Everything posted by md1400cs
Katsumoto, This kit is absolutely NOT based on the Corel version; Corel's example is the least accurate of all the Vasa kits available (yes, mine was a Corel) Of the Deagostini examples in progress Marek's work here is brilliant. He has really captured the finely detailed colorful artwork that was present on the original - based on analysis of wood figures found after its resurrection. The museum's replicated carvings are an excellent tool to use as guides.
- 146 replies
- deagostini
- vasa
Frank: The knightheads will go through the upper deck and attach to the upper gun deck floor. Also need to figure out what kinds of details to those four. The ship was first rate - so certainly the knightheads were sculpted as well. BTW the kit provided pins are way too large. Will toss those - and gold metal no less.
- 371 replies
Denis: Yes that rail cutaway is part of the cutaway - might be overkill on my part - here are a couple more photos, including one from the outer hull. =========================== Started work on the stairs as well as the chainplates. Decided to use Amati parts for the deadeyes. Learned something. Apart from the fiddly business of wrapping these small strap rings around the deadeyes, I also knew that those brass parts should be black. Did not want to first dip all of those bits into Brass Black liquid, and then put them all togethre - way too messy - was just going to leave all of those bright. Then by chance decided to dunk a wood deadeye into the Brass Black solution - well (I sort of thought so) but Brass Black did not also blacken the wood deadeye. So then just dipped all of the completed assemblies into the solution. Rinsed and you can see the results - very acceptable. Thanks for the likes and just stopping by.....
- 371 replies
Yes indeed, very beautiful. Ulises was very helpful with my effort with my Vasa. He was kind enough to send me jpgs of all of his kit's running rigging sheets after I decided to also add sails to my Corel example. I also looked over so many of his build log photos for help - Thanks again UV. Cheers,
Congratulations indeed! As we would presume to say here in your old colonies - "Now that's a Grand Slam of a job. Though it seems that you had good help from two of our colonist's businesses for supplies lol... As always B.E. your work is superlative, and always a pleasure and learning experience to follow. Cheers
- 574 replies
- cheerful
- Syren Ship Model Company
B.E., Just catching up --what brilliance AGAIN !! - Cheers,
- 574 replies
- cheerful
NIce added details. These after-market brass bits - sometimes in the many hundreds+ pieces tend to double the price of the original kit but add many times over that in the look of the completed build. Well worth the added cost IMO Regards,
Denis, thanks appreciated. Made some minor final adjustments to these bits - now moving on.....will leave side (stairs?) ladders for later. I have seen drawings of this ship that include side skids in just about this area of midsection - need to think about this as well. Might get too busy looking. Good time for pinrails - need to get lathe out in any case for those missing deck support stanchions. PS: Missing some of your updates!!! Regards,
- 371 replies
Completed the revised look of the side planks glad it's done. Almost done with most of the woodwork - will add carriages and so on. Here are a few updated photos. Need to figure out how to add pin rail to that side hmmm--- This kit precludes any instructions in that regard only two rails in front of and behind the main mast. Of course not correct since the main mast is fully rigged including sails so pins on both sides are needed. (The OcCre instructions for the complete ship - that also includes a cross section as part of the full ship package does, in fact, show pins for the included cross section instructions) Odd that for buyers of just the cross section they ignore that bit. The cross section kit comes with pre-cut sails. Regards,
- 371 replies
Thanks Frank and EJ, Decided to try, in fact, leaving one side partially open from both the deck and hull sides - will show framing details for one of the gun frames on the deck - this will be more visible once the ship is completed. Looking through other builder's logs trying to educate myself on how it should look. The work that I have seen is way above my skill set - but having some positive representative ideas. EJ thanks for the "push" Cheers,
- 371 replies
Revision updates for deck side framing. Here are a few photos - As always thanks for your looking in, and advice much appreciated as well.
- 371 replies
Patrick, As all are saying - great work indeed. Your level of research for this project is great to follow as well. Must be fun looking for, and building as historically accurate as possible these details into this brilliant project. Cheers,
- 756 replies
- galleon
- golden hind
E.J. Good save on your part - looks as if your wheel also took a hit? MJD
- 961 replies
Patrick, Thanks for confirming -- I will start this area all over again I also need waterways - missing from other decks (I knew that but ignored them hmmmm) At least I had only started top deck one side. haha PS: You are fluent in Google ‼️ Regards,
- 371 replies
Hi Mates, This current bit has caused me some stress. Did not quite know how to approach the idea of also adding the needed openings for boarding the ship (not a detail as part of the kit). But here is a work in progress update. Took several failed attempts to figure out how to proceed - do think that it will work out now PS: having second thoughts about the thickness of the inner bulwark planks - could be too thick hmmm? Cheers,
- 371 replies
Frank, Vossiewulf, Denis, Patrick, Vivian - thanks so much for your nice posts much appreciated. Waiting for some oak planking from Age of Sails so upper hull and inner planks on hold. Kit is a bit "off" in this area - see assembly photos - so working on some other bits in the meantime. Stairs and upper deck grids are almost done.
- 371 replies
