druxey
Everything posted by druxey
  1. The deck 'droop' at the bow was called - wait for it - camber. (Deck beams and decks 'round up'; decks do not camber across.) The usual reason for this forward droop was so that the cables came aboard above the deck without the hawesholes being placed to interfere with either headwork or a wale. In this case it would help control recoil.
  2. Mike: if you are using PVA or similar for thinner pieces, wet the back of the piece first to eliminate curling. This will even out the moisture that causes the curl.
  3. Good to read that the shipyard is back in business. Check the wet dock gates on the next spring tide!
  4. Taken in context, one can usually figure out the odd error.
  5. Excellent advice from Allan. If you can afford it, the Byrnes unit is the way to go.
  6. Well done on crossing the finishing line! That looks very nicely done indeed.
  7. Ideally acid-free rag paper would be the best option for frieze work. On old museum models you can see the 'laid' paper lines through the paint. Now, this may sound heretical, but I use regular 20lb paper. It is stretched like watercolor paper prior to painting using acrylics. As the front of the paper is sealed by paint and the back adhered with PVA, it is sealed from the atmosphere and is not likely to deteriorate. However, I'l let you know in 200 years.
  8. Nice work on the junction between the pieces, Siggi!
  9. Welcome aboard, Dave. I have happy memories as a student, spending weekends in Suffolk. Ah, those were the days....
  10. I'm sorry to read that the model is too large to continue. The work you have done is first class, Karl.
  11. So sorry to read of your calamity, Alan. I hope that you did not lose many things.
  12. Those waterway pieces are seriously impressive! Well done. Mark.
  13. Well done to get to the finish line, David - so many don't! One small suggestion: the ensign. Normally wind blows from aft, directing the flag forward. Also a natural fold would improve the look immensely. Just a suggestion - it's your model.
  14. For painting frieze details you need to invest in top quality sable brushes. Try Winsor and Newton Series 9 or Rosemary & Co. Expensive? Yes, but properly cared for they will 'point' beautifully and last a lifetime.
  15. Nice. Getting the lines not to torque is always a challenge!
  16. Mike: There are no contemporary draughts (I wish!), just a van de Velde painting, a copy of another van de Velde, now lost, and a v de V drawing of 'de fob'. There is also a contemporary model in private hands that is an 'Admiralty' style model that we have identified as Fubbs. The findings of the SYRG will get published, but the manuscript is still in preparation with no date yet set.
  17. For many years there has been confusion over the different versions of Fubbs. The one you show here is the 1724 rebuild, not the 1682 original Fubbs. The original had a straight cutwater, more vertical stern post and a taller, rounded tafferel. The inboard arrangements were very different than that of the rebuild. That the above statements are accurate is part of the result of several years research by the Stuart Yacht Research Group, a small international group of historians and model-makers of which I happen to be a member.
