Everything posted by druxey
Is it possible that you know someone who can cut wood to size for you? Are there other model-makers in your area that might have the equipment to do this for you or, if you are familiar with using power equipment, might have some time to use it? Well-seasoned, straight-grained wood should be dimensionally stable enough for your purpose.
I don't understand why you feel that you need to laminate up a keel. Using solid wood, held straight in a building jig, should be more than adequate. Am I missing something here?
Glad that you spotted the reproduction shrinkage early: this is a common issue even with good printers.
- 43 replies
- mediator
- first build
4 jaw chuck for a Proxxon lathe??
druxey replied to md1400cs's topic in Modeling tools and Workshop Equipment
I believe that the DB 200 takes a 12 x 1 mm metric thread. -
Allan: Riding bitts, as their name implies, were always used when at anchor. This would place a lot of strain on the bitts in a forward direction, further securing the cross-piece in its score as well as abrading it. The wear piece would be presumably simply nailed on for frequent replacement and the main cross-piece less often, but must have also worn on ts upper and lower sides. Anchor handling would not require use of riding bitts unless there was a problem bringing the cable aboard.
I take an alternative approach and file out the half-holes almost to size in the hawse timbers before assembling them on the model. This automatically puts the holes at the correct upward angle and parallel to the long axis of the model. Also, there is zero risk of tear-out by drilling. Ah, well - on your next model!
mast tapering fixture
druxey replied to Bob Blarney's topic in Modeling tools and Workshop Equipment
It's a form of drawplate, Jim. It would work really well on a long-grain wood like bamboo. Usually drawplates are the moving part (hence the name!), with the wood stock held stationary. -
Sea Witch 1846 by Zooker - RESTORATION
druxey replied to Zooker's topic in - Build logs for subjects built 1801 - 1850
Strange as it sounds, Mark is correct. Just keep a few slices of lemon handy. -
Well, it wasn't obvious - until you pointed it out, Steven! Your observations about 'halfway through' and now going downhill are right on. The ensemble effect of thr mass of rowers now looks great.
I'm sure you'll find it a nice change from carvel planking, Toni! Looks like you are off to a good start, but watch for the staggering of butt joints.
Well done indeed, Vaddoc. We've enjoyed following your journey on this. As has already been asked; what is next?
So, what would a shipyard worker of the time have done? "Ach, das war dumm!"
- 179 replies
- shipyard
- wütender hund
I believe that it's: Row, row, row your boat Gently down the stream, Merrily, merrily, merrily, merrily, Life is but a dream! But we digress again. Nice to see the population increasing, Steven.
YOUNG AMERICA 1853 by Bitao - FINISHED - 1:72
druxey replied to Bitao's topic in - Build logs for subjects built 1851 - 1900
Nothing short of superb work, HYW.- 257 replies
- young america
- Finished
What a fun project, Kevin! Nicely done indeed.
- 72 replies
- fishing boat
- artisanal fishing boat
