druxey
Everything posted by druxey
  1. Only just come across your post, Mark. Your dating of this document sounds very plausible. Given the thickness of the brackets as 6", and their spread from 1' 6" to 2' 0", the breadth of the brackets must be 2' 2". A drawing of a 32pdr carriage, 1732 pattern, measures exactly 2' 2" (Caruana, Volume II, page 375.) Hope this helps.
  2. Off to a good start, John. Look forward to your progress, however slow!
  3. Sorry that you have to interrupt your build, Christian. Hopefully you will have a bit of time to enjoy the Rijsmuseum if you are in Amsterdam. Best wishes with the project.
  4. Congratulations on the completion on your opus magnum, Nils! That is a very nicely well-populated model. One tiny suggestion, if I may: drape the flags in a natural way rather than have them stick out stiffly. But she looks magnificent. Well done!
  5. Good to see you back and more progress, Tecko. I'm sorry that you have had grief since last posting and hope your health issues are resolving. Quite the bundle of wires! Neatly done.
  6. Very nicely done, Frank. You are very brave to use a rotary tool to cut the octagon! Enjoy your break.
  7. Lovely, Ed: although I think you mean a tick strip. Ticks are marks (or a nasty little insect!) and tics are involuntary muscle twitches. Hopefully you don't suffer from the latter!
  8. There are several plans of Princess Royal, 1773, in the Royal Museums Greenwich collection .
  9. Sweet! What specie of wood are using to plank with, Maurys?
  10. Looking good, Mike. Keep those pencil lines hair thin for accuracy!
  11. Third attempt is a charm, Ed! Very, very nice work on this complex spar.
  12. Those are great suggestions and, no, I'm not laughing. It makes an excellent subject for the Janeites! All the best with your presentation.
  13. Coming along. Soon it will be time for the whiskey strake!
  14. Any decorative work would have been hollowed to fit over the wales: these strengthening strakes would not be cut into and weakened. However, you are correct that there would not be spaces between these pieces.
  15. The man in the photo, Dan? Purely there for scale comparison and your convenience. Nice work on the deflectors.
  16. Not odd. If you tied up in a ship's boat off the stern quarter (there was a swivel bolt under the aft part of the mizen chains), the boat would be towed aft of that. The ladders were a convenient way for sailors to come aboard. Only officers would come aboard via the entry steps on the side. Stern ladders (according to Steel) were of worn rope, with 'common treenail' treads.
  17. Yes, I visualized eyebolts in the deck and eyesplices and the bottom of the ladder, connected by lashings.
  18. Hmm... Life was cheap in those days, I guess, but one could not replace mariners in mid-voyage! I've no firm evidence, but surely the lines must have been attached to bolts at deck level? In a gale, that length whipping around would endanger those on deck as well as gear aloft.
  19. Try pre-bending with a slight over-bend. Allow to dry free in air. You should be able to 'massage' the plank to conform to the hull once dry.
