mtaylor
Moderators
Everything posted by mtaylor
  1. It's not a competion. LOL. Your work is looking great.
  2. To the best of my knowledge, the synthetics can't be dyed. They're a filiment and not fibers.
  3. I hope you, your family, and son have a great time together. As for the tank.. I'm not sure the Germans painted their tools. The paint would wear off the metal pretty quick in use, but wooden parts I think where just oiled or varnished.
  4. Here's a trick for the taping. Apply the tape and then brush on some matt varnish over the seam and extend it a bit onto the tape and the surface to be painted. When dry after applying the paint, carefully remove the tape.
  5. One way to make handling these easier during installation is get some tiny dowels (wooden toothpicks with the point clipped off work). Dip the end of the toothpick into to some molten beeswax (just melt it, don't boil it). When cool, use the waxed end of the stick to pick up and put the parts into place. When the sticky stuff stops sticking, toss it and use a fresh one. Easy and cheap to make.
  6. Seems like you're way beyond thinking a few steps ahead... more like a hundred. Interesting construction to say the least and I'm looking forward to seeing more.
  7. Looks very good from here. That is a tricky piece to do.
  8. Jax only works on brass as I understand it. Same with the old "Blacken It" stuff. If copper, use liver of sulpher. Quite a few builders are using that.
  9. Not to pick a fight, but I would not suggest tea. It is acidic and will over time destroy the rigging. There are an abundment of cloth dies available if dying your own rope is what you want to do.
  10. One would have been for senior officer's use depending the ship and time period. On some, junior officer's heads were littterally at the head of the ship. On many ships, one gallery was for the Captain's exclusive use... some used it for a private office. As I said, a lot of variation and depends on the ship. Be a bit more specific to era, nation, and better which ship and answers can be more specific.
  11. Take one into your local hardware store. They usually have gages to check size and proper threads to match what you have with what they sell.
  12. Welcome to MSW, Dan. When the Dory is finished, feel free to post some pictures of the finished model in the gallery. And on Pram, by all means start a build log. It's the best way to meet other builders and also get help when you need it.
  13. Finally have the port side done with painting and touch ups.. more touch ups, ad infinitum ad nauseum. So here's two pics. I've turned the hull around and started the yellow on the starboard side. All things considered, I'm pretty pleased with the result so far.
  14. Road trip!!!!!! However, you may want to wait a few months until the snowy season is over.
  15. I was thinking what Keith thought about the stack. Some did swivel but you'd never, ever want one set up for the wind to blow into it. Kit technology and research have improved very much. The older kits, particularly cerain manufacturers, never bothered to put much time into research for a kit. Just follow the advice of the build log and give it your best shot.
  16. Kickbacks re rightfully scary. I haven't seen what Kurt did but a good friend had one and shot the 2X4 completely through the wall of his shop.
  17. Jaager gave some good advice. As for "kits".... Syren, Vanguard, probably CAF. The catch is, by the time you're ready for the next model, there will probably be new ones with huge improvements over some of the older firms models.
  18. Ah... as senior moment explains it all. Too many of us are having them. Myself included.
  19. It all looks good from here for things. As for the ship, been touching up paint, finishing adding some parts (trim) to the hull. Hopefully I can get the ochre on tonight and tomorrow and do an update before things get really hectic.
  20. I'm not sure there is a one-size-fits-all formula. I drip enough water in to get a consistancy of somewhere between milk and cream. Not to thick, not runny. This is defninetly one of those "experiment.... and then experiment some more" things to get it to where you want it to be.
  21. Håkan is right. Start simple and small and build your skills from there. There's no such thing as a "big no-no".... just a learning curve.
