Everything posted by druxey
Nice result for your first model. Well done!
- 12 replies
- Model Shipways
- Lowell Grand Banks Dory
Kits are generally designed so that a minimal number of hand tools are needed. Here is a typical example: https://modelexpo-online.com/assets/images/MS1471 Norwegian Sailing Pram instructions rev 3-29-21.pdf Pages 40 to 43.
Interesting, Alan. I thought that this might be a typo, but, on checking the other tables in Steel, I see that all ships down to 64-gun size have 4 'extra' deadeyes and four shroud pairs. The 64 has 2 extras and rates below do no have any excess deadeyes. The main top for a 74 shows an outline of the top only and the 36-gun ship shows four slots a side (Plate 5, Volume I).
A magnificent piece of music, JD! I've had the privilege of singing it (chorus!) a few years back. But I digress.... Carving at such small scale is tough. Do you have good, directional light to work by, Mark? That alone can make a huge difference. A few years ago I invested in a set of miniature carving tools from Mihail Kirsanov. It improved my success rate considerably.
HMS Discovery 1789 by Don Case - 1:48
druxey replied to Don Case's topic in - Build logs for subjects built 1751 - 1800
I've seen draughts where the ends of a breast hook come through a deck, but not a sleeper. It's possible that as a merchant ship Discovery was not fitted with sleepers or that the aft ends of the sleepers actually came up through the deck. Sometimes only a Time Machine will give the definitive answer. In the absence of one, you need to be master shipwright and decide. -
HMS Euryalus 1803 by rlb - 1:48 scale
druxey replied to rlb's topic in - Build logs for subjects built 1801 - 1850
You'll find that different authors have different preferences. Choose your poison! You are master shipwright in your own yard.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
HMS EURYALUS by Matiz - FINISHED - scale 1:56
druxey replied to matiz's topic in - Build logs for subjects built 1801 - 1850
Nice progress. However, other builders have found that seasonal wood expansion and contraction can distort the hull. This can be prevented by leaving very small gaps between the fillings and frames every few frames rather than packing them all in tightly. -
Even if not fully authentic, you've caught the spirit of the time!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
We are all nervous when trying a new thing or technique for the first time. I was terrified of silver soldering until I actually did it. It really wasn't so bad. Just remember not to touch metal until it's good and cool! Soon you won't think about it twice when annealing.
- 160 replies
- Model Shipways
- norwegian sailing pram
There could be a sliding cover. However, hinged covers were often made in two halves, not a single piece as in the Marquandt illustration. Open, they took up less real estate and each half was, well, half the weight to lift. Harriet's sliding cover, 1843 (Royal Museums Greenwich) Of course, the cover could simply be grating for ventilation and a solid cover for heavy weather. The indication of the rabbet in the coaming suggests that this was the likely arrangement in this case. The 'extra' coaming on the sheer and profile that you show might be for a sliding cover. I am confused as deck plan says 'as fitted' and the sheer and profile 'as taken off' on the same date. Did the draftsman simply forget to add the aft extension, or was it fitted after the deck plan was drawn up?
NAIAD 1797 by Bitao - 1:60
druxey replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
I understand your position on this. You need to be happy and satisfied with your work, however good it may appear to others. Looking forward to your second start. -
I'm sorry that you are not happy with your work so far. It looks to be of very high quality to my eye. What exactly is unsatisfactory?
