druxey
Posts posted by druxey
  1. For scuppers: My method (waterway in place) is, first accurate mark-out both inboard and out. Drill with a very small diameter bit from both sides. Hopefully the holes will meet - at least partially. Then progressively enlarge using larger diameter bits and needle files, making minor corrections as you go until you reach the diameter of the scupper.
    I've not drilled hawseholes in years. I file the half-holes in the hawse pieced before assembly. Again, I make them slightly under final size, then file them out once planking is complete.
  2. I've also had this problem to solve. I cut a blank, longer than the finished ellipse, and PVA glued it to a backing block. This reduced the chance of breakage cross-grain. I then very carefully scratch molded the section. After soaking the piece off the backing, I was able to cut the joints with the straight sections of the moldings.
    If there are any 'tricks' to this, a really good piece of boxwood is needed and patience while running the molding along it.
  3. If the antique wood is a little brittle, you may be able to restore pliability as the veneer folk do: a very dilute solution of glycerin in water. Spray the cut strips and let them dry between sheets of plain newsprint under weight for a couple of days. (It may take longer in regions of higher humidity as it takes longer for the water content to evaporate out.)
