druxey
Everything posted by druxey
  1. Well, that's a drag. Sorry to hear about that, Alan. Hopefully it will not derail your life (or model-making!) too much.
  2. Well done, getting the port openings so nicely aligned.
  3. Thanks, Maturin. Books and paper? That is a specialty indeed.
  4. That is the largest collection of 'spare parts' lying on your benches that I think I've ever seen, Gaetan. The already assembled parts look terrific.
  5. Interesting: I wish I could read the small print! What was the conference, Maturin?
  6. Figuring out the shift of planking is always a 'do-over' task to make things fit well! However, it's usually three strakes between each butt, not two.
  7. It's a conundrum: either you cut the port openings as you go on a somewhat unstable framework or complete framing first, install longitudinals and then have a solid hull to cut into. Of corse, it's with tighter elbow room! A third alternative is assemble all the frames temporarily, mark the line of ports, then disassemble to do the cutting before permanently re-assembling.
  8. I believe WOP is the acronym for 'Wipe-On Poly(urethane)', Wefalck.
  9. Looking good. After you've done a few hulls, it will be much easier! The first time is the toughest.
  10. It's interesting to note the variations in direction of keelson scarphs. On my present model the pieces were installed starting aft.
  11. Great progress, Frank. I can imagine the awkwardness of planking that bulkhead in situ. And the language that accompanied it!
  12. As usual, you live fully up to our high expectations of you! Lovely work.
  13. Did you look at David Antscherl's planking tutorial? That speaks to this topic.
  14. Good progress, Steven. Is there a reason you didn't plank both sides in tandem?
  15. These elevation marks were made and used only on land-based ordnance. Obviously they would be useless at sea!
  16. Just caught up with you as well, Drazen. You use some interesting strategies with excellent results. Looking very nice!
