model-motorcars.myshopify.com/products/rivet-1-8-mm-head-diameter-copper-k109?_pos=4&_sid=f8b163f3f&_ss=r but perhaps they're not small enough.
I've had a couple of slices from my miniature table saw, all the result of poor techniques and not paying close enough attention. Nothing that surgical cement couldn't handle. But I don't think I'll ever get a full sized table saw.- 475 replies
Well done, Toni! That took a lot of guts to do at this point. I've been spending time looking at small contemporary models with square tucks and many of them have the fashion pieces. Something I never noticed until David Antscherl pointed it out.
Welcome to the "I have knocked off an aft cant with my elbow" club. Your are not the first member of this club! Follow Druxey's advice - a sharp chisel makes all the difference.- 475 replies
Although I've no doubt that you will tweak the design 12.75 times before settling on a a final version I very much enjoy seeing how an architect's mind works. Most of us are happy to achieve something that looks right. You are only happy when the design is not only aesthetically pleasing but actually works from a human perspective.
Much better Stuart! Agree with Druxey about those pesky hawse holes. And that Viagra tool organizer you have should keep them erect.- 475 replies
Not quite sure why you didn't check out the Byrnes drawplate. It is superb and draws down to a #79 drill hole size. Plus it costs less than what you were looking at! https://www.byrnesmodelmachines.com/drawplate5.html
Welcome back, Kevin! You have made excellent use of your time away from Thorn and I look forward to further progress and more great videos.
- 1,132 replies
When in doubt it's best to follow the text. Paper can shrink or swell depending on the humidity and that can certainly cause an inch (scale) discrepancy.- 475 replies
Three years down the road when those delicate knighthead corners are chipped and dinged you'll realize it's quite easy to replace them by amputating from the forecastle planksheer up, creating new ones and grafting them back on. The small ones are easily created by forming a short parallelogram of stock then slotting the recesses on a table saw (or mill).- 475 replies
Enjoying you build log Stuglo. I spent almost a decade on this fully framed model. Early mistakes are inevitable. The key is to recognize and correct them. Everything you do next year depends on the accuracy of what you do now. I can't tell you how many times I whipped out the isopropyl alcohol my first year and replaced a bad part. Ungluing is incredibly easy with PVS glue (sometimes scarily so)! Looks like you've done a very nice job so far on the stern transoms. Don't forget to view the excellent logs of Tony Levine and Remcoe.- 475 replies
