Everything posted by bhermann
HMS Victory by Sven - FINISHED - 1:600 scale
bhermann replied to Sven's topic in - Build logs for subjects built 1751 - 1800
Matt - congratulations on completing her. Fabulous detail at such a small scale. I too am looking forward to the next project! Bob -
Chris - The tools I have used so far for working with brass: round-nose pliers - for shaping all those bands side cutting diagonals - for cutting brass strips to length small files - to even the ends and shape pieces punch - for centering drill bits pinvise - to hold the drill bits while hand drilling holes in the brass strips butane torch - for annealing brass (to make it easier to work) and for soldering silver solder brazing paste - for soldering cross locking pliers, third hand tool - to hold the brass while applying heat while soldering All items were purchased though Model Expo (except the soldering paste - I think that was Amazon). Hope this helps. Bob
Dave - that is some nice looking work. After reading your comment about the upper end of the jumbo jib stay, I had to take a closer look at the rigging plan. What you did matches the plan nicely. To me it seems a little iffy for them to wrap the stay around the base of the topmast, but I suppose that after the topmast shroud is rigged there isn't much chance of the base popping out. Bob
- 95 replies
- bluenose
- model shipways
Try replacing the "'," with "." and it'll make more sense: 1.5X5 - It is just a different notation for the decimal point. Definitely not a stupid question, just a translation issue. By the way - it'd be great if you could start a build log for your work. We love to see other builders progress around these parts! Bob
Jay, am I reading to much into this or did you put the model in a window, or out on the porch, to catch the breeze? Regardless of method, I look forward to seeing what the end result looks like. Bob
- 732 replies
- constitution
- model shipways
Jay - Yeah I can see where the bearings would have an issue. I had this crazy picture in my head of them all laying side by side in a well-behaved sheet, ignoring gravity and the tendency to roll. Hmmm... maybe aquarium gravel I will be following with great interest. Bob
- 732 replies
- constitution
- model shipways
Silver Soldering Tools
bhermann replied to bundybear1981's topic in Metal Work, Soldering and Metal Fittings
Jason - one of the things i have found most useful is that the silver solder tends to flow toward the heat source. I learned this from someone on the old MSW. It was counter-intuitive to me, but it made getting good bonds much easier than it was when I first started, when I assumed the flame would push the solder away from it. Bob -
Sjors You are off to a good start - and it looks like the cannon is properly aligned to fire between the deadeye lanyards, always a good thing. There are some tight tolerances there. Bob
Hmmmm... I think I get it, Sjors - wait a minute - you're describing my log!!! A post here or there with very little activity in between. I guess I am just not the gracious host you are - for example, I've never offered anyone coffee over there. In any case, my post was done with tongue firmly planted in cheek - just having a little fun, no offense intended. BTW - I did finally go back far enough to find a photo of your work (18 pages back, I think ) - it is really looking great - I will be following more closely from here on out. Bob
JP - On the surface this sounds like a recipe for trouble. I could picture myself doing the bow section followed by the stern section, and when I got to tye midships section having a different number of strakes on either side, resulting in having to put a drop plank or stealer amidships! With the amount of planning and attention to detail you are putting into this, I'm sure you won't have any such issues. Remember this is from someone who wound up with a pretty weird looking plank in the middle of my hull and consider the source. Thanks to your detailed description and documentation of the process, I'm sure my next project will turn out much better and more life-like. thanks for putting in the time and effort it takes to provide this useful information! Bob
Thanks for sharing your trials with the sails Jay. This type of information seems to be hard to come by. My (completely unfounded) observation. Have you tried putting more bearings into the sail while it is drying? It seems that you might get a better "belly" if there was more in there. Of course the additional weight may be too much to handle. I'm sure you will get these to where you want them, looking forward to watching the progress! Bob
- 732 replies
- constitution
- model shipways
Rod Spell check isn't a feature of the Forum, it is something that needs to be enabled in your browser, and how to do it is dependent on which browser you are using. Check out this topic for some more information: http://modelshipworld.com/index.php?/topic/534-spell-check-and-measurment-converter/ BTW - I agree with Russ. The stand looks really good - I like the reasoning behind using oak.. Bob
