Everything posted by mtaylor
If you were going to make it strictly a drag car, you could put some filler or plastic over the headlight area then paint it. Back, for just drag strip racing, a lot of guys did that. When I had my Vega strip car, I used run against a few of them. The 454 was sweet motor that needed minimal work (cam, carburation/injection, pistons and valve work) to turn it into a beast.
Enzo Ferrari by CDW - FINISHED - Tamiya 1:24 Scale
mtaylor replied to CDW's topic in Non-ship/categorised builds
One of my all time favorite cars. I would have maybe not killed for one only scratch them a bit. Even the new ones would be great. Alas, gotta' be a millionaire to get one and then there's the wait time. From my end, it would have the California smog equipment if it was street driven. Even back then the smog stuff bogged things down. I've seen several (including the newer ones) up close and wow.... The local dealer had one back about 5-6 years ago and I took the opportunity to sit in it. They offered to let me test drive but no.... I don't think my insurance would have covered it. -
Under "fair use" here in the States, one can post, for lack of a better word(s), bits and pieces as example. Posting the whole document would be a no-go.
Hello from the Mitten from moltinmark
mtaylor replied to Moltinmark's topic in New member Introductions
Nice work and welcome to MSW. For the gallery, just photos of the finished build. As for everything else you're showing, those should go into a build log in the kit section as this area is really only for introductions. -
English did the same thing with oaks. Not sure about France, etc. Looking at Dick's post from Monday (I'm behind the curve here) that would seem to be the logical solution.
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Welcome to MSW, Harvey from a fellow Oregonian. Do give some thought to doing build logs as they're a great way to get help and make friends.
- 2,626 replies
- heller
- soleil royal
(and 9 more)
Well done on the model, Eric. The tribute to your FIL was both moving and fitting. Loss of someone close is a hard thing. Thanks for sharing it.
tilt arbor table saw
mtaylor replied to Anthony Hearne's topic in Modeling tools and Workshop Equipment
The simple solution is to make a zero clearnace wooden insert. Cut a slab of wood the same thickness as the saw's insert. Shape it to match the original. Then.. drop the blade all the way down and put on the new wood insert. Turn the saw on and slowly raise the blade until it comes through. I've found you may need a couple of these for various thicknesses of blades and arbor size. There's also this, which may help. It was done some years ago by former wood supplier and is very helpful for the Byrnes and many of the other table top hobby saws. -
I'll be patient. I can't wait to see how the paint comes out. -
I went to that site, Bruce.... and this pops up at the bottom of the page: https://www.chairish.com/product/2178278/mid-century-luxury-liner-ship-model Let's not laugh too hard at the asking price.
glue for planking
mtaylor replied to BOB S.'s topic in Building, Framing, Planking and plating a ships hull and deck
I moved this to the correct area and deleted a duplicate post with no responces. -
I'll pull up a chair for this one also. This should be fascinating as we've not had a whaleback build until now.
- 33 replies
- James B Colgate
- whaleback
I can't add much to what's already been said, but your display really sets the mood. The shipyard worker is definitely a master stroke on an already masterful build. I too can't wait to see what you'll build next.
