Everything posted by druxey
ancre La Belle 1684 by Oliver1973 - 1/36
druxey replied to Oliver1973's topic in - Build logs for subjects built 1501 - 1750
Daß ist echt! Very lovely progress, Oliver. She makes a very sweet model. -
I would be hesitant to bend the beams. Wood has a way of reverting to its previous form if not bolted or treenailed in place. The larger piece with the round-up shaped, then parted off, is a better choice. The underside can be milled in if you have the facility. If not, cut the individual beams from sheet and finish them on shaped convex and concave sanding blocks. That is the way I make my beams these days. Looking really nice so far!
No Idea: The square tuck, if almost above water level, will not really affect the rudder's effectiveness. However, if the tuck is deep into the water, the rudder will be in its 'shadow' with water turbulence in that area as the ship moves through the water. This situation means that the rudder is less efficient.
Impressive. Marc. Might I suggest thinning the angels' lower feet a bit, though? They ain't hobbits!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Mark-out is also critical. The finest pencil line possible helps a lot. A regular HB pencil doesn't cut it; use a mechanical clutch pencil with 2mm leads of 3H or 4H grade. in the purpose made sharpener. These give a really fine line. Then you can cut with confidence without wondering whether to aim for the which of the edges or middle of the line!
The wishbone assembly looks very nicely done, Bob. I applaud your idea of adding the safety rails and bimini to your model. That will certainly set it apart from any other iteration.
- 111 replies
- Nonsuch 30
- Model Shipways
Welcome aboard, indeed. Check out Marine Modellers of Niagara on this site.
Well done. The line that you aren't quite happy with could be straightened with a little water and then some dilute acrylic matte medium.
Nice work, Bob. Those wishbones are a little tricky to shape, no? BTW, i never keep my coffee or any other drink in the workshop area. All it takes is one spill....
- 111 replies
- Nonsuch 30
- Model Shipways
Those illustrated certainly seem to be Dutch style, not British.
Well, another lesson learned! We all seem to learn the hard way. I did, too!
- 111 replies
- Nonsuch 30
- Model Shipways
According to Lees, catharpins of the style where a single block was lashed to each shroud with a zig-zag line laced back and forth, the ends seized together, were in use until about 1730. This applies to British ships. Not sure about Spanish, but most European rigging was similar. Anderson does not mention Spanish ships, unfortunately. He says there is very little information.
