Everything posted by mtaylor
Thanks for the likes and comments. I've started sanding and will take my time and not rush it. I know I'll have gap fill but I'm ready for that. On this step as Willie Nelson would say: "It's been fun and it's been real. But it ain't been real fun.". On the bright side, it was a good lesson to re-learn on first planking.
- 505 replies
- vanguard models
- Sphinx
Indeed on the appointed hour and family should come first before models.
- 2,677 replies
- heller
- soleil royal
(and 9 more)
Putting a render here won't be off topic since it is part of the Charles Martel. Also, it fits in with "methods" for building the model.
- 132 replies
- charles martel
- battleship
I think that banging one's head on the wall is actually part of model shipbuilding. Don't we all have bruised foreheads from either banging the wall or facepalming?
- 756 replies
- galleon
- golden hind
I do the same as you... make stick, glue some sandpaper down. Also the same grits. The other thing for sanding I use a lot is those disposable finger nail files. They're flexible and come in many grits.
Planking Question
mtaylor replied to Malazan's topic in Building, Framing, Planking and plating a ships hull and deck
First two photos didn't come down the pipe, Roger. They're links to nowhere. -
Update. The hull has it's first planking in place. Well, almost. I just ripped off two planks on the side not shown due to them coming loose. A bit of re-glue will fix and then tomorrow I'll start sanding. I believe that what happened was I wasn't as careful lining off the hull and the errors magnified themselves by the time I got to the keel. Lesson learned, sharper pencil and more patience needed.
- 505 replies
- vanguard models
- Sphinx
Flakpanzer T-34(r) by Backer - FINISHED - UM - 1/72 - PLASTIC
mtaylor replied to Baker's topic in Non-ship/categorised builds
Bingo! Spot on. Things haven't changed much in that regard since the earliest times in history. -
Greeetings from Italy, Sardinia Island
mtaylor replied to Ugo Crisponi's topic in New member Introductions
Welcome to MSW, Ugo. Beautiful work on the figures and gun. If you would like to, open a log on your carronade. We would love to see it. -
Rotary tool recommendations, preferences
mtaylor replied to Steve116's topic in Modeling tools and Workshop Equipment
For "light work", take a look at the WeCheer WE-242. It's small, variable speeds, but not much torque. Takes all the Dremel collets. I like it over the Dremel as I don't feel the weight of it but the "feel" of what's being shaped. -
Photographing your models
mtaylor replied to Patrick Matthews's topic in Photographing your work. How to do this.
I'll move this to the photo forum since that would probably be the best place. -
Fascinating stuff on these printers. It's voodoo to me but I guess time to start reading up a bit.
Swan-Class Sloop by Stuglo - FINISHED - 1:48
mtaylor replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
Is this a saw or thicknesser? If it's a thickness sander, your grit may be too rough. If it's a saw, check that the blade's teeth aren't offset and also go for a higher tooth count. Here's a good reference for table saws and blades and even though it's for the Byrnes it's very helpful for other saws. https://modelshipworld.com/topic/23843-byrnes-saw-reference-also-good-for-other-desktop-hobby-saws/- 475 replies
