Posts posted by CaptainSteve
Nice work on the mast-hinge, Buck. Good to see that the mean ole Quality Control lady let it pass through.
- Jack12477, mattsayers148, JesseLee and 3 others
- 6
For a very brief moment, I considered swapping books with you (an autographed Model Building with Brass for my AOTS). But, in truth, I'd really rather have BOTH books.
I have also read some reviews of Marquardt's book that say it is not entirely accurate. For me, personally, I find it to be a fantastic and extremely detailed tome, although I have never claimed to be any kind of Naval Historian.
That's a fantastic picture, Ken !! It appears to show both Royal Studs and Topgallant Studs on the Mizzen, as well as a second Swinging Boom.
I think I'm gunna need a bigger modelling room !!
Just a thought, but with regards to the booms, would the fore ones fold back along the channels, and the main-mast ones fold forward ?? (I'll check again, but I'm sure AOTS only showed the one along each side, though clearly two would be required.)
Ken,
I've pulled out my copy of AOTS and had a scan thru the Masting and Rigging Sections. There really is a ton of useful information in that book (some of which I'm still discovering). At first, I must admit that CapnHarv's explanation made sense - that any mainmast stud-sails would deprive the foremast stud-sails of any wind.
However, AOTS provides irrefutable evidence that Connie not only had Main- and Fore-mast studding sails ...
... but also had the option for Mizzen-mast studding sails ...
It would seem that, with one exception, all of the studding booms are kept fitted to the corresponding spar ...
The one exception would be the one boom that is stored alongside the main-mast channels. This is the one which you have already modelled (and which I shamelessly plan to copy from your build). This boom is more correctly known as the Swinging Studding-sail Boom.
(In this pic, you are interested in Item #30. Rather difficult to spot, but it appears below the open bulwarks between the mainmast and the foremast.)
Here is a pic of a studding-boom attached to its' corresponding spar (I can try to get a better photo if you need it) ...
(You are interested in the fourth spar down from the top of the page.)
Finally, a pic showing the fixtures for the Swinging Boom where it lies against the channel ...
Hope these are of use to you. Let me know if you require any others.
- Elijah, Stubby, Geoff Matson and 5 others
- 8
Matt, is M-E's rigging line any good? I ask because I have an unused credit there and budget is always a concern for me. I'm definitely ordering blocks from Syren.
CH, I wasn't at all impressed with the ME line in the Bounty Launch kit, and replaced all of it with Chuck's Syren rope. I plan on doing the same with my MS Constitution build, and have already laid in one order with Chuck for both rope and blocks.
I think you will notice a vast difference with the Syren stuff.
- mtaylor, Cathead, mattsayers148 and 3 others
- 6
Coming along nicely, Sunsanvil. I also lost a lot of the cherrywood when doing the frames. Indeed, there was barely enough of them to complete the Launch ... and I may have even needed to substitute some wood I'd saved from previous kits. In my case, I was painting the kit anyway, so this wasn't too much of an issue.
With regards to bending the planks, as I recall, I just soaked them in cold water and then used the curling iron to apply heat while making the bends around the bow area.
Actually, Jud, house-training a dog is a whole lot easier than most people realize. It just takes a bit of patience and the need to pay very close attention to your puppy for about three to four days. Training should start as soon as the dog is walking on her own.
All that is needed is to follow the doggie around closely for those first few days. The trick is that the very moment you notice the dog start to squat down, you interrupt her toilet intentions by clapping your hands loudly near her (to break her train of thought), then (still clapping) lead her outside to her designated toilet spot (it's essential that she learns to walk there by herself).
Now just wait. It won't take very long. As soon as the dog has done her business, reward her with heaps of praise and a treat.
Repeat this process after all meal-times, and whenever you see the dog going into a squat, for the next few days.
Naturally, an open door or fitted doggie-door is essential so that the dog can get outside by herself.
Have a section of garden reserved just for the dog to use as a toilet. You will need to bury any doggie-droppings regularly. Do this in the same spot, as the dog will come to recognize the smell as being her toilet place.
The Old Wives' tale of rubbing their nose in the mess is actually counter-intuitive as, most of the time, the dog is being punished for something that happened hours beforehand. They cannot associate the crime with the punishment.
Sorry to hijack your build-log, Nenad.
Beautiful work, Matt ... right down to the scuppers in the last pic.
- mattsayers148, mtaylor, kier and 3 others
- 6
Is there a visual cue to use?
I read that a gentle plying of the part will give an indication of the best orientation to bend it in (the one which is most yielding).
Can't say that I know wood well enough to have spotted any visual clues. I'd agree with what you have read about gently plying the wood. If it doesn't yield, then turn it 90 degrees.
How much spring back on the ribs is acceptable? Or phrased another way, how close to perfection should I be going for? Here is my test rib after being clamped in place for 24 hours.
That looks good. The plans, as I recall, mention spot-gluing the frame pieces just above the sheer-tabs.
- Elijah and Captain Poison
- 2
- Mark P, thibaultron, WackoWolf and 2 others
- 5
In the past, I have had great success with a hair-curling iron*. Just soak the strips in warm tap water. It may take a bit longer. Depending on the size and thickness of the wood, leave them for an hour or so. Then clamp the strips in the curling iron where you want the bend to form. You may require a tea-towel (or similar) to prevent burning your fingers.
(*Note: The part where I didn't have a lot of success was walking into a store frequented mostly by female members of the population and asking to buy aforementioned hair-curling iron. Something about a short-haired male (with tattoos) requesting said item seemed to result in stares of incredulity and wonderment amongst the staff.)
- Nirvana, Canute, thibaultron and 3 others
- 6
While waiting to see if any of my experiments with bending the wood for the deck beams actually works (smother in wood glue; soak in water for a couple of hours, let dry pinned in the curve overnight and then glue and put back in the pins) I started looking ahead. In one respect the kit seems a bit inaccurate - while there are five beams per deck, the kit comes with only 4 knees (2 per side) per deck, and those knees attach to the side of the beams, not underneath them. The knees provided are hanging knees, there are no lodge knees nor any diagonal knees. I've seen may pictures of this ship with diagonal knees, and I have a page of the plans from 1926 that show all three types of knees. Am I missing something here, or is the kit?
If I wanted to make diagonal knees, does anyone know a trick to getting the curve for the side against the hull - I expect it will not be exactly the same as the curve for the hanging knees.
Steve. Have you seen the cross section being built by Modeler12 ?? He is doing his from scratch and I know that he has done extensive work on the knees.
(See his log from about page 7 and onwards)
For someone who is flying blind, you are doing a fantastic job, Dave.
- SawdustDave, Canute, mtaylor and 2 others
- 5
Your close-ups are a thing of beauty, Thomas !!
- Elijah, Blue Ensign and Gahm
- 3
Sovereign of The Seas by SawdustDave - FINISHED
in - Build logs for subjects built 1501 - 1750
I'll be the lone, dissenting voice that says I wouldn't worry about a launch ... your ship is magnificent enough to stand alone as a display.