- 127 replies
- model shipways
- syren
Dave - I tracked down the wire and did the 'wrap around a dowel 10 times and measure" trick. Diameter works out to .012" for the footroopes, looking at the plan calls for .010, so not too far off. Bob
- 43 replies
- bluenose
- model shipways
Dave - glad to hear you caught the jumbo bail problem. I'm still not sure i have mine far enough forward to miss the traveler block, but it'll all work out somehow. On my build the footropes are wire and the stirrups are black sewing thread. I did use an individual strand pulled out of some speaker wire for this. I don't know what the gauge is, but it looks thinner than the thread, I can't locate my source material at the moment, but I'll have a look around and see if I can get more detail for you. I am not completely happy with the result. Getting the wire shaped properly - and then maintaining that shape - was a bit touchy for me. Bob
- 43 replies
- bluenose
- model shipways
I like the contrasting colors you are creating with the wood. This looks like it will be fun to watch... and a model we don't get to see that often. Bob
Rod - i don't know how I missed this one on MSW-1, but she sure is looking good. I love the way the bowsprit rigging came out. Getting those footropes to sag "naturally" is a pain in the butt - you did a real fine job there. Referring back to your original post - when Neil Armstrong was walking on the Moon, I was building those paper LEM models you could get at Gulf gas stations - I must have had 10 of them around the house. When I get to my Flying Fish, I'll be sure to come to you for advice! Yours looks really nice - even after all the years. Looking forward to following this as you progress - thanks for sharing. Bob
- 127 replies
- model shipways
- syren
Jim - it's good to hear you are getting back to it. Sounds like you've had a bit of a rough road - hopefully all is turning to the good now. So no one will think I am slacking completely, I attached the block for the staysail throat halliard to the spring stay bail. I must remember to keep it on the port side when I get around to attaching the stay, as it belays to a pin on the port side of the foremast saddle. Bob
Good to see your log resuming Dave. I remember admiring those futtock shrouds when you originally posted them... hmmm, maybe it's not too late! Bob
- 43 replies
- bluenose
- model shipways
Hi Dave and Floyd - I made my first step in preparing for the sails.I picked up some HB graphite pencils and a sharpener. I am not keen on folding over the edge of the sail and sewing because I think the bulge made by triple folding and sewing through it would be too much for the scale. The plan shows the edging on the sails to be a little less that 1/8", which would scale up to just under 8 inches on the real thing. I was thinking about getting some 1/4" tape and folding it over the edge so it comes up 1/8" on both sides, but Floyds post has me thinking that if I could find 1/8" iron-on seam tape and just use it on one side, that might be better. I could also use it for the reef bands. I feel a bit cheated that I have lost all reference to both your logs - in Floyds case, all three logs (the LSS, DDM, and MSW-1 versions). If either of you were to post details of your experience as a guide, say in the Masting and Rigging forum, I would read them avidly!!! (and I'm sure I wouldn't be the only person interested.) Bob
Thanks for the info, Russ. I am going to follow the plans on this one, as I have no contradictory evidence - and few (if any) of the photos on the Nova Scotia archive pages show mast-top detail at all. I think it's safe to write this one off as a regional difference. Keith - the two materials feel very similar in thickness. The pillowcase is a little more translucent than the sheet material, another reason for me to go with the sheet. I nave considered using modelspan, or silkspan, but photos I have seen of those materials seem even more translucent. My feeling is that opaque is the better way to go here, all else being equal. Bob
Dead Eyes (avant premiere) - moved by moderator
bhermann replied to stelios's topic in Masting, rigging and sails
That is some clean looking work, Stelios, especially at that scale. Thanks for sharing. Bob -
I found the rigging for the fishermans staysail in a detail on plan sheet 5 - along with a note that describes how the sail is lowered to the deck to change sides. I guess I had the right idea, now I just need to execute on it. The throat halliard runs through a block hooked to the spring stay bail and the tack has a pendant with a fairlead that the throat halliard runs through. I think I can handle this! I may become a sailor yet! There is no indication whether the hook is moused or not. I think it would be to keep the whole thing from dropping to the deck when working the sail. Bob
