md1400cs
Everything posted by md1400cs
  1. Frank, It’s my error. I had many files available to look at (see one below) did it wrong – Gave a look at my Vasa (all correct) – weird that I would attach the lanyards off to one side for this one. Easy fix – thanks for the diplomatic “heads up” Was goofing around last night took a few of the lights - here’s one I like. Seems as if I will need to do some dusting off before building its case. PS: I had, sometime back, occasion to speak with the owner of Evan Designs LED’s. Suggested that he contact MSW and possibly become an add sponsor (mentioned the 33k membership) – Still don’t see him listed in the sidebar – hmmm. Cheers,
  2. Ferit, Very well done!! - they look so well scaled - nice work
  3. Frank, Looking brilliant as you get deeper into this complicated build
  4. Hi mates, Minor updates - completed the hull gun doors, added deck support stanchions along with some other bits here and there. Decided to use kit provided frames, but make the doors.(happy that all the lights are still working !!) Now onto the mast, yards etc... Thanks for you continued interest in this very slow going log.
  5. Eddie, This will solve ALL of your problems. Use a very very small amount– it is thick, will adhere in a few seconds. It will attach anything to anything. Used this for all of my Vasa gilded bits+++. Use it for only FOR specific applications. Once you use it you will determine the best use for this product. It is great. If you need to move a piece - after glue has settled - just slowly pull the piece away – the dried glue will, like a rubber band, also pull away and can be completely removed leaving no glue marks on either bit. It will be difficult to pull away but it can be done. PS: used it for the ballast rocks – perfect.
  6. Hi Mates, E.J., Patrick, Frank – thanks for the kind thoughts ------------------ Completed the installation of the upper deck furnishings. Here are a few updated photos. Think that the sponge pole is a bit out of scale – may fix. With that fourth carriage decided to leave it unfinished placing it close to the unfinished gun port area. Two of those train tackles that I could not make use of (made a notations in previous post) instead worked out real well for use as gun tackles (wrapped the ropes as it would be in a “stored” position). As always thanks for your likes, notations and just dropping by.
  7. Ferit, nice to see your update - as always excellent work. Rigging looks just right.
  8. Michael, As EVERYONE has noted - Yes indeed your planking work is superlative. Hard to believe that you will cover it up with a second layer. Do you intend to plate the lower sections of the hull? The HMS Victory are one of those ships that make me just too nervous to even consider. Then there is the real estate war that would follow with the Admiral haha Will follow along & congrats on your newborn.
  9. Greg, WOA!!! indeed. found your log as it turned up on just posted updates. So in my "quick ignorance" saw your title and thought, "Hmmm what is an airship doing here?" then opened you log and got amazed (apologies for too many "like" clicks -- Your are indeed - as was mentioned - a master of plastic, PE, paint, research and aging - much more indeed. Brilliant work - So glad to follow along. Will need to go to your other builds as well - though don't see links in your signature (will find) Again superb work Regards,
  10. Martyn, Woa!! for a moment I thought that you had added photos of the 1/10th stern as an example- then realized!! - it is your brilliant painting details - You've set the bar very high for this kit - well done Cheers,
  11. Hi Mates, Martin – you are way too kind – big thanks ================== Update on deck guns –work in progress (paint details need to be fixed along with other bits) First so much for thinking ahead – did not even think about room on deck when I added rear train tackles to the carriages. Grrr As I did for the upper deck guns tried to also add the look of the capsquare eyebolt and keys to the carriages. Decided to at least add those to the three main deck guns – really simple to do. Then thought to add a challenge by also adding chainlinks that attach the keys to the carriages. Went to Michael’s Art supplies looking for a miniature jewelry chain that might work. Bit of paint and “looked ok” needs “touch up”. Next - made a jig template of sorts to measure, cut and attach second eyebolts to the breeching tackles – will be an easy install – just secure the guns and slip the eyebolts into pre-drilled holes. The jig makes adjusting and knotting other rope to eyebolts very easy Oh yes – got creative with the barrels – added a flat clear-coat to the sanded brass but now looks like flat gold paint – not happy with that – but oh well too late. I did a similar thing with my last build – scraping the emblems on the guns then adding a clearcoat –so faded the look almost disappeared so there is hope. I know that the brass rings on those guns is not remotely “correct”.
  12. Grant, SUPERB example of this super difficult (to achieve correctly) ship - Well done indeed.
  13. Excellent - really enjoy looking at your work PS: Damn that lathe is older that me.
  14. E.J., Just catching up on this one - looking super. Your scarf joints for the whales are perfect - Will add your technique to my memory banks- Great hull and deck work as well. Cheers,
  15. Denis: Thanks much appreciated - wanted to add just a bit to the visual - Regarding pins they are too short and a bit too large. Will let that go, as the rope coils will cover much of the scale issues IMO Working on carriages now. Very fiddly and time consuming - so tiny -, since I will only have three cannons on the main deck decided to take the extra time to fully rig them. That said I see that my trunnion cuts are too far forward on the carriages. Will need to remove those upper rows of wood, add new bits then re-groove further aft. Need to also make three quoins to fit under the guns. I don’t think that I will articulate the capsquares with keys and eyebolts. Did that for the lower gun deck carriages – totally lost work. Fun experiment, but Hmmmm Regarding the guns – just playing around – might un-blacken those rings – at least the ones at the breeches – just for their look – certainly incorrect historically. Might add rammers and shot triangled boxes. Will post when all is installed and completed. It will be a while haha… As always mates thanks so much for looking in and posting comments and likes……
  16. LF, Nice variation for a build log. Will follow as well. I'm using the instructions for the cross section that are included in the full ship kit for my cross section of same. There are more details added to your kit for the cross-section bit that are available with just cross-section instruction booklet (odd?) I'm also tempted to buy the full kit and attempting it later. Those would be a great side-by-side -- I have also read the the stern section is not too good. Other builders have done some great "fixes" to that area. You might want to look around at other build logs as well when you get into that area. Good luck with this one. Cheers,
  17. Thank Dave and Frank - mates thanks for the likes!! Continuing upper deck work. Added pin rails - rear rail and railing are not attached. Will add, much later, rear railing after I add hail and yard lines. Need to add deck blocks, rig carriages as well. Tried to use my Proxxon lathe to add details to knightheads - abject failure so improvised with left-over stanchion bits instead. Cheers
  18. Hi Mates, Been away from the shipyard for a couple of weeks. Added a few minor bits – but first Dave: thanks very much as an avid follower of your cross-section – very touching - thanks again Federicoaa: I looked briefly at the rigging sheets some time ago, as I am close to adding pinrails and blocks to the deck (no rigging at this point). Yes, you are right some lines do not have locations noted – My solution is in the last photo. This build will not go into any competition haha- so line locations are not SO important. That said somehow someway the Admiral will notice any line/pin errors hahaha Ferit: I think that you posted a question about how hull stairs could be climbed. That has been a question for me as well. Found very little at “Google University” – but there are apparently two methods – one of which I photographed from the 74 Gun ship bible book 2 (Jean Boudroit) With regard to stair alignments – Chose, the easier of the two solutions. well it is what it is. E.J. from your log - great idea for side skid contours. Cheers,
  19. Tom, Very excellent work - PS" you are right resurfacing the pins is a great "in scale" idea. Typically kit included wood pins are way out-of-scale. Alternative is buying aftermarket metal examples - hummmm? . Your idea is excellent. Regards,
